POV-Ray : Newsgroups : povray.binaries.images : Alpha Channel Help Server Time
24 Oct 2026 21:14:01 EDT (-0400)
  Alpha Channel Help (Message 1 to 19 of 19)
Subject: Alpha Channel Help
Date: 2 Aug 2000 19:21:15
Message: <3988aceb@news.povray.org>
image map are showing the color specified in the background{} statement, as
shown in the image below, instead of the color behind it.  My goal is to
make a section of my image map simply 100% transparent other then by using a
.gif.  Is there something I'm doing wrong or is there some characteristic of
alpha channels that I'm not yet aware of?
-Chris-
Download 'scene_06aa.jpg' (8 KB)
Preview of image 'scene_06aa.jpg'
Subject: Re: Alpha Channel Help
Date: 2 Aug 2000 19:32:29
Message: <3988AF6F.96BFA2CC@spiritone.com>
It's kind of hard to see. Which version of POV-Ray are you using? I rerendered a
few files and I think they were originally POV-Ray and I redid them with MegaPov
and got different results, but I haven't pursued the details.
Josh
> -Chris-
eng### [at] spiritonecom
Date: 2 Aug 2000 19:49:02
Message: <3988b36e@news.povray.org>
Josh English <eng### [at] spiritonecom> wrote in message
news:3988AF6F.96BFA2CC@spiritone.com...
rerendered a
MegaPov
Sorry, this image should help.  In this image I made the background color
red.  Also, there is a blue/green fog.  the transparent sections of the .png
seem to ignore the fog, although where they overlap they show the correct
color of the fog...?
I'm using MP 0.5.  With .gif support gone I'm at a loss at what to do...
Making the background color the same as the fog is only a temporary fix and
still leaves a similar result as below when the map is in front of objects
other then the fog.
-Chris-
Download 'scene_06aa.jpg' (13 KB)
Date: 2 Aug 2000 19:57:34
Message: <3988B576.ED05C89F@aol.com>
Open the alpha channel in your paint program and either do a color
replacement for black using rgb 1 1 1 (on the 0 to 255 scale) or simply
repaint the alpha using that color.  It probably won't be absolutely
tranparent, but it'll be darn close.
You could also try adding a sky_sphere or a distant plane and see if
that helps.
-Mike
Date: 2 Aug 2000 23:45:54
Message: <3988eaf2@news.povray.org>
In my experience with alpha channels, I have never been able to make them
totally transparent to appear like empty space so I've stopped trying to use
them.
What I do is make a separate image file which is just a 2-bit black and
white mask of the part of the image I want.  I use this file for a material
map with texture 1 = rgbt 1 and texture 2 = the original image map.
It works for me.
Ian.
Date: 3 Aug 2000 00:09:49
Message: <chrishuff-9F2545.23104302082000@news.povray.org>
In article <3988b36e@news.povray.org>, "Chris S."
> color red.  Also, there is a blue/green fog.  the transparent
> sections of the .png seem to ignore the fog, although where they
> overlap they show the correct color of the fog...?
> fix and still leaves a similar result as below when the map is in
> front of objects other then the fog.
I'm guessing you are using infinitely-thin boxes or polygons to make the
fish? If so, POV may think it is "inside" one after hitting it, and
"outside" after hitting another, so the fog is only calculated if an
even number of fish are hit. Try making the fish hollow(so fog is also
calculated "inside" the fish), this might prevent it. Also, make sure
you have a max_trace_level large enough to get past all the fish.
Date: 3 Aug 2000 03:53:53
Message: <39892511@news.povray.org>
Chris S. <chr### [at] bluelectrodecom> wrote in message
news:3988aceb@news.povray.org...
as
> shown in the image below, instead of the color behind it. [snip]
Try putting max_trace_level 50 (or higher) in the global_settings{} block of
your scene.
Attached are some pics which may help.  The first shows a scene without any
max_trace_level, the second with it set at fifty.  Spot the differenence.
The last two show the png image used, and it's mask/alpha channel.
The image was mapped onto a box using the following code:
#local alpha_thing=box {-0.5 0.5
  texture {pigment {image_map {png "robo_head" map_type 0 once}
translate -0.5}}
  scale <1,1,0.0001>
The scene was rendered using MegaPOV0.5a, if that makes a difference.
Hope this helps,
Alan.
Download 'alpha_no_mtr.jpg' (35 KB) Download 'alpha_mtr_50.jpg' (35 KB) Download 'robohead.jpg' (9 KB) Download 'robohead_mask.jpg' (3 KB)
Preview of image 'alpha_no_mtr.jpg'
Preview of image 'alpha_mtr_50.jpg'
Preview of image 'robohead.jpg'
Preview of image 'robohead_mask.jpg'
Date: 3 Aug 2000 05:16:36
Message: <39893874@news.povray.org>
I use palletted png's, limited to 256 colors. Masking is achieved by
defining transmit for each pallette value intended to be transparent. In the
example Alan posted, you could get away with 16 color png's.
Use max_trace_level, but limit the depth to your actual requirements. I
believe this will save you memory and time in the future. Perhaps, your
current scene won't see much difference in render time, but best to learn
good habits now. :)
Grim
Date: 3 Aug 2000 12:22:21
Message: <39899c3d@news.povray.org>
GrimDude <vos### [at] yahoocom> wrote in message
news:39893874@news.povray.org...
the
Don't know how much this applies, but the png used in the scene I posted was
24-bit, as are all mapping png's I use.
Alan.
Date: 3 Aug 2000 16:17:32
Message: <3989d35c@news.povray.org>
Alan <man### [at] freeukcom> wrote in message news:39899c3d@news.povray.org...
> the
was
> Alan.
Thanks, but no go...  The problem you spotted is fixed by my max_trace_level
of 40, but the problem I'm having seems to be a different one...
-Chris-
Date: 3 Aug 2000 17:23:19
Message: <chrishuff-813F14.16241303082000@news.povray.org>
In article <3989d35c@news.povray.org>, "Chris S."
> max_trace_level of 40, but the problem I'm having seems to be a
> different one...
Like I said before, it looks like a "hollow" issue. Make your fish
objects "hollow" and see if the problem is still there.
Date: 3 Aug 2000 18:45:58
Message: <3989f626$1@news.povray.org>
Chris Huff <chr### [at] maccom> wrote in message
news:chrishuff-813F14.16241303082000@news.povray.org...
> > different one...
Thanks, but no change.  I tried using the hollow boxes...no luck.  Triangles
and polygons still show the same problem...
-Chris-
Date: 3 Aug 2000 19:27:30
Message: <chrishuff-6B1410.18282603082000@news.povray.org>
In article <3989f626$1@news.povray.org>, "Chris S."
> Triangles and polygons still show the same problem...
Maybe a finite-vs-infinite fog problem? Try putting something behind the
fish, so the background isn't an infinite distance away.
Date: 3 Aug 2000 20:04:16
Message: <398a0880@news.povray.org>
news:chrishuff-6B1410.18282603082000@news.povray.org...
Already tried, no good.  It actually seems to be showing up properly against
the fog, but incorrectly with foreground images.
-Chris-
Download 'scene_06aaa.jpg' (16 KB)
Preview of image 'scene_06aaa.jpg'
Date: 4 Aug 2000 04:00:33
Message: <398a7821@news.povray.org>
Could you post the source you used?
Grim
Date: 4 Aug 2000 11:12:36
Message: <398add64@news.povray.org>
news:398a7821@news.povray.org...
> Grim
Sure, it's in p.b.s-f
-Chris-
Date: 6 Aug 2000 04:41:55
Message: <398d24d3@news.povray.org>
I'm not an expert at paint packages, but it looks to me as if your included
image has transparency set for every color within the image. Is this what
you meant to do? I think you would achieve the effect you are after, if you
would set the background of your image as transparent, only.
Keep on tracing!
Grim
Date: 6 Aug 2000 16:24:51
Message: <398dc993@news.povray.org>
news:398d24d3@news.povray.org...
included
you
Well, yeah, that would be the ideal solution...but PS removes any
transparent backgrounds when the file is not saved as a .psd.  As to all my
colors being transparent...if you rendered the file in p.b.s-f the fish part
is showing where the background is "general" not.  The problem I seem to be
having is the background, which I want 100% transparent, is at points
showing up less then 100% creating slightly light boxes appear around the
fish.
I guess I'll live but this problem sure is annoying...
-Chris-
Date: 11 Aug 2000 21:38:25
Message: <347.258T1120T9324165PeterC@nym.alias.net>
Chris:
        Have you tried using a 32-bit targa (TGA) file?  I
was working with alpha channels back and forth between
PovRay and PhotoShop and found that PNGs didn't work but
32-bit TGAs did.
        To make and save a TGA with an alpha channel in
PhotoShop is a PITA but it *is* possible and povray reads
the resulting file correctly.
Pete
