Improved the cockpit interior.
Added some sidewinders.
Changed the camo scheme to blue/grey.
Sky background changed (originating from POVRAY package).
Still a lot of work ahead, as you can see !
Just to keep you up-to-date....
Any comments would be nice !
Thx - Jens
Download 'wip.jpg' (116 KB)
Preview of image 'wip.jpg'
> Thx - Jens
It get's better, even though i liked your other plane model more.
The cockpit looks as if the bottom part is missing...
The texture could maybe become more shiny, how about some more geometric
structures on the body/wings (like rims between different parts)
You should name it "fighting plane chasing lonely cylinder" or what does that
shape in front of the plane mean? ;-)
Christoph Hormann <chr### [at] gmx de>
"Christoph Hormann" <Chr### [at] schunter etc tu-bs de> wrote in
message news:39A298AB.1A267BCE@schunter.etc.tu-bs.de...
> > Thx - Jens
that
I assumed it was a wip missile fired by the jet - btw (and this is just a
polite suggestion) it's nice seeing a work slowly come together, but to save
on bandwidth, couldn't you post a smaller image of just the plane, leaving
out the rest of the scene until it's finished?
Ok, but don't forget the other plane was my own design and this
one is a just-for-fun rebuild of an existing one.
Of course I it is nice to hear that you liked my personal design more ! :o)
True, here is still work to do.
Will be a little complicated to achieve a shape similar to the original one.
Cosmetics are for women, not for aircraft.... ;o)
No, you are right.... but this is for later.
Haha, no, this is the pitot probe for stagnation pressure measurement.
It is already there to see which dimensions the plane will finally have
when the nose area is complete.
Thx for comments !
Jens
Yes, Tom, guess you are right.
Will leave the background out in further postings until final image.
Thx 4 the hint !
Jens
Your Sidewinders look awesome!
I know you know this, but... the fuselage needs a tuck where the wing
reaches maximum thickness. Perhaps the "coke bottle" look will come into
being witht he rest of the plane? The perspective makes the pitot tube
appear to be too far out, but who can judge that? :)
I sat in one of these things (F-5 Freedom Fighter actually) at the Air
Museum near the Seattle Space needle (a long time ago). I believe I had a
better view then your helmet position implies ;)
Dropping the background may be going too far in future updates (reflection
mapping will suffer). Perhaps a tad more compression on your jpeg settings?
Grim
the nose of the f5 suddenly disappears.
<knight 1>:"i've lost the nose of my plane!"
<knight 4>:"eject! eject!"
<knight 1>:"i can't! aaaaaaaaa!"
knight 4 can only watch as his friend plummets to a watery death on the
ocean below.
> Thx - Jens
> [Image]
i think the background suggestion posted earlier meant cropping, not
leaving it out altogether. at least, that's what i thought.
Nice progress!
Shouldn't it have blue/gray camo on the bottom (for looking up at it) and
green/brown on the top (for looking down)? The latest planes I think don't
have any, they're just stealth black. (What good is camo on a plane going mach
3 and being looked at by non-visible radiation?) I'm not saying take it off
though, it looks neat. :-)
David Fontaine <dav### [at] faricy net> ICQ 55354965
Please visit my website: http://davidf.faricy.net/
> ocean below.
> > Thx - Jens
> > [Image]
*snicker* Funny story ! :))))))
But imagine it being a snapshot of the first low-tech stealth-plane
during cloaking process...... ;))
Jens
David Fontaine wrote:
> Nice progress!
> and
> don't
> going mach
> it off
Well, yes, the paint scheme......
Hmmm, you must know there are MANY different paint schemes
around the world for this jet. (Check out the little sample below !)
I somewhat chose my own, but I will keep experimenting with
different camo schemes. Btw, over-all flat black or fire red looks also
nice !
Will post some of them here later on...
Stay tuned !
Jens
[Image]
[Image]
Download 'us-ascii' (2 KB)
Download 'c:\windows\temp\nsmail7p.jpeg.jpg' (14 KB)
Download 'c:\windows\temp\nsmailqh.jpeg.jpg' (32 KB)
Preview of image 'c:\windows\temp\nsmail7p.jpeg.jpg'
Preview of image 'c:\windows\temp\nsmailqh.jpeg.jpg'
I'm happy you like 'em ! :)
It is funny, because I spent just about a quarter of an hour
designing them (no joke !). All I had was a small image in a book
and my great "golden thumb rule". ;)
I already thought about that....of course, the "area rule" should be
applied
correctly like on the original plane. Maybe later...?
BTW: Do you know the F-20 (F-5G) Tigershark, a further development
of its predecessor, the F-5E ? It was an excellent aircraft but
did not reach series production. It had just one engine, but that one
was even more powerful than the two engines of the 5E. The "coke-bottle-
slender-effect" (or better "area rule") is used to reduce drag in
supersonic flight regime (for example, take a look at the Convair F-104
and F-106 ! Same thing. If you have sufficient engine
power mounted, you don't need to apply the area rule. That simplifies
construction, too !
Maybe I should convert the plane into the single-engine F-20 to avoid
application of the area rule !? ;)
No, it is all right there. You are positive: It is just due to the
perspective.
Imagine there are small pilots, too !
(Even if they believe they're big...eheh !)
Acknowledged, sir ! ;)))
Jens
> also nice !
You should match it to whatever background you have in the end. Either
ocean or vast farmland should be doable in POV, mostly flat... and no
placing the horizon below the camera's field of view! :-)
I've flown R/C versions. There's a new kit coming out of Australia very
soon!
There were a few other versions, including a swept forward wing design. I do
not care for these planes, as they put a computer between pilot and
aircraft. That is not a bad thing, but I still don't like it. I'm funny that
way. :)
Grim
off
Actually, camo is essential to this airplanes survival. It is not a high
dollar fighter. It has to get in close to use its weapons. Most combat
maneuvering occurs down at about 350-425mph (corner velocity) and the turn
circle is still rather large at that speed. The F5 has to force its opponent
to lose sight of him, so he can maneuver for the kill. Since this plane is
deployed at forward fields it also uses camo to disguise its position. Don't
want to get your plane strafed! :)
Grim
