POV-Ray : Newsgroups : povray.binaries.images : BMP format Server Time
24 Oct 2026 14:02:22 EDT (-0400)
  BMP format (Message 1 to 19 of 19)
Subject: BMP format
Date: 4 Oct 2000 08:20:21
Message: <39DB2085.FACFC1AE@erols.com>
Can the server be configured to reject attachments with the BMP
extension?
Subject: Re: BMP format
Date: 4 Oct 2000 09:56:44
Message: <39DB371D.58915BC0@enst.fr>
> extension?
	Or could the maximum file size be lowered? Is there such a limit right
now? How much is it?
		Jérôme
******************************* Jérôme M. BERGER
Date: 4 Oct 2000 10:48:33
Message: <39DB4238.F8F0623C@pacbell.net>
> > extension?
I don't know off had without consulting with Mr. Cason about it.
Might be possible but likey not worth the hassle.
The following is based on some actual knowlege of the server while
other parts are educated guesses:
The server currently imposes a 1 meg limit on all messages. This number
could be adjusted on a group by group basis but I think at the moment
it is a global setting for all of the groups. If lowered it would likely
impact the binaries.animations group whose files sizes are generally
much larger than in this group.
I personally don't see a need for a change at the moment. I believe
that peer pressure works well and most people do not make the same
mistake once being informed of the problem.
Date: 5 Oct 2000 08:36:35
Message: <39DC7492.16B4CD84@my-dejanews.com>
If we're going to get fussy about it, how about also knocking out PNG's
and all animations other than MPG-1?
> extension?
Date: 5 Oct 2000 09:35:38
Message: <39dc83aa@news.povray.org>
"Greg M. Johnson" <gre### [at] my-dejanewscom> schrieb im Newsbeitrag
news:39DC7492.16B4CD84@my-dejanews.com...
What is wrong with PNG ???
isn't it better than GIF if you don't want a lossy compression ???
mostly it is  as good as PNG AFAIK ...
Date: 5 Oct 2000 10:46:54
Message: <39dc945e$1@news.povray.org>
"Jan Walzer" <j.w### [at] itcampusde> wrote in message
news:39dc83aa@news.povray.org...
I assumed he was being ironic sans smileys - maybe not. BTW I assume you
mean jpg, not gif (gif isn't lossy, except in the sense of being only 256
colours - a gif opened and repeatedly re-saved doesn't degrade, a jpg
does*).
* something I wish I'd known three years ago.
Date: 5 Oct 2000 10:59:57
Message: <39DC976C.35E15178@spiritone.com>
The closest thing to a problem I have with png is that Nescape doesn't
display a png file in the message window like it will with jpg. I have to
click on it and lose the message.
Josh
eng### [at] spiritonecom
Date: 5 Oct 2000 13:07:59
Message: <39DCB42D.82BE9596@my-dejanews.com>
I think it actually has to load the Quicktime plug-in.  And for me, I cannot
scroll up and down on an image which is larger than my small window, as was the
case with today's "Emoti-Pov".   It all boils down to that Dilbert cartoon
where the girder has fallen on one employee's head and Catbert reminds him,
"Nobody else is complaining."  It's just like the html issue.
Date: 6 Oct 2000 03:07:33
Message: <39dd7a35@news.povray.org>
Josh English <eng### [at] spiritonecom> wrote:
: The closest thing to a problem I have with png is that Nescape doesn't
: display a png file in the message window like it will with jpg. I have to
: click on it and lose the message.
  Strange, here it shows it normally, as any jpg or gif.
  It may be that
  a) You have it wrongly configured
  b) Netscape for Solaris is after all that different from Netscape for
Windows (or are you using Linux? Anyways). It wouldn't be the only difference.
Date: 6 Oct 2000 04:17:58
Message: <39DD8AB6.4293343B@enst.fr>
	I have no problem here (Netscape 4.75 for linux) and I had no problem
at school (Netscape 4.08 for Solaris)...
		Jérôme
Date: 6 Oct 2000 08:33:45
Message: <39ddc6a9@news.povray.org>
"Greg M. Johnson" <gre### [at] my-dejanewscom> wrote in message
news:39DCB42D.82BE9596@my-dejanews.com...
to
cannot
was the
him,
Sorry about Emoti-Pov png... but jpg didn't like that image (sharp
transition and near pure red, green, blue). I have no problem seeing it with
Outlook Express. Nonetheless I will mind that Netscape has some problems
with this great format. I think some programs have (had?) problems with gif
too... is this right?
Povingly,
Philippe
Date: 7 Oct 2000 19:03:47
Message: <39dfabd3@news.povray.org>
I have a 280*210 82k png due for upload. It has single pixel reds and
greens that are killed with lowest jpeg compression. What format would
you suggest?
Alf
Greg M. Johnson <gre### [at] my-dejanewscom> wrote in message
PNG's
> > extension?
Date: 7 Oct 2000 21:52:34
Message: <slrn8tvjrd.sro.steve@zero-pps.localdomain>
>you suggest?
PNG would probably be best for that, I don't have a problem with PNG, though
some people do.
  2:33am  up 9 days,  4:52,  2 users,  load average: 1.00, 1.00, 1.02
Date: 7 Oct 2000 22:02:25
Message: <39DFD357.AE9A91AC@faricy.net>
> some people do.
I don't have a problem with PNG, it's an excellent format. I have a problem with
Nutscrape. :(
Stupid POS diplays them inline if they're in HTML, but uses the plugin if
they're attached, and the Edit button is grayed out for the association.
Date: 12 Oct 2000 09:11:23
Message: <39E5B737.5BF584B3@my-dejanews.com>
My point in the whole affair was that those who say, "Let heads roll," usually
aren't safe for long themselves.
PNG is a very minor inconvenience to me.
There are a bunch of eclectic video formats that people keep dredging up, forcing
some of us to either pass them by or slop through a bunch of bleeding edge codecs.
David Fontaine wrote:
> > some people do.
> Nutscrape. :(
Date: 15 Oct 2000 18:45:47
Message: <39EA33A4.CC97BEC4@ij.net>
> extension?
	As they say, anything can be done. I have never done it but it could be
scanned after received for the string "anything.bmp" and erase the post.
That can be beaten if someone wants to so the right way to do it would
be to search for the identifier of a BMP type graphic which servers and
browsers already do.
http://www.giwersworld.org/ is not blocked by Surf Watch.
How bad can the former be? How good can the latter be?
	-- Iron Webmaster, 84
Date: 15 Oct 2000 18:47:30
Message: <39EA340D.E5D6CA54@ij.net>
	Don't know about IE but NS 4.75 now handles PNG format. That is worth
the upgrade.
What is the sound of one hand clapping?
A spanking.
	-- The Iron Webmaster, 136
Date: 15 Oct 2000 18:48:52
Message: <39EA345F.771F87E9@ij.net>
	4.75 does.
Q. "Do you realize I can defame you without penalty?"
A, "Do you realize I can let you?"
	-- The Iron Webmaster, 31
Date: 15 Oct 2000 21:58:20
Message: <39EA5E3A.6E0B7255@faricy.net>
> the upgrade.
Yup! Even though it was several megs...
