Why don't facets work in a pigment function...
#declare My_Function =
function { pigment { facets.....
Rendering error.
Problem in Evaluate_TPat.Reclaiming memory
On Sun, 10 Sep 2000 12:16:15 -0700, SomeGuy wrote:
>Why don't facets work in a pigment function...>>#declare My_Function =>function { pigment { facets.....>>Rendering error.>Problem in Evaluate_TPat.Reclaiming memory
Not sure about the errors, but facets is a normal-only function. You
should try crackle solid instead if you're using it in a pigment.
Ron Parker http://www2.fwi.com/~parkerr/traces.html
My opinions. Mine. Not anyone else's.
Oh... )=
Thanks... (=
Ron Parker wrote:
> On Sun, 10 Sep 2000 12:16:15 -0700, SomeGuy wrote:> >Why don't facets work in a pigment function...> >> >#declare My_Function => >function { pigment { facets.....> >> >Rendering error.> >Problem in Evaluate_TPat.Reclaiming memory>> Not sure about the errors, but facets is a normal-only function. You> should try crackle solid instead if you're using it in a pigment.>> --> Ron Parker http://www2.fwi.com/~parkerr/traces.html> My opinions. Mine. Not anyone else's.
