POV-Ray : Newsgroups : povray.binaries.images : Concave shapes (43KB) Server Time
24 Nov 2026 09:08:44 EST (-0500)
  Concave shapes (43KB) (Message 1 to 25 of 25)
Subject: Concave shapes (43KB)
Date: 5 Oct 2000 11:11:45
Message: <39DC993C.5D889A93@online.no>
Yesterday I did some more work on some CSG-macros of mine.
They will "round off" any concave shape made with intersections
of planes, like the upper left shape.
The lower right shape shows how the resulting shape looks
like if both the edges and corners are wounded off.
The rendering is slow, so now I'm working on the macro
so that it will render much faster.
The upper right shape shows how the rounding looks like if
only the edges are rounded off.
And the lower left shape has different colours where "material"
has been "removed".
When I'm finished with the macros I'll post the source code
if anyone is interested.
Tor Olav
mailto:tor### [at] hotmailcom
Download 'roundoffplanes22_01_cleaned09.jpg' (43 KB)
Preview of image 'roundoffplanes22_01_cleaned09.jpg'
Subject: Re: Concave shapes (43KB)
Date: 5 Oct 2000 11:21:46
Message: <39DC9C88.54B9888F@erols.com>
Nota bene:  The shapes depicted are convex, not concave.
It's possible that making each face into a prism will help.  This
might be difficult, however.
John
Date: 5 Oct 2000 11:29:14
Message: <39dc9e4a$1@news.povray.org>
"John VanSickle" <van### [at] erolscom> wrote in message
news:39DC9C88.54B9888F@erols.com...
Well, not if you put the camera inside  :-)
You're quite the wizard with this kind of thing Tor, manipulating CSG
objects.  I just wanted to say that.
Any chance this could merge with one of the rock making includes?  Then
again, if this is slow and the rock makers are already slow it might be too
much for the typical scene file.
If the amount of roundedness can be adjusted it certainly could do well for
worn edges of such shapes anyway.
Date: 5 Oct 2000 11:37:46
Message: <39DCA04A.D00B7A72@schunter.etc.tu-bs.de>
looks good, how did you do it ? just CSG with planes, cylinders and spheres?
I suppose parsing will also be quite slow when working with complicated shapes.
> has been "removed".
Sure we are :-)
I estimate it's quite a lot of work doing it, so thanks in advance...
Subject: truncated cubes.
Date: 6 Oct 2000 08:18:15
Message: <39DDC1B9.8637A48C@my-dejanews.com>
I want the coordinates for a truncated cube, in terms of triangles.
Can anyone point me to a reference for this?
In other words, I have seen the list of triangles needed for a cube/
rectangular solid based on 2 corner points.  I want 2D projection of this
solid to be, instead of a square, a symmetric 8-sided figure.
Date: 8 Oct 2000 18:30:52
Message: <39E0F57C.F4D1F1E0@hotmail.com>
Ugghh...  -How did that happen ?!
I even looked up convex in the dictionary
to make sure that this wasn't only a
norwegian word before I wrote the post.
> This might be difficult, however.
Yes I think you're right. I like that idea.
Prisms would probably make it faster.
It would not be very difficult. The needed
data are already available within my macros.
But it will be some work determining how
data should be passed between the different
macros in an efficient way.
There's one problem with prisms though:
The "stones" could not be used in further
CSG operations. E.g. like I did in my image;
"Two spheres" posted to this news group 26.
April:
news://news.povray.org/3906D341.F1CD358C%40online.no
The two metal spheres are put inside the
"space" cut out by a convex shape "rounded off"
by some preliminary versions of these macros.
Tor Olav
Date: 8 Oct 2000 18:38:17
Message: <39E0F73A.B0E029C8@hotmail.com>
Thank you !  - I'm flattered :)
I'll look into it. Where can I find these
rock making includes ?
The roundness can be adjusted by setting
a "rounding radius" for the corners and
the edges.
Tor Olav
Date: 8 Oct 2000 18:56:10
Message: <39E0FB6B.A7DFECE0@hotmail.com>
The starting (convex) shape is just
intersections of all the involved planes.
Then one macro takes info about these planes
and calculates where every possible triple
of non parallel planes meets at potential
corners (points).
Then another macro removes all the corners
that are "false" (I.e. those that have one
or more planes "below" themselves.)
Then some other macros receives the data
about the final "true" corners and
constructs the shapes (CSG with cylinders
and spheres) that are used to "subtract"
from the starting shape.
Yes, but not unbearable slow (as the pre-
liminary macros was).
> Sure we are :-)
Yes, there's a lot of info to manage within
the macro. But I've now manage to make them
much faster. But there's still some work
left to make them stop calculating the same
things over and over.
Maybe I can force myself to post some code
soon, even if I'm not satisfied with it yet.
Tor Olav
Subject: Re: truncated cubes.
Date: 8 Oct 2000 19:00:45
Message: <39E0FC7F.44BB1E09@hotmail.com>
I'm not sure if I understand what you mean.
Can you try to explain more or post an
image of this shape (e.g. made by inter-
section of planes) ?
By truncated cube, do you mean that the
original corners are "cut" off ?
Tor Olav
Date: 8 Oct 2000 23:10:35
Message: <39e1372b@news.povray.org>
"Tor Olav Kristensen" <tor### [at] hotmailcom> wrote in message
news:39E0F73A.B0E029C8@hotmail.com...
I'm having no luck finding the rock includes or macros, sorry.  One thing is
John Van Sickles and it seems Chris Huff may have something too (not sure),
and at the POV Objects Collection...  Steve Pidgeon was another person that
did one I know.
Date: 8 Oct 2000 23:21:54
Message: <39E1376B.51EDCFE6@faricy.net>
If you have a cube going from <-1,-1,-1> to <1,1,1> and you want to truncate
it so each of the original six faces becomes a regular octagon, then the
vertices would be at
<±1,±1,±(sqrt(2)-1)>
<±1,±(sqrt(2)-1),±1>
<±(sqrt(2)-1),±1,±1>
(2^3+2^3+2^3=24 vertices)
Date: 9 Oct 2000 02:19:05
Message: <39E1622C.580FBDDA@pacbell.net>
> did one I know.
> Bob
If I'm not mistaken John has removed his rock include from his
website but he may have included it with his subdivision surface
suite - http://users.erols.com/vansickl/sss.htm which is in it's
own right a fun toy to play with.
Steve's site is at:
http://www.iro.umontreal.ca/~pigeon/pub/PovPage/RockGen/RockGen.html
See also:
http://www.rahul.net/endl/mallan/html/rocks.htm
http://www-personal.umich.edu/~mstock/pages/rocktools.html
Date: 9 Oct 2000 06:06:24
Message: <MPG.144ba8e7cb24f838989804@news.povray.org>
On Sun, 08 Oct 2000 23:14:04 -0700, Ken wrote...
I had a look at that URL, and it seems that the Surface Subdivision Suite
page has moved to /dev/null <grin>, as the URL you posted points to a new
page, which gives a 404...
John?
Bye for now,
     Jamie.
Date: 9 Oct 2000 08:21:28
Message: <39e1b848@news.povray.org>
Any chance of you posting the macro code itself...
Rarius
Date: 9 Oct 2000 08:33:04
Message: <39E1B9BD.60A199EA@my-dejanews.com>
Thanks, but what I meant is this:
Take  perfect cube.  set each edge on a grinding wheel such that the normal of
the two faces on this edge make a 45 degree angle with the normal of the
grinding wheel.  Do it for just a second or two.
Date: 9 Oct 2000 11:22:58
Message: <slrn8u3ohq.1jk.ron.parker@fwi.com>
So what you want is a cube with beveled edges.  The size of the bevel is a
factor in finding the corners.
What used to be a square face will still be a square face, but it will be
moved inward on all sides by the size of the bevel.  What used to be an edge
will now be a rectangular face; connect corresponding edges of the new square
faces to find the twelve new faces.  What used to be a vertex will now be a
triangular face; connect corresponding corners of the new square faces to
find the eight new faces.  The final object will have 26 faces, with a total
of 44 triangles.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Proudly not helping RIAA and SDMI steal my rights --
  http://www.eff.org/Misc/EFF/Newsletters/EFFector/HTML/effect13.08.html
Date: 9 Oct 2000 11:56:16
Message: <39E1E972.407515C7@pacbell.net>
Hmmm.... I'll see if I can track it down.
Ken Tyler
Date: 9 Oct 2000 14:43:37
Message: <39E210D5.A2979329@online.no>
> of 44 triangles.
Are you sure about all this ?   :)
See enclosed image.
To Greg:
When I've cleaned up the source code (that I believe
solves your problem), I'll post it.
Tor Olav
Download 'truncatedcube03.jpg' (18 KB)
Preview of image 'truncatedcube03.jpg'
Date: 9 Oct 2000 16:58:39
Message: <39E23080.DA437FE3@online.no>
Yes I will. -But it needs some more work first.
Right now I'm too tired to do this work.
Tor Olav
Date: 9 Oct 2000 17:12:37
Message: <39E23260.EB784E5@faricy.net>
Ah, that's bevelled, not truncated :) (Besides i think my data was wrong, it
should have been (2-sqrt(2)) for perfect octagon)
so you want a perfect octagon for the cross section? hmm...
<±1,±(sqrt(2)-1),±(sqrt(2)-1)>
<±(sqrt(2)-1),±1,±(sqrt(2)-1)>
<±(sqrt(2)-1),±(sqrt(2)-1),±1>
<±.75,±.75,±.75> (?)
24 vertices, 18 faces, 60 triangles
Date: 9 Oct 2000 19:11:51
Message: <39e250b7@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:39E1E972.407515C7@pacbell.net...
| > the URL you posted points to a new page, which gives a 404...
Only the last of those 4 addresses worked for me.  No wonder I couldn't
locate anything, and I had misspelled Steven Pigeons' name (sorry Steve).
Anyhow, not sure any of this goes with what Tor has done since the rocks all
seem to be triangle mesh instead of plane intersections.
Date: 10 Oct 2000 20:19:44
Message: <39E3B121.D80F0C6E@online.no>
I've now posted some source code that provides you with the coordinates
for the corners. (Watch the output in the debug window.)
See my recent post "Source code for bevelled box" to povray.text.scene-files:
news://news.povray.org/39E3AFCA.B8FB8283%40online.no
Tor Olav
Date: 11 Oct 2000 00:09:47
Message: <39E3E6D3.D03F7949@pacbell.net>
> Bob
After contacting John the Subdivision Surface Suite is now back online
at - http://users4.50megs.com/enphilistor/sss.htm
Steven's page is still valid as is Mack Stocks page. The only one
that appears to be gone is "Rocks" at -
for which there appears to be no replacement URL for.
Three out of four ain't bad :)
Date: 12 Oct 2000 08:59:58
Message: <39E5B473.5CFF8783@my-dejanews.com>
Oh my dear friend, I am sorry. I wanted triangles.  Let me figure it out myself.  I
am a newbie at discovering the benefits of triangles.    If I were to use the
intersection of a dozen or more planes, I might as well have used a superellipsoid.
Download 'cells.jpg' (21 KB)
Preview of image 'cells.jpg'
Date: 3 Dec 2000 01:59:25
Message: <f8rj2t8d0mp38q5krhkb3tgkttr1qbp4mn@4ax.com>
On Mon, 09 Oct 2000 08:27:41 -0400, "Greg M. Johnson"
<gre### [at] my-dejanewscom> blathered:
Let me first state that I've read the rest of this thread (as of this
date) and know my answer is not what you're looking for.
This description (above) leads me to describing how I figure out the
appropriate method for creating a shape.  If I were creating a cube
that I wanted to look like it had the corners knocked off with a
grinder, I tend to create the cube, then use a CSG difference to
remove the parts the grinder took away.  In other words, I try to
create the effect of the manufacturing process.
<inside_voice> Pinot Gris has an odd effect on my thought
processes...</inside_voice>
I'd create the cube, then create my imaginary grinding wheel.  Then
I'd use a CSG difference (or maybe a few thousand...) to remove the
corners.
Defective O-O
http://members.home.com/redundant/Defective/
(yes, I know that's the wrong membername...ran out of space at
http://members.home.com/defective/)
