POV-Ray : Newsgroups : povray.binaries.images : HF problems Server Time
24 Nov 2026 10:18:51 EST (-0500)
  HF problems (Message 1 to 16 of 16)
Subject: HF problems
Date: 15 Aug 2000 08:05:58
Message: <39993F1A.D8C74DF8@ss.com>
I remember having seen a message regarding this problems already, but
can't seem to find it.
Just look at the image - why can't a make a smooth HF?!!
Download 'nland.jpg' (25 KB)
Preview of image 'nland.jpg'
Subject: Re: HF problems
Date: 15 Aug 2000 08:14:31
Message: <39994125.E90EA96B@ss.com>
BTW the resolution is not the problem - it's 2000 * 2000...
Date: 15 Aug 2000 08:29:56
Message: <399937DA.8851B5F9@kivisalo.net>
This must be 8bit hf, try 16bit tga.
______________________________________________________________________
Kari Kivisalo                                  http://www.kivisalo.net
Date: 15 Aug 2000 08:46:19
Message: <39994891.DAC8B978@ss.com>
I am having trouble creating the HF as a 16-bit grayscale. It has 256
colors (8 bits) but I can't get more for some reason. How do I ??
Lewis wrote:
> It's already a 24-bit tga. What, then?
Date: 15 Aug 2000 08:54:26
Message: <39993d82$1@news.povray.org>
"Lewis" <tt### [at] sscom> wrote in message news:39994891.DAC8B978@ss.com...
Since you have a 24 bit targa there the thing to do probably is to use it as
a pigment {image_map{}} and do a global_settings {hf_grey_16 on} to get it's
16 bit greyscale.  Only problem might be if it's not already a greyscale
image the conversion of the colors just might go wrong for what you have
intended, but I'm not sure of that.
Anyway, if you're willing to go that route then just use a orthogonal camera
with the same up and right as the image resolution, mapping to a plane of
course.  Also set the file output type to +FT so you don't get a BMP or
something.
Date: 15 Aug 2000 08:58:40
Message: <39994B78.B3D6F7BA@ss.com>
I'm just trying that right now, but for some reason the scene is
completely black.
I have absolutely no idea why. It's a time like this when I make stupid
mistakes which stall me for hours, when I forget something very, very,
simple.
Help!
global_settings
  hf_gray_16
  ini_option "+FT"
camera
	orthographic
  location  <0.0, 5, .0>
  look_at   <0.0, -1.0,  0.0>
plane
  y, // <X Y Z> unit surface normal, vector points "away from surface"
  -1.0 // distance from the origin in the direction of the surface
normal
  hollow on // has an inside pigment?
    texture
         pigment
            image_map
              png   "D:\Noam\POV-Ray for Windows
v3.1\scenes\nLand\nlandhf.png"
               interpolate 4
         finish
           ambient 1
> something.
> Bob
Date: 15 Aug 2000 09:01:05
Message: <39993F32.CE2D2889@schunter.etc.tu-bs.de>
As Bob said, you should use "hf_grey_16 on" when generating the heightfield with
Povray. With png output, you have to use +fn16 to get 16 Bit grayscale output.
IIRC the black parts in the heightfield are a known problem, there were some
posts about that in the past:
from p.a-u:
Topic: Height field bug?
Date:  Fri, 28 Apr 2000 23:00:46
from p.b.i:
Topic: height field problem - 2-11K jpegs
Date:  Wed, 31 May 2000 21:33:19
Subject: argghhh
Date: 15 Aug 2000 09:08:20
Message: <39994DC2.F49691A2@ss.com>
Help....
The only clue i have is that It seems that POV is ignoring the
global_settings, for some reason
Date: 15 Aug 2000 09:09:34
Message: <39994130.350E3764@schunter.etc.tu-bs.de>
> completely black.
> simple.
> Help!
Try this one:
#version unofficial MegaPov 0.5;
global_settings
  hf_gray_16
  ini_option "+FT"
  ini_option "-w256"   // change this
  ini_option "-h256"
camera
        orthographic
  look_at   <0.0, 0.0,  0.0>
  right 1*x
plane
  y,
  -1.0
    texture
         pigment
            image_map
              png "g:\ray\maps\river_01.png"  // change this
              once
              interpolate 4
         finish
           ambient 1
         rotate 90*x
         translate <-0.5, 0, -0.5>
Subject: NEW HF problems
Date: 15 Aug 2000 09:24:03
Message: <39995164.8BA17532@ss.com>
Thanks, it works.
However, I still can't understand what's the problem with MY source.
Further more, this is what comes out when I try to use that output in
the HF scene:
Download 'nland.jpg' (10 KB)
Subject: forget it!
Date: 15 Aug 2000 09:30:37
Message: <399952F3.3B89E41B@ss.com>
It was the wrong file. Thanks for all the help.
Lewis wrote:
> Thanks, it works.
> the HF scene:
Date: 15 Aug 2000 17:56:15
Message: <slrn8pjdi5.h95.steve@zero-pps.localdomain>
Don't know what you're doing over there Lewis but your posts are in some
strange format, I have to run them through MetaMail before viewing, but
the post with the image in it didn't have that problem.  Maybe it's the
character set that you're using or something like that.
  8:37pm  up 31 days, 19:04,  2 users,  load average: 1.04, 1.29, 1.24
Date: 16 Aug 2000 01:53:04
Message: <m0bkpssfr2a7psmc3aujifp44jnnqa4ol5@4ax.com>
On 15 Aug 2000 17:56:15 -0400, ste### [at] zeroppsuklinuxnet (Steve)
X-Accept-Language: en,x-ns1lnmOdH2gNhQ,x-ns2r2f09OnmPe2
Content-Type: text/plain; charset=x-user-defined
What the heck could these mean??? Anyway, I think this answers your
question.
Peter Popov ICQ : 15002700
Date: 16 Aug 2000 02:44:30
Message: <399a384e@news.povray.org>
No problems on this end. I think Lewis is in Israel? OE interpreted it
correctly. ;)
Grim
> question.
> Personal e-mail : pet### [at] usanet
> TAG      e-mail : pet### [at] tagpovrayorg
Date: 16 Aug 2000 14:55:21
Message: <399AF08C.2F72E7C2@ss.com>
Grimdude is RIGHT!
> correctly. ;)
> Grim
> > question.
Date: 16 Aug 2000 18:37:39
Message: <9q5mps41tocv06vk1809mallfhak0qgf6c@4ax.com>
On Wed, 16 Aug 2000 01:59:00 -0500, "GrimDude" <vos### [at] yahoocom>
>correctly. ;)
I don't have a problem either but I think Steve is using some kind of
Unix and probably doesn't have Hebrew support. Of course he doesn't
need it to read Lewis' posts as they are in plain English but Lewis'
newsreader seems to be thinking differently :)
And then of course I could be all wrong, as more and more often
happens (age?).
