POV-Ray : Newsgroups : povray.binaries.images : 7-'sided' Mobius-ring Server Time
23 Sep 2025 01:23:33 EDT (-0400)
  7-'sided' Mobius-ring (Message 1 to 7 of 7)
Subject: 7-'sided' Mobius-ring
Date: 11 Aug 2000 17:37:59
Message: <39947237@news.povray.org>
Well, actually of course it has only one side :-)
Saying 7-edged mobius ring isn't correct either, since it has also only 1
edge...
How do you call this?
A mobius-ring with a 7-sided cross-section?
ZK
http://www.povplace.be.tf
Download 'while-PP1.jpg' (55 KB)
Preview of image 'while-PP1.jpg'
Subject: Re: 7-'sided' Mobius-ring
Date: 11 Aug 2000 17:58:44
Message: <39947515.29E41607@faricy.net>
> edge...
Sure.
Nice pic (I see you used focal blur :).
And since 7 is a prime number, it will always have 1 side unless it is
twisted by a multiple of 360..
Date: 11 Aug 2000 18:03:32
Message: <39947834@news.povray.org>
> Sure.
Tnx.
I used PP-focal blur and softglow.
You mean an it wouldn't be the case with an even number?
Are you sure?
Hmmm...
Maybe...
Don't know... :-)
ZK
Date: 11 Aug 2000 19:27:32
Message: <399489E2.5894E34F@faricy.net>
> Are you sure?
> Hmmm...
> Maybe...
> Don't know... :-)
Yes, I'm sure :-)
For example, if a 7-sided strip twists by 1/7 of 360 degrees every time
around (as your does it looks like), it will go from row 1 to row 2 to row 3
and so on back around to 1, giving a sequence of 1234567. If it twists 2/7
of 360, it has a pattern of 1357246. You can easily figure out the other
sequences if you like.
Now, with a six-sided one, you can rotate it 60 degrees every revolution
which yields 123456, or 120, which gives two sides: 135 & 246, or 180, which
gives 14 & 25 & 36...
The key is, does the numerator, or the modulo of the numerator and the
denominator, divide into the number of sides of the cross-section.
Date: 12 Aug 2000 05:07:35
Message: <399513d7$1@news.povray.org>
> Yes, I'm sure :-)
OK, if you say so :-)
3
Mine twists 2/7 of 360 degrees, but I don't think that's really important,
is it?
It still has one side, right?
(Please! :-)
Ah, that's a 'right'-answer... isn't it? :-)
which
interesting...
Really!
ZK
Date: 12 Aug 2000 05:54:00
Message: <39951eb7@news.povray.org>
David Fontaine <dav### [at] faricynet> wrote:
: And since 7 is a prime number, it will always have 1 side unless it is
: twisted by a multiple of 360..
  And this holds for every prime number.
  Now, this is an interesting idea: Get a really big prime number and make
a moebius which cross-section has that many sides. It will look like it has
lots of sides and still it will have only one (unless you twist by a multiple
of 360...).
Date: 12 Aug 2000 10:09:05
Message: <39955a81@news.povray.org>
Warp <war### [at] tagpovrayorg> schreef in berichtnieuws
39951eb7@news.povray.org...
has
multiple
> of 360...).
Actually, I think it will look like an ordinary torus :-)
ZK
