POV-Ray : Newsgroups : povray.binaries.images : Fibonacci Stones (142KB) Server Time
24 Nov 2026 09:34:37 EST (-0500)
  Fibonacci Stones (142KB) (Message 1 to 30 of 30)
Subject: Fibonacci Stones (142KB)
Date: 4 Sep 2000 21:26:59
Message: <39B44A76.2ECBA98A@online.no>
For this image I used some of Alf Peak's code in his post
"Golden Ratio" to p.t.s-f  31. Aug;
(news://news.povray.org/39ad9be0%40news.povray.org)
in combination with my AntiBlobs macro.
Comments are welcome.
Tor Olav
mailto:tor### [at] hotmailcom
Download 'fibonacci02.jpg' (142 KB)
Preview of image 'fibonacci02.jpg'
Subject: Re: Fibonacci Stones (142KB)
Date: 4 Sep 2000 22:22:26
Message: <39B4598F.8AD92D68@unforgettable.com>
This would look interesting if you embedded the blob in a wall and used
an image for pigmentation.. instant Fibonacci mosaic art.
-Xplo
Date: 5 Sep 2000 01:35:59
Message: <39B487F3.7B4C522B@pobox.com>
A very appropriate use of AntiBlobs!
Anton Sherwood  --  br0### [at] p0b0xcom  --  http://ogre.nu/
Date: 5 Sep 2000 03:29:20
Message: <39B4A105.AF460FEE@schunter.etc.tu-bs.de>
> Tor Olav
Looks good for some ground paving, just add some sand between, maybe scale the
texture ...
Date: 5 Sep 2000 07:11:57
Message: <39b4d4fd@news.povray.org>
Great...... could we perhaps see the source ? :-)
Ian
Inkwell: Ian's Homepage
http://www.topcities.com/cartoon/inkwell/index.htm
"Christoph Hormann" <Chr### [at] schunteretctu-bsde> wrote in
message news:39B4A105.AF460FEE@schunter.etc.tu-bs.de...
> > Tor Olav
the
> texture ...
> Christoph
> Homepage: http://www.schunter.etc.tu-bs.de/~chris/
Date: 5 Sep 2000 10:45:21
Message: <39b50701$1@news.povray.org>
This is a little bit off topic, but not too much since raytracing is all
about math.
Anyone interested in mathematics and/or the golden ratio and/or pi should
check out the film called "Pi".  See http://www.pithemovie.com for more info
about it.
Date: 5 Sep 2000 12:02:57
Message: <39B517ED.F7229D48@online.no>
I like that idea. Thanks.
I guess I need MegaPOV to that...
Or is it possible to read from an image file with
standard POV ?
Tor Olav
Date: 5 Sep 2000 12:03:45
Message: <39B5181D.BDDC0749@online.no>
Tor Olav
Date: 5 Sep 2000 12:07:53
Message: <39B5190D.37C68592@online.no>
I'll try to make a simple render with the camera
low and looking "horizontally" to see how that looks.
Hmmm... I need to figure out how to make a
sand texture.
> maybe scale the texture ...
Up or down ?
Thank you for commenting
Tor Olav
Date: 5 Sep 2000 12:14:52
Message: <39B51AB0.C47062F2@online.no>
I'll try to post the code later today.
I'm not quite satisfied with the AntiBlobs macro yet.
For this image I replaced this line;
#local NStrB = (Trh - StrA*PowA)/PowB;
in the macro, with this line;
#local NStrB = -abs((StrA*PowA - Trh)/PowB);
But I have do some more math-thinking to see
if I can make this macro better.
Tor Olav
Date: 5 Sep 2000 12:29:00
Message: <39B51E08.3B2723CB@online.no>
> about math.
> about it.
I would like to see this film, but unfortunately I haven't
seen any advertisements for it here in Norway.
But maybe I can order a DVD-copy of it.
Thank you for the tip.
Tor Olav
Date: 5 Sep 2000 12:43:31
Message: <39B522EB.CF16615D@schunter.etc.tu-bs.de>
> sand texture.
plane with some granite normal or ... isosurface ;-)
> Up or down ?
down, but you can also leave it as it is.
Date: 5 Sep 2000 13:35:05
Message: <chrishuff-AC6430.12364705092000@news.povray.org>
In article <39B517ED.F7229D48@online.no>, Tor Olav Kristensen
> standard POV ?
Not unless it is an ASCII format. However, you could position the blob
component at the origin, rotate an image map so the portion of the image
the blob will represent is also at the origin, and scale it up by a
large amount, so the whole component is a single color. Doing this, you
could make it *look* like each blob component has a solid color.
Using the eval_pigment() function would be much more elegant, though...
Christopher James Huff
Subject: Re: Fibonacci Stones -> Mosaic image (75KB)
Date: 5 Sep 2000 17:18:49
Message: <39B561E7.BC0D7B11@online.no>
> > standard POV ?
So I could read an uuencoded image then ? =)
Great idea !
I have now tried this with an array of spheres. => See attached image.
Is this a well known technique ?
Now I have to go and try to use this on my antiblobs,
as Xplo Eristotle suggested.
Yes, but .... :)
Tor Olav
Download 'imagemosaic01.jpg' (76 KB)
Preview of image 'imagemosaic01.jpg'
Date: 5 Sep 2000 17:23:55
Message: <39B56320.3F77E7E@online.no>
> > sand texture.
NO!  It can't be THAT simple.   :-)
I was thinking too complicated then ...
> > Up or down ?
Ok
Tor Olav
Date: 5 Sep 2000 17:43:03
Message: <39B567A5.57EC279A@online.no>
I used a part of the first image on this page:
http://www.wadhome.org/frazetta/overview0002.html
(Not really: Some years ago I scanned my Frazetta
poster-book with a monochrome scanner and added
pseudo colours to the image.)
If anyone is interested in the art of Frazetta, then here
are two links:
http://www.frazettaartgallery.com/
Tor Olav
Date: 5 Sep 2000 17:55:04
Message: <chrishuff-1ECF18.16564705092000@news.povray.org>
In article <39B561E7.BC0D7B11@online.no>, Tor Olav Kristensen
An interesting idea...anyone want to write a uu-decoder in POV-Script?
Ouch, did I really write "rotate"? I meant "transform"...
If it is, I have not seen it...it was just something I thought of as I
was writing that the eval_pattern() patch was the only way to do it. :-)
I highly doubt I was the first to come up with this idea, though,
especially since there have been mosaiac images in the past using
official POV.
> Yes, but .... :)
But it requires a patched version of POV.
And if you want to do something to the objects themselves that depends
on the color, or if you want to make them light sources or something,
you do have to use eval_pigment().
Date: 5 Sep 2000 18:21:16
Message: <39B5728A.54AE8936@unforgettable.com>
Ha! I can see it now: Fibonacci mosaic glows.
-Xplo
Date: 5 Sep 2000 18:23:45
Message: <39B5731F.5DE12310@unforgettable.com>
> > > sand texture.
Nonsense. Making 600,000 tiny isosurfaces and tracing them onto a
surface is a GOOD idea. :P
-Xplo
Date: 5 Sep 2000 18:58:06
Message: <chrishuff-1C2CFF.17594805092000@news.povray.org>
In article <39B5728A.54AE8936@unforgettable.com>,
My version of the glow patch is based on MegaPOV, which has
eval_pigment(), so I didn't mention that. Though it would be a problem
with POV-AFX...
Date: 5 Sep 2000 20:08:26
Message: <39b58afa@news.povray.org>
Here's my own attempt at a Fibonacci antoblob floor... I got tired of
waiting and made my own source ;-) I don't fully understand how to do it but
I'd like to have larger gaps between the tiles.
Download 'floor.jpg' (19 KB)
Preview of image 'floor.jpg'
Date: 5 Sep 2000 21:24:58
Message: <39B59BA5.15ECE20D@online.no>
It's not TODAY longer, but I posted it to p.t.s-f anyway :)
Here it is:
news://news.povray.org/39B59A50.66F1BAA7%40online.no
Tor Olav
Date: 5 Sep 2000 21:29:20
Message: <39B59CA4.BDC6D1E8@online.no>
I like this floor !
Please post another image if you improve it.
> I got tired of waiting and made my own source ;-)
Sorry. I got so excited about Chris' and Xplo's suggestions.
If you look at the source code I just posted,
you will find a comment I made in the code
that shows how to move them a little bit apart.
Tor Olav
Date: 6 Sep 2000 12:59:02
Message: <39B677C7.A9D822DB@merlin.net.au>
> > > standard POV ?
I've done this by saving the image imn ppm format.
Then search/replace space with comma (POV needs commas between values)
and stripping the header except the dimensions (it's handy to leave
these in).
Now you can read it with POV.
PoD.
Date: 7 Sep 2000 17:08:47
Message: <39b803df@news.povray.org>
I like that one Tor. I'm jealous.
Now, if you scale the blobs larger as they move outwards, and increase
distance from center after each blob, pow(radius,??), then this would
be what I would have liked to achieve.  I can do this with spheres but
your antiblobs would give a more realistic result and avoids the
spheres intersecting :)
I must find time to play with your AntiBlob macro.
Alf
Tor Olav Kristensen <tto### [at] onlineno> wrote in message
news:39B44A76.2ECBA98A@online.no...
> Tor Olav
> http://www.crosswinds.net/~tok/tokrays.html
Date: 7 Sep 2000 19:34:52
Message: <39B824DB.21B298CA@online.no>
Thank you. - And I'm glad you are jealous =)
Maybe I need to have a look at your code once
more, because I'm not sure if I understand correctly
what you describe above.
> I can do this with spheres but your antiblobs would give a more
> realistic
> result and avoids the spheres intersecting :)
Have fun !
(The math in this macro may need some adjusting,
and I'll look into that a day when I'm in math-mode. :)
Tor Olav
Date: 7 Sep 2000 20:54:10
Message: <39B83768.BE863064@online.no>
> > > > standard POV ?
> these in).
Can you please tell me where can I find appropriate
information about the ppm format ?
(I.e. Info about structure of the header- and colour-
information.)
And is there any "free" programs that can convert to
this format ?
Tor Olav
Date: 7 Sep 2000 22:15:44
Message: <chrishuff-2AC365.21172907092000@news.povray.org>
In article <39B83768.BE863064@online.no>, Tor Olav Kristensen
> information.)
Try:
http://www.wotsit.org/search.asp?page=8&s=graphics
> this format ?
Free as in price or philosophy?
Free or low in price:
POV-Ray. :-)
GraphicConverter(not free, though nicely priced shareware, Mac only).
I don't know of any others, though that is mostly because I have never
used the format. Programs that use QuickTime can *read* it with no
problem...
Date: 8 Sep 2000 10:41:54
Message: <slrn8rhve5.19a.ron.parker@fwi.com>
>> information.)
>Try:
>> this format ?
>POV-Ray. :-)
>problem...
netpbm, the programs that introduced the format in the first place.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 9 Sep 2000 06:42:30
Message: <39ba1416@news.povray.org>
news:39B824DB.21B298CA@online.no...
increase
would
In my p.t.s-f post replace constant size spheres:
  sphere{ z*Rad, 0.1 rotate y*Count*Inc }
with spheres of increasing size:
  sphere{ z*pow(Rad,1.4), Rad/16+0.055 rotate y*Count*Inc }
( You can delete the blob and bounding sections)
Alf
