Bob Hughes wrote:
> This is very good, competitive with isosurfaces in looks at least I'd say. The
texturing is
> exceptional too.
> Bob
Thank you Bob.
I haven't found time to work with Megapov (and won't in the
next months), therefore I thought about a trick and it worked for me.
I hope I can get to Megapov when everything settles down. I guess
that POV-Ray 3.5 will be out then (and I know this will take some
time ...).
I post the codes to p.t.s-f
Marc
Marc Schimmler wrote:
> I'm using one height field which is copied 100 times
> and where each row is randomly shifted to avoid strong
> banding effects.
> I guess animating would be difficult. You have generate
> a heightfield for each frame ...
> Marc
How did you manage, that there is no visible break between the hf's? Doing
landscape scenes I could never avoid that, even if the heightfield was tilable.
Christoph Hormann <chr### [at] gmxde>
> Christoph
Sad fact is that there are visible lines. But look somehow natural (at
least in
this resolution ...).
Marc
I had to do a gamma correct, and yes it looks great, even
AWESOME some might say.
Steve email mailto:ste### [at] zeroppsuklinuxnet
%HAV-A-NICEDAY Error not enough coffee 0 pps.
or http://start.at/zero-pps
2:23am up 15 days, 2:04, 2 users, load average: 1.04, 1.05, 1.01
Whitecaps...?
> I tried to create water in the non-patched POV-Ray and this is my latest
> attempt. I used a height field that has also been created with POV-Ray
> using
> an average pigment for two rotated marble patterns. The light source and
> the
> cylinder are used to check the reflection and the shadow.
> The results are promising so far. What do you think?
> Marc
> Marc Schimmler
> [Image]
Hey, Marc!
Excellent work here! I tried, for some time, to do water with hf's. It
worked, somewhat, but I never got what I was shooting for.
MegaPov isn't that much to learn and I expect the official 3.5 will have
nearly all of the same advantages of MP. I can't wait to see what the Pov
guru's have added, as well! :)
I'm going to post the FW I was working on, after I get the pony completed.
Hope to see you online then. ;)
Grim
(whispers to Bob) ...should inspire you to grab the particle patch of MP and
work on a waterspout... :D
Grim
Moon47 wrote:
> Whitecaps...?
> > using
> > the
> > Marc
would love to do that.
Maybe I already have an idea ...
Marc
"GrimDude" <vos### [at] yahoocom> wrote in message news:396ec304@news.povray.org...
Yes, that would be interesting to try. Emphasis on the word try.
I would love to see...
Don't forget to share in your triumph...
> Moon47 wrote:
> > Whitecaps...?
> > > using
> > > the
> > > Marc
> Marc
