Ha! Hahaha! Muwahahahaha!!
Bow down before your master!
j/k
Comments/criticisms?
Anyone care to guess how it was done (it's a macro of course)?
David Fontaine <dav### [at] faricy net> ICQ 55354965
Download 'fttor.jpg' (50 KB)
Preview of image 'fttor.jpg'
That! is! magnificent! :-)
Børge Berg-Olsen
+47 90 62 71 78 DoD#2101, DoDRT#017, NIC#015, PJ#006, OGM#007
azo### [at] dod no, Ducati M600 Ubesudlet: Aldri eid en J&%#PS.
Looks like you're calculating fewer points along the torus and drawing the
squares in and not smoothing your triangles ; )
Josh
> j/k
> Please visit my website: http://www.faricy.net/~davidf/
> [Image]
eng### [at] spiritone com
actually, It can't be that easy, but I bet you are rotating and translating
instead of using a parametric equation
> Josh
> > j/k
> > [Image]
> Josh English -- Lexiphanic Lethomaniac
> The POV-Ray Cyclopedia http://www.spiritone.com/~english/cyclopedia/
Cool.
If you make the cylinders a dull silverish color and put a bumpy normal
on the red parts it would look more like a stained glass structure.
...just a thought.
Phil
David Fontaine <dav### [at] faricy net> wrote in message
news:396B7E41.DD2AD7EF@faricy.net...
Cool! Now darken the scene; make the panels semi-transparent with a good
ior; add in some funky turbulated emitting media (like glowing gas) inside
the object; add in point lights with a good fade_distance and fade_power in
the center of each segment; and hover the beasty over some rippling water in
a large copper dish in the center of an open-skied altar place with
moonlight trailing down on the scene.
or.. Just leave it like it is. :{)
David
Yappari David-sama wa Kami-sama desu!
And so on, and so forth...
Nope, that is the deceptively easy way, but I want quadrilaterals, not triangles,
and they have to be coplanar of course...
Um, thanks, I guess :)
I took that from a Japanese cartoon, all I did was replace "Shougo" for
"David". I means "I knew that the great David was a god!" :-)
"David Fontaine" <dav### [at] faricy net> wrote in message
Master, Master, where's the dreams that I've been after?
Master, Master, you promised only lies
Laughter, laughter, all I hear or see is laughter
Laughter, laughter, laughing at my cries
Very......
It's possible have the .pov/.zip source
for experiments?
Thanks.
In the words or a great Jedi master "...There is always a bigger fish..."
oh no...
Peter!! we HAVE started a trend...
Z.
On Wed, 12 Jul 2000 14:29:30 +0200, "Zilvah" <zil### [at] online no> wrote:
>oh no...
*ducks for cover*
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] usa net
TAG e-mail : pet### [at] tag povray org
"up.luino" wrote:
> Very......
> for experiments?
> Thanks.
Sure, once I clean it up I'll eventually post it in p.b.s-f.
Well, actually it means, "As suspected, David is a god." or, in proper
characters, "$B$d$C$Q$j!"%G%S%C%I$5$s$O?@MM$G$9!#(B"
--Rainer
"Tony[B]" <ben### [at] panama c-com net> wrote in message
news:396bf1eb@news.povray.org...
David,
That is really cool. I can't wait for you to
post the source code. In the mean time, I've tried to
re-create a similar shape.
The big problem with my version is the facets:
you can see that they are actually two noncoplaner
triangles. I tried to use a smooth triangle to cover
that but someone I can't get the normals to work. No
modeler used: this is all pov coding.
Download 'facet_torus_4.jpg' (74 KB)
Preview of image 'facet_torus_4.jpg'
Pete wrote:
> David,
So, non-coplanar facets are easy! You'll notice that on mine, a row of
paneling on the outside of the shape eventully works it way around to the
inside. Also, I beilieve strips don't meet themselves after a full trip
around, so it's like a mobius strip.
Sorry for the delay
source will be in p.b.s-f
I actually had not noticed that. Woops. Hmm. That's why you
have seven coils: otherwise the six-sided cross section would not
work. Aha! That also means you can only use an odd number of
coils. So does the mobius-like twisting somehow cut down
on the amount of curvature on the individual facets?
I learned a lot of math and pov in the progress of attempting
to emulate your picture, so thank you for posting it!
<bows to master>
photons, sir, photons...
> coils.
I'm not following. Why do you think I can only use an odd number?
Not entirely sure what you mean... the facets are perfectly flat, except for
the last one (where it must meet up properly with the first), the mobius
twisting is a side effect of them being flat.
No problem :)
With my great mastery of photons that'll only take a month or two :)
