POV-Ray : Newsgroups : povray.binaries.images : Wooden Isosurfaces (145k) Server Time
24 Nov 2026 10:18:52 EST (-0500)
  Wooden Isosurfaces (145k) (Message 1 to 17 of 17)
Subject: Wooden Isosurfaces (145k)
Date: 16 Aug 2000 16:36:13
Message: <399AFB5F.66433228@schunter.etc.tu-bs.de>
Nearly everything is isosurfaces here, i am still working on the structure of
the wood, it is quite to clean right now.
Radiosity made everything very red, i also made a version without it that is
available here:
http://www.schunter.etc.tu-bs.de/~chris/wood_02.jpg
Comments and suggestions welcome.
Download 'wood_01.jpg' (145 KB)
Preview of image 'wood_01.jpg'
Subject: Re: Wooden Isosurfaces (145k)
Date: 16 Aug 2000 17:43:59
Message: <399B0918.1AF6BED2@faricy.net>
Wow, I am impressed! It must have taken a lot of patience to get this far.
David Fontaine   <dav### [at] faricynet>   ICQ 55354965
Please visit my website:  http://davidf.faricy.net/
Date: 16 Aug 2000 21:08:40
Message: <399B3A58.4C3ACB08@attglobal.net>
Wow!  That's all I have to say.  I hope once you feel this is finished,
you'll share the code (or at least some pointers).
Francois Labreque | It is by caffeine alone I set my mind in motion, it
     flabreq      | is by the beans of Java that thoughts acquire speed,
        @         | the hands acquire shaking, the shaking becomes a
  attglobal.net   | warning, it is by caffeine alone I set my mind in
motion.
                               - Stolen from Badger's .sig file
Date: 16 Aug 2000 21:59:44
Message: <399A06D4.2C2260C3@earthlink.net>
Radiosity looks much better...
> available here:
> Christoph
> Homepage: http://www.schunter.etc.tu-bs.de/~chris/
Date: 16 Aug 2000 22:10:35
Message: <399B5A96.724884FF@osu.edu>
The wood on the wall is great. especially closer to the light. I'm not
sure what the checkered board is supposed to be, but it looks nice too
ross
Date: 17 Aug 2000 01:24:53
Message: <399B7723.7CB44DE3@aol.com>
The three boards holding up the chess board would make great railroad
ties.  The planks on the wall look like rough hewn hardwood in the
radiosity version and more like driftwood or weathered cedar (though a
bit dark for that) in the non-rad image.  The item on top of the
chessboard, though I'm not sure what it's supposed to be, looks like
it's carved from cherry or rosewood
Anyway, great stuff.
-Mike
Date: 17 Aug 2000 04:34:21
Message: <399BA3AF.4CB76B66@schunter.etc.tu-bs.de>
I think so too, even though i will probably try to turn it down, using some
darker textures for the walls behind the camera.
Date: 17 Aug 2000 04:38:40
Message: <399BA4B1.E5E57984@schunter.etc.tu-bs.de>
Thanks.
Well, in fact most things in the scene are quite similar, composition was mainly
accidental playing around with different things.
Date: 17 Aug 2000 04:45:10
Message: <399BA638.A704A364@schunter.etc.tu-bs.de>
Thanks, it's a real mess right now (and i really mean a mess) so i will have to
clean things up a bit first.  You should really *never* start naming your
pigments P_A and P_B, because those things will lead to much confusion very soon
Maybe i can make some usable macro for those wooden planks...
Date: 17 Aug 2000 04:49:56
Message: <399BA754.E07828CC@schunter.etc.tu-bs.de>
Thanks,
it started with a chess board (even though i did not care about the number of
fields) and then i decided to rotate it 45 deg :-)
Date: 17 Aug 2000 04:57:34
Message: <399BA91F.4DFA1CC2@schunter.etc.tu-bs.de>
> ties.
I also thought that, but they are much to clean and regular for that, no
railroad company could afford that nice planks :-)
Right now i'm mostly using the wood color maps coming with povray.
Subject: SV: Wooden Isosurfaces (145k)
Date: 17 Aug 2000 07:14:44
Message: <399bc924@news.povray.org>
do you make up these textures yourself?
the wall texture is great!
Peter
http://hertel.no/bigone
Subject: Re: SV: Wooden Isosurfaces (145k)
Date: 17 Aug 2000 12:09:02
Message: <399C0E42.E0B1C546@schunter.etc.tu-bs.de>
Thanks, the effects are caused by both texture and isosurface,  I wrote them
myself, even though i somehow sticked to the standard wood textures.  Most color
maps are those included in Pov.
Date: 17 Aug 2000 17:21:27
Message: <399c5757@news.povray.org>
"Mike" <Ama### [at] aolcom> wrote in message
news:399B7723.7CB44DE3@aol.com...
.......The item on top of the
> -Mike
    Hi, Mike.  I believe that there was actually a gold ring made this way
in the late seventies, in production. The idea being that the different
'holes' were different finger sizes, evidently wearable, but I haven't tried
it!
   This is the only time that I have seen this.
        ~Steve~
Date: 17 Aug 2000 17:34:27
Message: <399C5A89.38E31851@schunter.etc.tu-bs.de>
> it!
>         ~Steve~
BTW it's a "func_5" isosurface (if you like to model it in gold :-) but it's
probably difficult to model different sized holes ...
Date: 17 Aug 2000 22:02:30
Message: <slrn8pp00k.s5.steve@zero-pps.localdomain>
This looks really good.
I've got to fix the gamma on this machine. In fact I think I'll do
it now.
 12:29am  up 4 min,  2 users,  load average: 1.24, 0.94, 0.42
Date: 21 Aug 2000 08:35:07
Message: <39a121fa@news.povray.org>
I have a macro that lays out planks pseudo-randomly to create a floor of
wooden planks, given max/min lengths and so on.  Right now it takes two
textures, the wood texture and the grout texture (between the wood planks).
I'm not entirely happy with it, as it's not intelligent about placing wood
ends (if it were a real wood floor there would be no ends close on two rows
of planks, and there would be places no edges were near where the baseboards
run) but I'd be happy to share if it means I get a look at your iso code. ;)
Geoff
