POV-Ray : Newsgroups : povray.binaries.images : Strange media effect. (20kbu) Server Time
24 Nov 2026 10:47:04 EST (-0500)
  Strange media effect. (20kbu) (Message 1 to 15 of 15)
Subject: Strange media effect. (20kbu)
Date: 3 Aug 2000 03:59:00
Message: <39892644@news.povray.org>
I was trying to get a fog-like effect with media, unfortunatly
I got the following picture. I thought initially that there was a non-hollow
object interfearing with the media, fog type 2 (ground fog) works fine.
The media container is definatly hollow.
The second picture is the same scene using fog type 2. That is what I want
to get with media
I've been fighting with this for two weeks now and I'm out of
ideas. I've posted the source for the simplified scene in p.b.s-f
If anyone can tell me what the problem is, I will be very grateful.
(Bill I have a feeling I'll need one of your signs)
Thanks
Gail
* gsh### [at] monotixcoza              * Reality.dat not found         *
* http://www.rucus.ru.ac.za/~gail/ * Attempting to reboot universe *
* The best way to accelerate Windows NT is at 9.8 m/s^2      *
Download 'StrangeMedia.jpg' (13 KB) Download 'WithFog.jpg' (8 KB)
Preview of image 'StrangeMedia.jpg'
Preview of image 'WithFog.jpg'
Subject: Re: Strange media effect. (20kbu)
Date: 3 Aug 2000 05:02:51
Message: <3989353b@news.povray.org>
Your problem lies in trying to get absorption, emission and scattering all
in the same media statement. You need to declare each media type separately
within the interior statement. I've listed out below how to get it to work.
BTW, having all three really slows things down. I'd use emission for test
purposes and then try different combinations of the three to get a final
effect.
David
#declare Final=1;
// ground fog
#if (Final=0)
 fog {
  fog_type   2
  distance   0.3
  color      rgb 0.7 // gray
  fog_offset -0.7
  fog_alt    0.15
  turbulence 1.5
  turb_depth 0.8
#else
 box
  <-15,-3,-15>,<15,-0.3,45>
  pigment { rgbf 1 }
  hollow
  interior {
   media {
    absorption 0.7
    method 3
    density {
     bozo
     density_map {
      [0 rgb 1]
      [1 rgb 1]
   media {
    emission 0.7
    method 3
    density {
     bozo
     density_map {
      [0 rgb 1]
      [1 rgb 1]
   media {
    scattering {2, rgb<.25,.25,.25> extinction 1 }
    intervals 1 samples 1
    confidence 0.8 variance 1/32
    method 3
    density {
     gradient y
     color_map {
      [0 rgb 1]
      [1 rgb 1]
Date: 3 Aug 2000 16:46:20
Message: <3989D9F9.F910706@yahoo.com>
wasn't there a section in the docs about multiple media and multiple
density?  does this apply here?  is that what the problem was?
Date: 3 Aug 2000 17:10:35
Message: <nu0jos4spbijc1m8ogvvsioqn53tnb8200@4ax.com>
On Thu, 3 Aug 2000 00:55:03 -0800, "David Heys" <sou### [at] gcinet>
Using emission, absorption and scattering in a single media statement
is perfectly legal. However, they will share the same density which
will render them rather useless (unless the density is totally
unsaturated, color-wise).
Only true a) for scattering and b) for separate media statements.
Peter Popov ICQ : 15002700
Date: 3 Aug 2000 17:10:36
Message: <961josgklq8m3mv5ahg1qqaut1aqubdno1@4ax.com>
On Thu, 3 Aug 2000 09:57:33 +0200, "Gail Shaw" <gsh### [at] monotixcoza>
Looks like there're too few samples. Try starting with 5 or 10 and
then use anti-aliasing along the way.
Date: 4 Aug 2000 03:16:23
Message: <398a6dc7@news.povray.org>
Peter Popov wrote in message <961josgklq8m3mv5ahg1qqaut1aqubdno1@4ax.com>...
I feel really dumb now.
<rereads mega documentation> Mega creates extra intervals not
extra samples.
I had an odd idea that only one sample was needed and more would be created
as necessary.
Thanks for the help Peter. Pic looks a lot better now.
Gail
Date: 4 Aug 2000 05:20:55
Message: <gf2los4rl7a8mldaih4s1ec8ksnligkj8g@4ax.com>
On Fri, 4 Aug 2000 09:14:59 +0200, "Gail Shaw" <gsh### [at] monotixcoza>
I would let you have my sign but I need it as I've made the same
mistake a couple of weeks ago. It was more obvious in my case, though.
>as necessary.
That's how antialiasing works. However, in order to be able to get a
sample in-between two others, MegaPOV will need, well, at least two
others :)
Date: 4 Aug 2000 05:47:47
Message: <398A9141.210183CE@iname.com>
> others :)
	Actually, if you tell it to use only one or two samples
with method 3, it will take three and work from there...
		Jerome
******************************* Jérôme M. BERGER
Date: 4 Aug 2000 05:48:52
Message: <398A9182.66C040B7@iname.com>
> to get with media
> Thanks
	What version of MegaPov where you using?
		Jerome
Date: 4 Aug 2000 06:03:15
Message: <398a94e3@news.povray.org>
Jerome M. Berger wrote in message <398A9182.66C040B7@iname.com>...
0.5a
Works fine now that I put the samples to 10.
Gail
Date: 4 Aug 2000 11:34:47
Message: <sfolos4b3kcegrup6625evss9pur1vnso9@4ax.com>
On Fri, 04 Aug 2000 11:47:45 +0200, "Jerome M. Berger"
I don't recall reading this in the docs so you must be speaking from
your knowledge of the source. This means your words are true :)
Date: 4 Aug 2000 11:44:25
Message: <398AE4D8.198B41D5@iname.com>
	It's not in the doc and I am speaking from my knowledge of
the source :) OTOH I haven't looked at it for some time so I
may not rember right (I'm not sure whether it takes at least
3 samples or at least 2, I think it's 3 but...)
		Jerome
Date: 4 Aug 2000 17:39:42
Message: <gmdmos03tuloe4eiao353cf8nb9h7qgkds@4ax.com>
On Fri, 04 Aug 2000 17:44:24 +0200, "Jerome M. Berger"
I would vote for two. My arguments? Well, I've noticed that this
behaviour when I was making an orb with a turbulated spherical density
and pretty cranked up AA settings. When setting the samples to 1
(initially) it looked like, well, crap. Now, if three samples were
used (and only one interval as was the case), then the first and last
would be at the edges of the container object and the second would
fall somewhere in the midst of it. With spherical density this would
result in a great difference between the samples and anti-aliasing
would kick in. This was not the case. OTOH, if only two were used then
they would be situated near the edges of the container object and in
the general case would hit a density of 0 (we don't want out media to
go beyond our container, do we?) and anti-aliasing would not play its
part. So I would vote for two.
Date: 7 Aug 2000 05:58:08
Message: <398E882F.845D7C22@iname.com>
	Well, I just checked and the answer is three: one at each
end and one in the middle to determine if supersampling is
needed...
		Jerome
Date: 7 Aug 2000 17:33:24
Message: <aoauos4ma3v9ppr82555gu75t1jnkgh1k3@4ax.com>
On Mon, 07 Aug 2000 11:58:07 +0200, "Jerome M. Berger"
>needed...
Odd indeed... why does a simple spherical media look like s**t with
samples set to 1 then?
Hold on, that was in MP 0.5, and Nathan does mention something about
fixing a bug related to samples being equal to 1. I'll have to play
with it and see.
