POV-Ray : Newsgroups : povray.binaries.images : Faceted twisted torus (50k) Server Time
24 Nov 2026 11:15:20 EST (-0500)
  Faceted twisted torus (50k) (Message 1 to 24 of 24)
Subject: Faceted twisted torus (50k)
Date: 11 Jul 2000 16:14:04
Message: <396B7E41.DD2AD7EF@faricy.net>
Ha! Hahaha! Muwahahahaha!!
Bow down before your master!
j/k
Comments/criticisms?
Anyone care to guess how it was done (it's a macro of course)?
Download 'fttor.jpg' (50 KB)
Preview of image 'fttor.jpg'
Subject: Re: Faceted twisted torus (50k)
Date: 11 Jul 2000 16:25:25
Message: <396B8228.869EFF48@dod.no>
That! is! magnificent! :-)
Børge Berg-Olsen
  +47 90 62 71 78          DoD#2101, DoDRT#017, NIC#015, PJ#006, OGM#007
  azo### [at] dodno, Ducati M600              Ubesudlet: Aldri eid en J&%#PS.
Date: 11 Jul 2000 17:00:28
Message: <396B8B32.EABAD6@spiritone.com>
Looks like you're calculating fewer points along the torus and drawing the
squares in and not smoothing your triangles ; )
Josh
> j/k
> David Fontaine     <dav### [at] faricynet>     ICQ 55354965
> Please visit my website: http://www.faricy.net/~davidf/
eng### [at] spiritonecom
Date: 11 Jul 2000 17:04:30
Message: <396B8C24.25141A1D@spiritone.com>
actually, It can't be that easy, but I bet you are rotating and translating
instead of using a parametric equation
> Josh
> > j/k
> >  [Image]
> Josh English -- Lexiphanic Lethomaniac
> The POV-Ray Cyclopedia http://www.spiritone.com/~english/cyclopedia/
Date: 11 Jul 2000 17:05:54
Message: <396B8C4E.94C7F277@tiac.net>
Cool.
If you make the cylinders a dull silverish color and put a bumpy normal
on the red parts it would look more like a stained glass structure.
...just a thought.
Phil
Date: 11 Jul 2000 17:40:10
Message: <396b943a@news.povray.org>
David Fontaine <dav### [at] faricynet> wrote in message
news:396B7E41.DD2AD7EF@faricy.net...
Cool! Now darken the scene; make the panels semi-transparent with a good
ior; add in some funky turbulated emitting media (like glowing gas) inside
the object; add in point lights with a good fade_distance and fade_power in
the center of each segment; and hover the beasty over some rippling water in
a large copper dish in the center of  an open-skied altar place with
moonlight trailing down on the scene.
or.. Just leave it like it is. :{)
David
Date: 11 Jul 2000 19:53:47
Message: <396bb38b@news.povray.org>
Yappari David-sama wa Kami-sama desu!
Date: 11 Jul 2000 23:16:32
Message: <396BE15B.E87BFF6@faricy.net>
And so on, and so forth...
Nope, that is the deceptively easy way, but I want quadrilaterals, not triangles,
and they have to be coplanar of course...
Date: 11 Jul 2000 23:16:48
Message: <396BE16B.3B405B3B@faricy.net>
Um, thanks, I guess :)
Date: 12 Jul 2000 00:19:55
Message: <396bf1eb@news.povray.org>
I took that from a Japanese cartoon, all I did was replace "Shougo" for
"David". I means "I knew that the great David was a god!" :-)
Date: 12 Jul 2000 00:46:50
Message: <396bf83a@news.povray.org>
Master, Master, where's the dreams that I've been after?
Master, Master, you promised only lies
Laughter, laughter, all I hear or see is laughter
Laughter, laughter, laughing at my cries
Subject: R: Faceted twisted torus (50k)
Date: 12 Jul 2000 00:51:49
Message: <396bf965@news.povray.org>
Very......
It's possible have the .pov/.zip source
for experiments?
Thanks.
Date: 12 Jul 2000 01:28:07
Message: <396AB374.FBD5C1B6@earthlink.net>
In the words or a great Jedi master "...There is always a bigger fish..."
Subject: SV: Faceted twisted torus (50k)
Date: 12 Jul 2000 08:32:36
Message: <396c6564@news.povray.org>
oh no...
Peter!! we HAVE started a trend...
Z.
Subject: Re: SV: Faceted twisted torus (50k)
Date: 12 Jul 2000 13:41:09
Message: <sbbpms8s1d666b9626usgtmq8diksmvrru@4ax.com>
On Wed, 12 Jul 2000 14:29:30 +0200, "Zilvah" <zil### [at] onlineno> wrote:
>oh no...
*ducks for cover*
Peter Popov ICQ : 15002700
Subject: Re: R: Faceted twisted torus (50k)
Date: 12 Jul 2000 17:02:16
Message: <396CDB1D.939A6836@faricy.net>
"up.luino" wrote:
> Very......
> for experiments?
> Thanks.
Sure, once I clean it up I'll eventually post it in p.b.s-f.
Date: 13 Jul 2000 02:57:40
Message: <396d6864@news.povray.org>
Well, actually it means, "As suspected, David is a god." or, in proper
characters, "$B$d$C$Q$j!"%G%S%C%I$5$s$O?@MM$G$9!#(B"
--Rainer
"Tony[B]" <ben### [at] panamac-comnet> wrote in message
news:396bf1eb@news.povray.org...
Subject: Re: Faceted twisted torus (50k) ((74k))
Date: 13 Jul 2000 20:26:48
Message: <396.229T1171T12254412PeterC@nym.alias.net>
David,
        That is really cool.  I can't wait for you to
post the source code.  In the mean time, I've tried to
re-create a similar shape.
        The big problem with my version is the facets:
you can see that they are actually two noncoplaner
triangles.  I tried to use a smooth triangle to cover
that but someone I can't get the normals to work.  No
modeler used: this is all pov coding.
Download 'facet_torus_4.jpg' (74 KB)
Preview of image 'facet_torus_4.jpg'
Date: 13 Jul 2000 23:46:26
Message: <396E8B57.484B56B7@faricy.net>
Pete wrote:
> David,
So, non-coplanar facets are easy! You'll notice that on mine, a row of
paneling on the outside of the shape eventully works it way around to the
inside. Also, I beilieve strips don't meet themselves after a full trip
around, so it's like a mobius strip.
Subject: Source in p.b.s-f
Date: 14 Jul 2000 13:10:00
Message: <396F47AD.84EB9FE@faricy.net>
Sorry for the delay
source will be in p.b.s-f
Date: 16 Jul 2000 22:03:41
Message: <712.232T2900T13186381PeterC@nym.alias.net>
I actually had not noticed that.  Woops.  Hmm.  That's why you
have seven coils: otherwise the six-sided cross section would not
work.  Aha!  That also means you can only use an odd number of
coils.  So does the mobius-like  twisting somehow cut down
on the amount of curvature on the individual facets?
I learned a lot of math and pov in the progress of attempting
to emulate your picture, so thank you for posting it!
<bows to master>
Date: 23 Jul 2000 17:42:36
Message: <397B7406.33AC04D9@netvision.net.il>
photons, sir, photons...
Date: 27 Jul 2000 19:42:25
Message: <3980C70B.E618AAF4@faricy.net>
> coils.
I'm not following. Why do you think I can only use an odd number?
Not entirely sure what you mean... the facets are perfectly flat, except for
the last one (where it must meet up properly with the first), the mobius
twisting is a side effect of them being flat.
No problem :)
Date: 27 Jul 2000 19:43:45
Message: <3980C758.AD5215AA@faricy.net>
With my great mastery of photons that'll only take a month or two :)
