a work in progress.......
Quadhall
Download 'a7.jpg' (166 KB)
Preview of image 'a7.jpg'
A pedantic nitpick, but while the red and blue tiles are shaped like
those of a Penrose tiling, they are not arranged in the Penrose pattern.
John
ICQ: 46085459
Tangentially I wonder whether it's possible to cover a sphere with tiles
topologically equivalent to Penrose's.
Anton Sherwood -- br0### [at] p0b0x com -- http://ogre.nu
I'm no expert in spherical geometry, but that could be possible if you would
distort the single tiles a bit (change angles). The structure of real penrose
tiling is quite irregular, so this could be quite difficult... you will probably
have to work with variable distortion.
I could think of a program where the tiling grows and angles are adaptively
modified to follow a sphere's shape. I'm not sure if that works, probably
things would not fit together in the end.
Christoph Hormann <chr### [at] gmx de>
I'm sure there must be a way to cover a sphere, but your pattern
has to fit in a triangular system... But I thínk, this is tiling,
too. But You surely know that you can aproximate a sphere by n
equal-sided triangles, where n are some discrete numbers...
I don't know if it will work, to take 2 of these triangles
together, but maybe you can get your' penrose tiling this way to
the sphere ...
hmm ... quite hard to explain, hope you know what I mean...
,', Jan Walzer \V/ http://wa.lzer.net ,',
',',' student of >|< mailto:jan### [at] lzer net ',','
' ComputerScience /A\ +49-177-7403863 '
Thanks for pointing that out--->I won't change this image as a result, but
perhaps I will incorportate a true Penrose tiling in a future image. Oh,
and nitpick away, it helps me to learn and stay humble (not that I have much
reason not to be humble). Thanks again.
John VanSickle wrote in message <39725C85.4B510B8E@erols.com>...
>Regards,
>John
>ICQ: 46085459
On Sun, 16 Jul 2000 21:08:21 -0400, John VanSickle wrote...
I thought that the whole point of penrose tiling was that there *was* no
pattern, that you could fling the tiles together almost randomly and
still get them to tesselate...
I could easily be wrong though.
Bye for now,
Jamie.
> Bye for now,
> Jamie.
IIRC, penrose tilings have a nonperiodic structure, but they are based on very
simple rules, for example fractint describes penrose tiling with the following
L-System:
Penrose1 {
Angle 10
Axiom +WF--XF---YF--ZF
W=YF++ZF----XF[-YF----WF]++
X=+YF--ZF[---WF--XF]+
Y=-WF++XF[+++YF++ZF]-
Z=--YF++++WF[+ZF++++XF]--XF
F=
So there is only one unique penrose tiling, and changing any element, even if
the tiling stays complete, would no more be a real penrose :-)
It's not periodic, but (iirc) every infinite Penrose tiling contains
every finite Penrose tiling -- *because* it is not periodic.
Anton Sherwood -- br0### [at] p0b0x com -- http://ogre.nu/
Well, according to this page:
http://mathworld.wolfram.com/PenroseTiles.html they're not
even shaped like a Penrose tiling's tiles...
Jerome
******************************* Jérôme M. BERGER
* Doctor Jekyll had something * mailto:ber### [at] iname com
* to Hyde... * http://www.enst.fr/~jberger
> > like those of a Penrose tiling, they are not arranged in the
> > Penrose pattern.
You have in mind the darts-and-kites form? Aperiodic tilings can also
be done with rhombs; see
http://www.ics.uci.edu/~eppstein/junkyard/penrose.html
> > > Penrose pattern.
Both patterns can be broken down into an underlying pattern of fat and
skinny triangles. The triangle pattern is much easier for a script
file to subdivide.
John
