POV-Ray : Newsgroups : povray.binaries.images : Test Rendering : The Vases (3) Server Time
14 Mar 2026 17:12:15 EDT (-0400)
  Test Rendering : The Vases (3) (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: Test Rendering : The Vases (3)
Date: 9 Aug 2000 19:44:45
Message: <01c0025b$c5453320$817889d0@daysix>
| Actually, the rendered procedural-textured vase look more real than the
| image_map floor.
| Great work ! How did you design them ?
Umm.. Dude, those aren't procedural textures.  If you look close, you can
see the pattern start to repeat.
Still, these are very nice.  The might benefit from some radiosity, though.
H.E. Day
Date: 10 Aug 2000 00:03:48
Message: <399229a4@news.povray.org>
Fabian BRAU <Fab### [at] umhacbe> wrote...
> The bottom of the picture is not good so just look
> the upper part :).
Nice use of image maps, though the image map on the table is what causes the
strange look.  The problem is that the image map has some lighting "built
in" to the photograph (light coming straight down from the top), and that
lighting does not correspond to the true lighting in the scene (light coming
more from the side).
Anyway, I was wondering if you used 'real' or post-processed focal blur?
-Nathan
Date: 10 Aug 2000 04:36:09
Message: <3992695E.711FBD48@umh.ac.be>
Actually, repetition are more visible on the stone vase but this is due
to
a mistake from me :).
I use radiosity though. But nothing is really perfect in this world :).
Fabian.
> H.E. Day
Date: 10 Aug 2000 04:38:54
Message: <39926A08.903080F0@umh.ac.be>
You are right and I know this, this is why I say to look the upper part
I will perhaps do another with real model of plank with each one with
its
own texture. This would noramlly be better.
Post-processed focal blur.
Fabian.
> -Nathan
Date: 10 Aug 2000 04:50:36
Message: <slrn8p3qr4.ura.steve@zero-pps.localdomain>
These are sweet.  I did a coffee cup texture like one of these
a while back, but never finished the sceen (or the macro).
 12:04am  up 25 days, 22:30,  2 users,  load average: 1.21, 1.10, 1.02
Date: 10 Aug 2000 05:00:49
Message: <39926F2A.FE36C44@umh.ac.be>
Hello All,
Thanks for your comment.
For the textures, I use a "new" (at least for me) method
which mix procedurial and image_map. In this way, if
you don't make mistake :), you cannot see repeating pattern.
The adventage is that you aren't obliged to use huge image_map.
This doesn't work with all image_map, it depend on the kind of
pattern on the image, but it work great for most.
You want the method?
It seems I can hear yes ;).
This is very simple and I suppose I am not the first to
experiment it. Many variant are possible and perhaps some
of you will improve it (this is why I give you the method ;)).
You make a layer texture:
1) on the first layer you put the image_map (well corrected
   in photoshop etc...), the normal (bump_map which is just
   the same picture but in grey scale and with much more
   contrast) and the finish.
2) on the second layer you make a pigment map, you can use
   what you want as pattern with turbulence or not (but if
   there is turbulence, you need reset children, thank Nathan!).
   Here I use two entries. For the first entry you put a simple
   color rgbt 1.0. For the second entry you put the same image
   map, with normal (bump_map). And finally you add the finish.
I think it's all :). Pretty simple.
In the beginning, I though about that to make some roughcast-like
texture, with some part which are gone etc... But it works for
other kind of texture too :).
Some of the image_map are found on internet, the others are
photos made by me. Simply go to the link part of the povray site
to have good links to really good textures. Some are seamless,
others need to be processed (if you need explication, this
will come on the GenOrb site http://www.genorb.be.tf. But I am
sure that with Altavista you can find this information on
the web). But in all case you need to improve their histogram into
photoshop (thanks Gilles).
Fabian.
> the upper part :).
> Fabian.
Date: 10 Aug 2000 05:13:20
Message: <3992737B.82223966@home.com>
The textures are wonderful one little nitpick.....    Are they suposed to
looke like carved granite or clay??
> the upper part :).
> Fabian.
Date: 10 Aug 2000 05:42:55
Message: <3992791f@news.povray.org>
I haven't seen a vase rendering this good since the 3 oval shaped and glazed
vases someone did long ago standing amidst ground fog on cubic stands (here,
at AOL graphic libraries, someplace).  Had you done likewise I think this
would be incredibly life-like.  Well, still-life life-like, ha ha.  A small
gap between boards and bottoms of these would do good I think too.  It's
that fuzzy/sharpness contrast that distracts.
Actually, it's not that the others were so real as they were artistic and
were done with what was new back then, POV-Ray 3.0.
Date: 10 Aug 2000 11:54:46
Message: <MPG.13fcee1d5f6e1953989681@news.povray.org>
[This followup was posted to povray.binaries.images and a copy was sent
to the cited author.]
In article <39917CB2.188324C5@umh.ac.be>, Fab### [at] umhacbe says...
> the upper part :).
> Fabian.
> [image/jpeg]
Very nice wood texture!
j/k out of jealousy. Extremely impressing vases!
Regards,  Sander
Date: 10 Aug 2000 16:04:47
Message: <39930adf@news.povray.org>
hoe do you do it ? make wonderful vases that don't appear to touch the
ground :)
