POV-Ray : Newsgroups : povray.binaries.images : Not a submarine Server Time
23 Sep 2025 03:41:12 EDT (-0400)
  Not a submarine (Message 1 to 10 of 22)
Subject: Not a submarine
Date: 1 Aug 2000 18:30:59
Message: <39874fa3@news.povray.org>
No, it's not a submarine!
Something I'm doing for work... thought I'd share it.  The original is
much larger in resolution, so some of the smaller details (like the
threading) don't show here.  It's a cut-away model of an injection
molding assembly.  It was created in AutoCAD from blueprints, then
exported as a series of .3DS files.  I imported the .3DS files into
PolyTrans and converted them into a POV smooth_triangle mesh.  The final
POV file was a whopping 57.6 meg.
How it works: The plastic (in pellet form) is fed into the large hole at
the upper left and the cylinder is heated by the heater bands that are
wrapped around it.  The temperature ranges from 300-900 degrees
fahrenheit, depending on the resin used.  The screw spins inside the
cylinder and forces the melted plastic out the nozzle orifice and into a
mold.  That's the basic synopsis, anyway.  The vertical cylinders are
thermocouples.
Doug Eichenberg
http://www.nls.net/douge
dou### [at] nlsnet
Download 'iso-8859-1' (2 KB)
Subject: Re: Not a submarine
Date: 1 Aug 2000 19:08:22
Message: <398758AE.A0CF08CD@istar.ca>
Great submarine!
Simon
Date: 1 Aug 2000 19:54:01
Message: <39877047.D25F08F5@aol.com>
I thought it was going to be the titanic when it was about halfway
through loading.  Nice looking model, even if I don't know what it is.
-Mike
Date: 1 Aug 2000 21:13:58
Message: <398776C5.BA7E3555@home.com>
Nice! I thought it was a tunnel boring machine.
Doug Eichenberg wrote:
>  No, it's not a submarine!Something I'm doing for work... thought I'd
> share it.  The original is much larger in resolution, so some of the
> smaller details (like the threading) don't show here.  It's a cut-away
> model of an injection molding assembly.  It was created in AutoCAD
> from blueprints, then exported as a series of .3DS files.  I imported
> the .3DS files into PolyTrans and converted them into a POV
> smooth_triangle mesh.  The final POV file was a whopping 57.6 meg.How
> a mold.  That's the basic synopsis, anyway.  The vertical cylinders
> are thermocouples.
> Doug Eichenberg
> dou### [at] nlsnet
Date: 1 Aug 2000 22:12:37
Message: <chrishuff-3D5B28.21132901082000@news.povray.org>
In article <39874fa3@news.povray.org>, "Doug Eichenberg"
Ouch...talk about inefficient. I don't see anything here that couldn't
be done easily with CSG and have a much smaller file size...the threads
on the screws would be the hardest part. They would be possible with
CSG, but probably the best way to do it would be an isosurface. But I
guess you used meshes because it originated as an AutoCad file...
One suggestion: make some more surroundings. Maybe place it on a wood
surface, so the metal has more to reflect.
Date: 1 Aug 2000 22:53:31
Message: <39878CB9.E0FB6FA7@gci.net>
I hate to say it, but I knew it for what it was when I saw it.
There was a time when I was interested in plastics and how they
were worked. In the course of my reading I have seen similar
injectors. This one looks very much like the pictures I saw.
You have done a good job at the modeling.
Mr. Art
> at the upper left and the cylinder is heated by the heater bands that
> are wrapped around it.  The temperature ranges from 300-900 degrees
> are thermocouples.
> Doug Eichenberg
> dou### [at] nlsnet
Date: 1 Aug 2000 23:34:36
Message: <398796cc$1@news.povray.org>
Glad to hear someone else recognized it!  I see these things everyday at
work (I'm a design engineer for a company called Plastic Process Equipment).
I've seen some incredibly complex mixing screws, a couple feet in diameter
and so large you need a truck to move them.  I even designed one that was
used to inject meat by-products into dog bone molds.  I once designed a
screw used by a company making solid rocket propellant.  The temperature had
to be kept to very strict tolerances to avoid any unfortunate mishaps.
- Doug Eichenberg
  http://www.getinfo.net/douge
  dou### [at] nlsnet
Date: 1 Aug 2000 23:41:33
Message: <3987986d@news.povray.org>
How about adding a sense of scale?
You could add something to the scene like the tip of a pencil, the whole
pencil, or the pencil delivery truck-- whichever is appropriate ;-)
Date: 2 Aug 2000 00:14:49
Message: <39879FE8.57DA5FF0@hotmail.com>
before i read i thought it was a down hole crude oil pump
Date: 2 Aug 2000 00:20:26
Message: <3987A139.2DB79010@hotmail.com>
also you might want to try some very very small scratches on some of the
metal and some texture or somthing so it looks like real
