POV-Ray : Newsgroups : povray.binaries.images : penrose tiles and sphere(180K?) Server Time
24 Nov 2026 11:01:33 EST (-0500)
  penrose tiles and sphere(180K?) (Message 1 to 12 of 12)
Subject: penrose tiles and sphere(180K?)
Date: 16 Jul 2000 19:42:19
Message: <3972485b@news.povray.org>
a work in progress.......
Quadhall
Download 'a7.jpg' (166 KB)
Preview of image 'a7.jpg'
Subject: Re: penrose tiles and sphere(180K?)
Date: 16 Jul 2000 21:07:55
Message: <39725C85.4B510B8E@erols.com>
A pedantic nitpick, but while the red and blue tiles are shaped like
those of a Penrose tiling, they are not arranged in the Penrose pattern.
John
ICQ: 46085459
Date: 17 Jul 2000 01:42:36
Message: <39729E51.289ED5@pobox.com>
Tangentially I wonder whether it's possible to cover a sphere with tiles
topologically equivalent to Penrose's.
Anton Sherwood  --  br0### [at] p0b0xcom  --  http://ogre.nu
Date: 17 Jul 2000 03:16:22
Message: <3972B2C7.86DD4606@schunter.etc.tu-bs.de>
I'm no expert in spherical geometry, but that could be possible if you would
distort the single tiles a bit (change angles).  The structure of real penrose
tiling is quite irregular, so this could be quite difficult... you will probably
have to work with variable distortion.
I could think of a program where the tiling grows and angles are adaptively
modified to follow a sphere's shape.  I'm not sure if that works, probably
things would not fit together in the end.
Date: 17 Jul 2000 16:37:14
Message: <39736e7a@news.povray.org>
I'm sure there must be a way to cover a sphere, but your pattern
has to fit in a triangular system... But I thínk, this is tiling,
too. But You surely know that you can aproximate a sphere by n
equal-sided triangles, where n are some discrete numbers...
I don't know if it will work, to take 2 of these triangles
together, but maybe you can get your' penrose tiling this way to
the sphere ...
hmm ... quite hard to explain, hope you know what I mean...
 ,',    Jan Walzer      \V/  http://wa.lzer.net     ,',
',','   student of      >|<  mailto:jan### [at] lzernet ',','
  '   ComputerScience   /A\  +49-177-7403863         '
Date: 17 Jul 2000 22:06:24
Message: <3973bba0@news.povray.org>
Thanks for pointing that out--->I won't change this image as a result, but
perhaps I will incorportate a true Penrose tiling in a future image.  Oh,
and nitpick away, it helps me to learn and stay humble (not that I have much
reason not to be humble).  Thanks again.
John VanSickle wrote in message <39725C85.4B510B8E@erols.com>...
>Regards,
>John
>ICQ: 46085459
Date: 18 Jul 2000 14:41:46
Message: <MPG.13dd6a3c415ceeea98974f@news.povray.org>
On Sun, 16 Jul 2000 21:08:21 -0400, John VanSickle wrote...
I thought that the whole point of penrose tiling was that there *was* no
pattern, that you could fling the tiles together almost randomly and
still get them to tesselate...
I could easily be wrong though.
Bye for now,
     Jamie.
Date: 18 Jul 2000 14:57:53
Message: <3974A8B2.CB19171E@schunter.etc.tu-bs.de>
> Bye for now,
>      Jamie.
IIRC, penrose tilings have a nonperiodic structure, but they are based on very
simple rules, for example fractint describes penrose tiling with the following
L-System:
Penrose1 {
  Angle 10
  Axiom +WF--XF---YF--ZF
  W=YF++ZF----XF[-YF----WF]++
  X=+YF--ZF[---WF--XF]+
  Y=-WF++XF[+++YF++ZF]-
  Z=--YF++++WF[+ZF++++XF]--XF
  F=
So there is only one unique penrose tiling, and changing any element, even if
the tiling stays complete, would no more be a real penrose :-)
Date: 28 Jul 2000 23:20:29
Message: <39824F0E.1CEDDA44@pobox.com>
It's not periodic, but (iirc) every infinite Penrose tiling contains
every finite Penrose tiling -- *because* it is not periodic.
Anton Sherwood  --  br0### [at] p0b0xcom  --  http://ogre.nu/
Date: 31 Jul 2000 08:07:39
Message: <39856C06.30BF69@tapasmail.net>
	Well, according to this page:
http://mathworld.wolfram.com/PenroseTiles.html they're not
even shaped like a Penrose tiling's tiles...
		Jerome
******************************* Jérôme M. BERGER
Date: 23 Jan 2001 02:00:15
Message: <3A6D2E07.761BC0BE@pobox.com>
> > like those of a Penrose tiling, they are not arranged in the
> > Penrose pattern.
You have in mind the darts-and-kites form?  Aperiodic tilings can also
be done with rhombs; see
	http://www.ics.uci.edu/~eppstein/junkyard/penrose.html
Date: 23 Jan 2001 02:03:24
Message: <3A6D4219.CE461593@erols.com>
> > > Penrose pattern.
Both patterns can be broken down into an underlying pattern of fat and
skinny triangles.  The triangle pattern is much easier for a script
file to subdivide.
John
