POV-Ray : Newsgroups : povray.binaries.images : Dragonfly revisited 39k Server Time
24 Oct 2026 18:43:10 EDT (-0400)
  Dragonfly revisited 39k (Message 1 to 14 of 14)
Subject: Dragonfly revisited 39k
Date: 23 Aug 2000 17:58:58
Message: <39a44922@news.povray.org>
I like glass objects but I don't usualy have the patience to finish
them. This Dragonfly started over 2 years ago and was resurrected when
I tried megapov and photons.
<moan>
Wanted a yellow tail but caustics were too weak. Did not want a white
plane but anything else hides the caustics again :(
Still too many black pixels, even with max_trace_level 85, but AA 0.01
gets rid of most of them at this resolution. ADC_bailout does'nt help
much even at 0.05
</moan>
DOS MegaPov 0.4, Celery 500, 128M ram and took 72 minuits.
Alf
http://www.peake42.freeserve.co.uk/
http://ourworld.compuserve.com/homepages/Alf_Peake/
"...but I've never seen an elephant fly" tra-la-la (From Dumbo?)
Download 'Dragonfly.jpg' (39 KB)
Preview of image 'Dragonfly.jpg'
Subject: Re: Dragonfly revisited 39k
Date: 23 Aug 2000 18:34:43
Message: <39A45056.32E778EF@online.no>
> <moan>
> much even at 0.05
> </moan>
Nice !
I like the red glass a lot. What's the code for it ?
And how are the wings done ?
There seems to be some problems with the attachment of the
rear wings to the body.
Tor Olav
mailto:tor### [at] hotmailcom
Date: 23 Aug 2000 18:48:41
Message: <39A452A7.69C25495@faricy.net>
Phantastic! :-)
David Fontaine   <dav### [at] faricynet>   ICQ 55354965
Please visit my website:  http://davidf.faricy.net/
Date: 24 Aug 2000 07:36:59
Message: <39a508db$1@news.povray.org>
Looks like that gummy jelly stuff, yummy
Kitty5 WebDesign - http://www.kitty5.com
TEL - +44 (01625) 266358 : FAX +44 (01625) 611913
PGP Public Key
http://pgpkeys.mit.edu:11371/pks/lookup?op=get&search=0x55116DCC
Date: 26 Aug 2000 06:46:05
Message: <39a79fed@news.povray.org>
I posted 3 replies to this thread on 25/8 but can not see them here.
Can anyone else see them please?
Alf
Alf Peake <alf### [at] peake42freeservecouk> wrote in message
news:39a44922@news.povray.org...
when
> <moan>
white
0.01
help
> much even at 0.05
> </moan>
> Alf
Date: 26 Aug 2000 07:07:45
Message: <39A7A492.E95604C2@mindspring.com>
> Alf
I can't see them either, Alf.
Kevin Jackson-Mead
http://www.mindspring.com/~jacksonmead
Date: 26 Aug 2000 10:22:00
Message: <slrn8qfiq5.cn7.steve@zero-pps.localdomain>
Can't see any of your replies.  Maybe the browser crashed before you
posted or something.
  2:36pm  up 4 days, 18:54,  2 users,  load average: 1.07, 1.51, 1.55
Date: 26 Aug 2000 15:39:54
Message: <39a81d0a@news.povray.org>
(3rd repost, seems I can only reply to my original post)
Subject: ReDragonfly revisited 39k
Date: 25 August 2000 20:54
Tor Olav Kristensen <tto### [at] onlineno> wrote in message
news:39A45056.32E778EF@online.no...
> Nice !
Thank you.
#declare Filtr=0.95; // Used ior 1.45 in final merged objects.
#declare GlassF = finish{ phong 0.4 phong_size 400 diffuse 0.1
reflection 0.05 ambient 0.5 }
Object{ Thorax pigment{ rgbf <1,0.2,0.2,Filtr> } finish{ GlassF } }
// The PNG is wing-shaped crackle, blurred to round-off the outer
edges.
#declare Wing=
difference{ box{ <0,-1,0>, 0.996 }
            height_field{ png "dragonhf.png" smooth translate -y*0.25
inverse }
            height_field{ png "dragonhf.png" smooth scale <1,-1, 1>
translate y*0.25 inverse }
     translate <-0.02,0,-0.95>
     scale <5.5,0.05,1.5> // Front pair. Rear pair will scale this
one.
     rotate <-16,-104,0>
     pigment{ rgbf <0.8,0.9,1,Filtr> } finish{ GlassF }
Yes, its that blob / camera angle thingy again. Same sort of thing
happens with 'lipsoids. I also lose the shadow with some angles.
The jpeg shows a close up, camera over left wings, (leading edge to
the left) all other objects removed, tail would be to the right. The
left 2 sections are opaque, no photons, with camera <0,4,-4> and the
right one is clear with photons and camera <0,5,-3>. Note the right
pair of wings do not connect in this one :(
See also a larger version, 88k,  of the pic I uploaded here in March:
http://www.peake42.freeserve.co.uk/pix1/dragnfly.jpg
Alf
Download 'Detail.jpg' (19 KB)
Preview of image 'Detail.jpg'
Date: 26 Aug 2000 15:39:56
Message: <39a81d0c@news.povray.org>
(Been having trouble replying - seems response headers are screwed)
Date: 25 August 2000 16:20
Should be a macro around to cover this with sugar I guess. What
flavour the blue? :)
Thanks also David F for response.
Alf
Rick [Kitty5] <ric### [at] kitty5com> wrote in message
news:39a508db$1@news.povray.org...
> Rick
> PGP Public Key
Date: 28 Aug 2000 18:16:51
Message: <39AAE38B.A57CEA91@online.no>
> > Nice !
> Thank you.
Thank you!  I'll try that.
> edges.
> #declare Wing=
> inverse }
> one.
>      rotate <-16,-104,0>
Ahh... Height fields !
Thanks again.
I wasn't aware that there were such problems with blobs.
Is it a photons-only error, or can it happen to me in standard POV
as well ?
What are 'lipsoids in POV-ray ?
May I ask how you generate that Fibonacci stuff ?
I have a vague memory of a Golden Ratio between the
number of right turns and the number of left turns (?)
Tor Olav
Date: 28 Aug 2000 20:29:10
Message: <39ab03d6$1@news.povray.org>
"Alf Peake" <alf### [at] peake42freeservecouk> wrote in message
| much even at 0.05
Just over an hour to render isn't bad.
About the 85 for max trace, were you going by what the statistics show?  I would have
thought that
you could use a third that number easily.  Black dropped out pixels aren't the same as
dark pixels
:-)  I don't see anything wrong in this image anyhow.  Well, except I was trying to
see the blue
caustics and finally realized it looks spread out and less intense as the others.
It's a great glass dragonfly but that rear pair of wings, at the connecting points as
someone
already said, could use a better joining.
Date: 30 Aug 2000 19:42:10
Message: <39ad9bd2@news.povray.org>
Bob Hughes <per### [at] aolcom?subject=PoV-News:> wrote in message
news:39ab03d6$1@news.povray.org...
0.01
help
> | much even at 0.05
show?  I would have thought that
Yes, I get 85/85, and I realised it was probably overkill on my part
persuing it.
aren't the same as dark pixels
I was trying to see the blue
as the others.
It is spread. I wasn't happy about poor blue caustics either but
assumed it was something to do with the way RGB values are weighted.
Its clearer with ior 1.2 but I wanted around 1.5
connecting points as someone
The wings actually do penetrate the red blob, as can be seen in my 26k
jpeg reply to Tor (In this thread I'm only able to reply to my
original post, otherwise post goes to my ISP news server, not
news.pov). I don't know if its a photon thing or not. Will check when
I get the tine :)
Simplified source posted to p.t.s-f
> Bob
Alf
Date: 30 Aug 2000 19:42:11
Message: <39ad9bd3@news.povray.org>
news:39AAE38B.A57CEA91@online.no...
to
The
the
right
> as well ?
Happens with me in dos versions of pov3.1g and megapov 0.4
Will post a piece in p.t.s-f  (Dragnfly1.pov)
Superellipsoids. Sorry, my bad habit of shortening words.
March:
Check this, amongst others, explains better than I can:
http://www.mcs.surrey.ac.uk/Personal/R.Knott/Fibonacci/fibnat.html
and look for my GoldnRatio in p.b.i later, with source in p.t.s-f
> Tor Olav
> http://www.crosswinds.net/~tok/tokrays.html
Alf
Date: 4 Sep 2000 16:48:33
Message: <39B4095A.E6783931@online.no>
That's a great web page.
And thank you for posting your GoldenRatio code.
Now I'll go and see if I can blobbyfy it !
Tor Olav
