POV-Ray : Newsgroups : povray.binaries.images : Test Rendering : The Vases Improved Server Time
24 Oct 2026 20:17:18 EDT (-0400)
  Test Rendering : The Vases Improved (Message 1 to 18 of 18)
Subject: Test Rendering : The Vases Improved
Date: 10 Aug 2000 13:06:41
Message: <3992E108.D6CDEE46@umh.ac.be>
I have improve a bit the bootom part of the pic. There are still
room for improvment but as this is only tests :).
Comment are welcome (this help a lot) :).
Fabian.
Download 'vase_all2.jpg' (131 KB)
Preview of image 'vase_all2.jpg'
Subject: Re: Test Rendering : The Vases Improved
Date: 10 Aug 2000 13:53:18
Message: <3992EC2A.8C66FD7@schunter.etc.tu-bs.de>
looks much better now, maybe you could round the bottom rim of the vases a bit
more.
If i see it right, you are using a normal statement for the wood structure.  If
you would use a heightfield/isosurface, it would improve things even more,
because you could see the shadows of the vases interfering with the wood's
surface.  Right now, it looks like the red one is to much sticking to the
plank.
Date: 10 Aug 2000 16:36:12
Message: <3993122D.9F3B42CA@spiritone.com>
How did you make the wood? I think the reason why the vases look like they
were photoshopped in is because the surfaceof the wood meets the vase in a
simple curve, so the wood suddenly has to be flat. I really really love these
textures.
Josh
> Fabian.
eng### [at] spiritonecom
Date: 10 Aug 2000 16:47:35
Message: <399314e7@news.povray.org>
The wood looks a little better, but I still think procedural wood would look
somewhat better. I like the rust colored vase the best. These would look
nice in an outdoor garden scene; they look nice and weathered.
HH
"Fabian BRAU" <Fab### [at] umhacbe> wrote in message
news:3992E108.D6CDEE46@umh.ac.be...
> Fabian.
Date: 10 Aug 2000 17:35:01
Message: <chrishuff-ECB3DA.16360710082000@news.povray.org>
In article <3992E108.D6CDEE46@umh.ac.be>, Fabian BRAU
I think the problem is that the lighting on the image you are using in
your image_map is different from the lighting on the vases...it really
doesn't look right. Try a procedural wood texture, that way the lighting
and shadows are always correct, and you don't end up with as much as a
"faked" look.
Date: 11 Aug 2000 03:37:22
Message: <3993AD1D.A94DF85C@umh.ac.be>
> somewhat better.
Show me good procedurial wood! I never see good one. Even from
Gilles Tran, Jaime Vives Piqueres etc.... :).
Fabian.
Date: 11 Aug 2000 03:39:09
Message: <3993AD88.2032B237@umh.ac.be>
> more.
As this is test rendering and not scene I will not do it :).
Actually the purpose of these pictures was to put texture on non so
trivial
object (need uv mapping here etc...) and see if there were good, it's
all.
Fabian.
Date: 11 Aug 2000 03:40:33
Message: <3993ADDC.EA0B3F81@umh.ac.be>
> doesn't look right.
There is only image map in this scene :).
> "faked" look.
Procedurial wood look always fake :).
Fabian.
> Christopher James Huff - Personal e-mail: chr### [at] maccom
> TAG(Technical Assistance Group) e-mail: chr### [at] tagpovrayorg
> Personal Web page: http://homepage.mac.com/chrishuff/
> TAG Web page: http://tag.povray.org/
Date: 11 Aug 2000 03:49:56
Message: <3993B00E.58506BA5@umh.ac.be>
Image map + bump map. And rework with photoshop.
This is a well known problem with povray : normals!
In other soft you can use displacement map and you have real
elevation, just by using the bump map. With povray, this is
more tricky because you need isosurface or heightfield. Which
is more difficult. I already saw some attempt to create wood
with hieghtfield, the result was more or less good but it took
several weeks for the guy to get a "good" result so...
With a displacement map it take you no more time that with the
present bump map.
Fabian.
> textures.
Thanks a lot. This was just the purpose of these images :
test texture :).
Fabian.
> Josh
> > Fabian.
> >  [Image]
> Josh English -- Lexiphanic Lethomaniac
> The POV-Ray Cyclopedia http://www.spiritone.com/~english/cyclopedia/
Date: 11 Aug 2000 06:42:34
Message: <3993d89a@news.povray.org>
this looks a lot better (if fact the wood floor tex is damn nice!), but it
still seems disjointed, however that maybe because we are all now looking
for problems at the base of the vase's (and are unlikely to ever be happy!)
Date: 11 Aug 2000 11:35:18
Message: <39941C4E.C2C82AA1@inapg.inra.fr>
But does displacement mapping solves the problem of having a good displacement map
in the first place ?
For me the main problem in using isosurfaces for displacement mapping in Megapov
is that it is restricted to what isosurfaces can do. For instance, using it on CSG
is not straigthforward, if not impossible. The second problem is that it's not
fast. Otherwise it's not that complicated.
Below is a setup for a floor with displacement mapping in Megapov (equivalent to a
height field).
#declare hf=function{pigment{image_map{png "floorbump" interpolate 2} rotate
x*90}}
#declare rs=0.005;
isosurface{function{y - hf(x,y,z)*rs } contained_by{box{<-2,-1,-1>,<2,1,2>}}
threshold 0    rotate x*-90
        texture{pigment{image_map{png "floormap"}} finish{ambient 0 diffuse 0.8
specular 0.2 roughness 0.1} rotate x*90 }
And a picture here (uses official focal blur, official caustics, a big image map
for the texture and another big one for the displacement).
Download 'parquet.jpg' (30 KB)
Preview of image 'parquet.jpg'
Date: 11 Aug 2000 11:47:35
Message: <39942034.6E8B59D7@schunter.etc.tu-bs.de>
If i see it right your sample is similar to the heightfield solution.  The
obvious starting point would be to take the image map used for the texture and
try to get a reasonable corresponding heightfield/isosurface map using filter
functions.
heightfields should be a lot faster than isosurfaces in many cases, but of
course they are not that flexible.
Date: 11 Aug 2000 11:57:06
Message: <3994223D.6503C21A@umh.ac.be>
Exactly!! I forgot that we can use image map in iso surface :).
But yes this slow but feasible!
I will have a look!
Fabian.
> height field).
> x*90}}
> #declare rs=0.005;
Date: 11 Aug 2000 12:36:24
Message: <39942AA0.9A020D6A@inapg.inra.fr>
> functions.
Which exactly what I did here. The map was desaturated, and then I made a copy of it.
On
this one I painted the planks white, leaving only the gaps black. I gaussian-blurred
it
and then added this map to the previous map.
Heightfields are surely faster in the case of  flat objects. I rendered the previous
picture with a height field instead of an isosurface and it rendered 5 times faster
for
an identical output (no need to post it !).
Their main problem is that they are not tileable (unless you make copies of them and
stitch them together) while an isosurface can be of any size.
G.
Date: 11 Aug 2000 15:09:58
Message: <39944E49.182E57E7@skynet.be>
for
 And they consume much more memory, and have a finite resolution, while
isosurfaces can have infinite resolution (with precedural displacement).
 Happily, both exists !  Twice the fun !
Fabien.
Date: 11 Aug 2000 16:03:36
Message: <slrn8p8li6.2j3.steve@zero-pps.localdomain>
What's going on here?  The pots seem to come out of the picture like
one of them 3D glasses things.  Has a chillingly realistic feel to it
but something in there lookks very flat at the same time, gives me a
slight feeling of vertigo.
  6:14pm  up 27 days, 16:41,  2 users,  load average: 1.08, 1.02, 1.02
Date: 12 Aug 2000 00:07:35
Message: <chrishuff-F428CA.23084211082000@news.povray.org>
In article <3993ADDC.EA0B3F81@umh.ac.be>, Fabian BRAU
Yes, but the map is tiled over the vases, right? It isn't a single image
wrapped over the vase. So lighting can affect it as it normally would.
However, it looks like much of the "lighting" effect on the wood is part
of the image_map.
Not always...I have seen some very convincing wood textures, some which
you really couldn't tell from real wood. And no offense, but even many
of the less convincing ones looked better than this. There is a very
noticeable discontinuity between the bases of the vases and the wood
texture.
Date: 17 Aug 2000 03:10:38
Message: <399B8FD7.B152FEB0@umh.ac.be>
No problem, I wait your art ...
