POV-Ray : Newsgroups : povray.binaries.images : Delving into the bozo world (144KB) Server Time
24 Nov 2026 08:58:57 EST (-0500)
  Delving into the bozo world (144KB) (Message 1 to 23 of 23)
Subject: Delving into the bozo world (144KB)
Date: 17 Oct 2000 06:01:12
Message: <39EC223E.51300FC7@hotmail.com>
Yesterday I took some time off from my old CSG-macros to
explore the bozo pattern.
Here's an image from this journey.
(The camera was placed inside the pattern.)
In this scene there are several hundred million spheres generated
by only one iso-surface.
Parsing time was a fraction of a second and rendering time was
about 2.6 hours on an AMD K6@200MHz
The image is best viewed with the lights in the room switched off.
Any comments ?
Tor Olav
mailto:tor### [at] hotmailcom
Download 'bozo04.jpg' (145 KB)
Preview of image 'bozo04.jpg'
Subject: Re: Delving into the bozo world (144KB)
Date: 17 Oct 2000 07:31:43
Message: <39EC389F.526A4346@schunter.etc.tu-bs.de>
Don't tell me you counted them ;-)
> Any comments ?
It looks good, i suspect it's made with no_shadow modifier.
A flythrough animation would be great, but 2.6 hours/frame would be quite a
lot.
BTW, you said it's a bozo pattern so you probably use a pigment function which
is slower than the plain noise3d although it should lead to identical results.
Date: 17 Oct 2000 11:30:24
Message: <39ec7090@news.povray.org>
Interesting. :)
I would have used shades of grey, as red and blue 'hurt' to look at.
How did you position the spheres according to the isosurface?
ian
Tor Olav Kristensen <tor### [at] hotmailcom> wrote in message
news:39EC223E.51300FC7@hotmail.com...
Date: 17 Oct 2000 17:50:19
Message: <39ECC714.CC5CF5C8@faricy.net>
The beauty of mathmatics? Maybe...
Neat idea.
Date: 17 Oct 2000 19:34:24
Message: <39ECE0E9.305975BC@hotmail.com>
Actually I tried to calculate how many there are.
I estimated the number of spheres in this scene to be about 10^10.
Yes you're right -My iso has a no_shadow modifier. But I believe now that
the sense of depth suffers from this.
> lot.
It certainly crossed my mind too. But I would need a much faster PC in order
to plan a good path for the flight. It was a lot of work just finding a good spot
to place the camera in this scene.
I even thought of a new application for my Nelder-Mead simplex macros:
Maybe I could make them determine the best "forward direction" in which
to move, in order to reach a new spot with low field strength. If this were
repeated, one could determine a flight path through the areas with low field
strength and therefore few spheres.
I.e.: An autopilot for "flying" through the "opens" in pattern-worlds.
But this would be a lot of work :(   -so I guess I wont try it.
Do you mean that the noise3d function also uses a kind of bozo pattern ?
Tor Olav
Date: 17 Oct 2000 19:47:43
Message: <39ECE408.B2CA6857@hotmail.com>
ian mcdonald wrote:
> Interesting. :)
I agree that the colours are not nice. I'm doing a new rendering now,
with the crackle pattern, where I have given all the spheres a light
blue
pigment.
And with a light source that fades with distances, this makes the
colours of the spheres to vary from deep blue to almost white.
I let the iso-surface do the work itself.
(-By using a pigment function inside an if statement. If the pigment
value in the middle of a "subcube" in 3D-space is above a certain
limit/threshold, a function is called to make a sphere in this
"subcube".
Else a constant outside the limit is returned.)
Unfortunately I have lost the source code for the image I posted,
but I'll soon post the code for the new image I'm rendering.
Tor Olav
Date: 17 Oct 2000 19:54:02
Message: <39ECE583.3C581FC9@hotmail.com>
> Neat idea.
Thank you.
I have been curious, for some time now, about how it will
look like if one could stand inside the different types of
3D-patterns that come with POV-Ray.
I think that the image I posted does not give a good sense
of depth. - It looks kind of flat.
So now I'm trying to figure out ways to increase the "3D-
feeling" for such scenes.
Do you have any ideas ?
Tor Olav
Date: 17 Oct 2000 19:59:37
Message: <chrishuff-A98B64.19021917102000@news.povray.org>
In article <39ECE0E9.305975BC@hotmail.com>, Tor Olav Kristensen
The bozo pattern *is* noise3d, or actually, Noise(). So are bumps(when
used outside of normals) and spotted.
Christopher James Huff
Date: 17 Oct 2000 20:32:54
Message: <39ECEEA7.AD8656E5@hotmail.com>
OK. Thank you.
But are there any differences in the possible applications (within
iso-surfaces)
for the bozo pattern and the noise3d function ?
And another question:
I tried to make the radius of all my iso spheres dependent of the field
strength
at certain points in space, but MegaPOV complained about not finding a
float inside the <> part of the "sphere" statement.
I think this is what I tried:
#declare BozoFunction =
function { pigment { bozo color_map { [ 0 rgb 0 ] [ 1 rgb 1 ] } scale 30 } }
#declare SphereFunction =
function { "sphere" <BozoFunction(x, y, z)> }
#declare ManySpheres =
function {
  SphereFunction(
    x - floor(x) - 0.5,
    y - floor(y) - 0.5,
    z - floor(z) - 0.5
Can you please explain ?    Is there any other way to do this ?
Tor Olav
Date: 17 Oct 2000 21:42:20
Message: <39ecfffc@news.povray.org>
Well, I would search for other nooks and crannies similar to how you placed
the camera, and place a few point light sources  here and there... and allow
the isosurface to cast shadows... you'd get little 'caves' of light. Mainly
just avoid using a main 'fill' light near the camera.
Andy Cocker
www.mariner9.net
..... for my music and graphics.
'I spilled spot remover on my dog. He's gone now. '
'I went to a restaurant that serves "breakfast at any time."
So I ordered french toast during the Renaissance. '
 - Steven Wright.
"Tor Olav Kristensen" <tor### [at] hotmailcom> wrote in message
news:39ECE583.3C581FC9@hotmail.com...
> > Neat idea.
> Thank you.
> Tor Olav
> http://www.crosswinds.net/~tok/tokrays.html
Date: 17 Oct 2000 22:04:41
Message: <chrishuff-4CE961.21072517102000@news.povray.org>
In article <39ECEEA7.AD8656E5@hotmail.com>, Tor Olav Kristensen
> iso-surfaces) for the bozo pattern and the noise3d function ?
Well, you can use the color_map of the bozo pigment function to get a
different range of values...and using noise3d() directly is faster.
> field strength at certain points in space, but MegaPOV complained
> about not finding a float inside the <> part of the "sphere"
> statement.
That portion of the function is parsed once and then the result is
evaluated multiple times...you can't use isofunctions to control it. The
same goes for pigment functions...you can't do something like this:
function {pigment {bozo scale Func(x, y, z)}}
One of the more obvious reasons for this is that the syntax for
functions and the syntax for the rest of the POV-Script can't be used in
the same place...for example, x, y, and z mean different things, vectors
don't exist in functions, etc.
No. Well, yes...you could modify the isosurface code to add a function
to do what you want, or you could use the eval_pattern() or
eval_pigment() functions to control millions of separate objects, but
that is probably not what you wanted to hear.
There may be some other way to get the same or a similar effect with
isosurfaces, though. There is very little that is impossible to do with
an isosurface...
Date: 17 Oct 2000 23:04:37
Message: <39ED10BE.8913C2@faricy.net>
Not quite related but similar, I had this idea to show the perspective
of being inside a menger sponge. Assuming the sponge is only a 2d
surface. I think by the nature of the sponge though it would be hard to
get a view that has a good onobstructed field.
Date: 18 Oct 2000 01:31:15
Message: <39EBF5BD.1D3DD63F@earthlink.net>
Isometrics is a cool tool...=)
> Any comments ?
> Tor Olav
Date: 18 Oct 2000 08:26:54
Message: <39ED970B.2C392393@enst.fr>
	Something like that should work:
#declare ManySpheres = function {
  sqrt (sqr (x-floor(x)-0.5) + sqr (y-floor(y)-0.5) + sqr
(z-floor(z)-0.5)) -
  noise3d (x/30, y/30, z/30)
	But I haven't tested it...
		Jérôme
********************************* Jérôme M. BERGER
* Abandon the search for truth, * mailto:ber### [at] inamecom
* Settle for a good fantasy.    * http://www.enst.fr/~jberger
Date: 18 Oct 2000 11:51:38
Message: <39EDC5F4.C1B7A07B@hotmail.com>
Yes. I think several point light sources is a good idea.
I now remember that I have seen pictures from real caves, where
there has been several light sources scattered around in the cave.
The effect from this was nice.
Thank you very much for this suggestion !
I have tried to let the isosurface cast shadows, but there seems to be
some problems with this. (See my "Inside the Crackle pattern" thread.)
Tor Olav
Date: 18 Oct 2000 18:48:00
Message: <slrn8us7e8.1mv.steve@zero-pps.localdomain>
Have a cylinder or two at the bottom of the scene running from
front to back, they could be neon pink or something.
 10:19pm  up 7 days, 23:39,  2 users,  load average: 1.07, 1.02, 1.00
Date: 18 Oct 2000 19:09:27
Message: <39EE2C8F.B5103C2B@hotmail.com>
Earlier today I didn't know what kind of sponge you were talking
about here. My dictionary didn't give me any clues either.
But then I did a search for "menger sponge" on www.google.com.
I found that this sponge is indeed interesting !
Have you or (anyone else in here) rendered this shape ?
With a recursive macro ? (Or with an isosurface ? =)
Tor Olav
Date: 18 Oct 2000 19:16:56
Message: <39EE2E4E.2931122A@hotmail.com>
Thanks for the suggestion.
I'll try something like this when I have found a solution to the problems
that I mentioned in "Inside the Crackle pattern" thread.
Tor Olav
Date: 18 Oct 2000 19:27:21
Message: <39EE30C1.6B71D3FF@hotmail.com>
> (z-floor(z)-0.5)) -
Hmmm...
I used this sqrt equation for the spheres, but then I discovered
the built in "spheres" function and started using that instead.
It didn't cross my mind to use the sqrt function when trying
to adjust the different radii according to the field strength.
But I think that I would have to change your noise3d part to
noise3d (floor(x/30) + 0.5, floor(y/30) + 0.5, floor(z/30) + 0.5)
I have not tested this yet either :)
Thank you.for this tip.
Tor Olav
Date: 18 Oct 2000 19:37:17
Message: <39EE330C.2231B737@hotmail.com>
I'm not very much into this kind of C-programming, so I think I'll seek for
other solutions.
> an isosurface...
I hope you are right. I'll try out a suggestion provided by  Jérôme M.
Berger.
Again: Thank you for explaining. I appreciate very much your efforts to
help.
Tor Olav
Date: 18 Oct 2000 20:06:03
Message: <chrishuff-237D0B.19084818102000@news.povray.org>
In article <39EE2C8F.B5103C2B@hotmail.com>, Tor Olav Kristensen
A while ago there was a craze of Menger sponges, Serpinski pyramids, and
other fractal shapes...I think there were at least a dozen different
methods being tried for Menger sponges alone. Some of them reached quite
high recursion levels...
Date: 19 Oct 2000 04:44:51
Message: <39EEB483.63098D2C@enst.fr>
	You're right, I thought about this too late. OTOH, since the value of
the noise3d won't change much over the size of one sphere, you might
find that the other equation gives adequate results and renders faster
(again completely untried...)
		Jérôme
Date: 19 Oct 2000 21:36:15
Message: <39EF9D77.4EEE93BE@global2000.net>
Wow!  This is neat!
Brendan
> Any comments ?
> Tor Olav
