POV-Ray : Newsgroups : povray.binaries.images : Fast Erosion (3*20k) Server Time
24 Oct 2026 22:58:02 EDT (-0400)
  Fast Erosion (3*20k) (Message 1 to 28 of 28)
Subject: Fast Erosion (3*20k)
Date: 10 Jul 2000 13:51:25
Message: <396A0D1D.2B382007@schunter.etc.tu-bs.de>
Just made some tests with an Erosion routine I programmed some time ago.  The
result has some similarity with ridged multifractal but it is an editing
function modifying any existing heightfield.
And it is quite fast (about 800 milliseconds for a single run on a 256x256
point heightfield on my K6/500)
The first one is the starting heightfield, the second one after about 15 runs
with smoothing between, the third after 15 additional runs.
Please tell me what you think of it, I wonder if anybody has done something
similar before.
I am already planning some addition to stop erosion process, when a certain
slope is reached, which would be more realistic.
Download 'erode1.jpg' (21 KB) Download 'erode2.jpg' (20 KB) Download 'erode3.jpg' (20 KB)
Preview of image 'erode1.jpg'
Preview of image 'erode2.jpg'
Preview of image 'erode3.jpg'
Subject: Re: Fast Erosion (3*20k)
Date: 10 Jul 2000 14:09:39
Message: <396A0FB2.D7D70F2@faricy.net>
Hmm, they look more like they're in reverse order. Tall, pointy peaks should get
rounded off.
Date: 10 Jul 2000 14:59:13
Message: <396A1D01.C701A4CD@schunter.etc.tu-bs.de>
> rounded off.
no, they are in right order :-)
Have you ever looked at a mountain region from above: most mountains have quite
plane sides and very sharp ridges.
Date: 10 Jul 2000 15:31:11
Message: <chrishuff-F98AD5.14313110072000@news.povray.org>
In article <396A1D01.C701A4CD@schunter.etc.tu-bs.de>,
> have quite plane sides and very sharp ridges.
Yes, but they eventually get smoothed over by time and weather. Sharp
points and steep sides shear off and the debris accumulates at the
bottom, and the mountain becomes more hill-like and rounded.
Your filter looks more like a "time machine", reversing the normal
erosion process.
Date: 10 Jul 2000 15:42:58
Message: <396A26E9.66264BE0@yahoo.com>
i think it depends on whether it is wind erosion or water erosion.  wind
rounds, water peaks.
if you could define areas most and least likely to erode, that would be
cool.  for example, areas with a lot of ground cover don't erode as fast
as open areas.  dirt erodes faster than rock, etc.
Date: 10 Jul 2000 16:18:12
Message: <396A2F84.90E97BE2@schunter.etc.tu-bs.de>
> erosion process.
It depends on the material, of course hillsides do not get infinitely steep, but
it can be quite extreme like in the attached photo.
Download 'mount1.jpg' (8 KB)
Preview of image 'mount1.jpg'
Date: 10 Jul 2000 16:31:48
Message: <396a32b4@news.povray.org>
quite
    Some mountains look sharp because they have been recently pushed up.
Even old mountains look that way if they are still being pushed up. But old
mountains in areas with no recent plate activity are rounded by erosion.
Your photo is clearly one of an upthrust formation of some sort. In a
billion years it will be a rounded boulder.
I get paid to do -anything- while connected to the internet.
Please use my referral id to find out more
http://www.getpaid4.com/?billdewitt
Date: 10 Jul 2000 16:32:36
Message: <396A32E4.CF4A5F18@schunter.etc.tu-bs.de>
IMO this type of erosion is mainly caused by the changing temperatures
destroying the structure of the material at the surface.  Of course water and
wind are major factors for transportation of material.
That's a good idea, it is only a problem how to define those areas.
BTW, my code partly already does this, because it erodes more on steeper areas,
where there is normally fewer vegetation.
Date: 10 Jul 2000 16:44:08
Message: <396A333F.8A101D00@global2000.net>
Can a routine be made to do wind erosion?  Desert landscapes could be made with
these mushroom shaped rocks that get eroded more at the bottom.  However, I'm not
sure if that can be done with height fields.
Brendan
> similar before.
> Christoph
> Homepage: http://www.schunter.etc.tu-bs.de/~chris/
>  [Image]  [Image]  [Image]
Date: 10 Jul 2000 16:58:22
Message: <396A38EE.47EC454D@schunter.etc.tu-bs.de>
Agreed, but on the other hand, the sharp structures often correspond with the
river network, which suggests, that they are also partly formed by erosion.
The photo is not a very good example, very good are usually satellite pictures
where you can see the sharp edges in the light *and* the rivers.
just found one (sorry for the many pictures), well in fact it's a radar image,
but it should work...
Download 'mount2.jpg' (44 KB)
Preview of image 'mount2.jpg'
Date: 10 Jul 2000 18:42:30
Message: <396A50E5.DAB3F0E8@yahoo.com>
have you seen any of the tutorials and utilities made for positioning
items on a height field?  i think there is something out there that can
define areas of height fields to be worked on.  i think it is genesis
toolkit found at www.rhein-ruhr.de/~schrammel/index.htm.  i'm not sure
it's usefull, but there you go.
> Christoph
Date: 10 Jul 2000 19:02:48
Message: <396a5618@news.povray.org>
Could you perhaps allow the user to provide an erosion_map for it?
Date: 10 Jul 2000 22:13:53
Message: <396A826F.E7ED81A8@online.no>
Interesting.
Is it a POV-script doing this ?
And if so, then how is it done ?
Tor Olav
mailto:tor### [at] hotmailcom
Date: 11 Jul 2000 01:14:44
Message: <396aad44@news.povray.org>
Maybe an animation would help illustrate your technique? (O.k., so I just
like animations a lot... :)
Dave
"Christoph Hormann" <Chr### [at] schunteretctu-bsde> wrote in
message news:396A0D1D.2B382007@schunter.etc.tu-bs.de...
The
runs
something
> similar before.
certain
> Christoph
Date: 11 Jul 2000 01:36:55
Message: <396ab277@news.povray.org>
Christoph Hormann wrote in message
<396A32E4.CF4A5F18@schunter.etc.tu-bs.de>...
Allow a user to provide a second greyscale image that specifies the
"hardness" of parts of the map.
Mark
Date: 11 Jul 2000 01:38:37
Message: <396ab2dd$1@news.povray.org>
Andrea Ryan wrote in message <396A333F.8A101D00@global2000.net>...
with
I'm not
>Brendan
It can't be done with a heightfield, but a .df3-based isosurface would work
quite well for this.
Mark
Date: 11 Jul 2000 06:16:47
Message: <396AF411.393E6CF4@schunter.etc.tu-bs.de>
> Regards,
> Dave
Never did an animation before :-) so i will have to learn it first...
NTL, it is a good idea.
Date: 11 Jul 2000 06:27:20
Message: <396AF68A.84E983A0@schunter.etc.tu-bs.de>
Tor Olav Kristensen wrote:
> Interesting.
> Tor Olav
No, it's a delphi program.
BTW, that leads to an interesting idea for a new feature:
   height_field {
      pov {
         "hf.pov"
         width=512
         height=512
   or similar...
Recursive implementation could occupy povray forever :-)
Date: 11 Jul 2000 06:52:00
Message: <396AFC4F.5F282941@schunter.etc.tu-bs.de>
> Mark
That's already planned (it's already possible to specify a B/W mask for total
exclusion of certain areas).
The problem is how to generate that map, because in real world the amount of
erosion is influenced by a lot of factors like:
   -rock material
   -water amount
   -slope
   -hillside orientation
   -most often wind directions
   -existing vegetation
Some of these factors can be calculated from the heightfield, some have to be
specified by the user, but for example not every user drawn "geological map" is
possible, it is not reasonable if the material changes from granite to sand just
at the top of a mountain.
Date: 11 Jul 2000 10:16:29
Message: <396b2c3d@news.povray.org>
That's what I said.
Date: 11 Jul 2000 15:02:42
Message: <396B6D9E.CED7E025@faricy.net>
Ugh, forget I said anything...
Date: 11 Jul 2000 15:16:35
Message: <396B7294.D66CFAF@schunter.etc.tu-bs.de>
Just put some more samples on my web page, so if anybody is interested:
http://www.schunter.etc.tu-bs.de/~chris/erosion1.html
I also included an "inverse version" with rounded hills, it does not look as bad
as i thought :-)  Maybe I could try out some mixtures...
Date: 6 Aug 2000 03:48:39
Message: <398D194A.FEB4006@home.com>
That would be a relatively young mountain in your photo.
> > erosion process.
> Christoph
Subject: Re: Fast Erosion (42k)
Date: 6 Aug 2000 17:53:42
Message: <398DDC5C.2F84F85E@faricy.net>
That is an example of water erosion, not wind. I have attached a photo from Glacier
Park to demonstrate...
Download 'glacierpark.jpg' (43 KB)
Preview of image 'glacierpark.jpg'
Date: 6 Aug 2000 19:27:36
Message: <398df468$1@news.povray.org>
news:398DDC5C.2F84F85E@faricy.net...
steep, but
from Glacier
I had said (and someone else was before me) about how the material being
carried away would make a lot of difference.  Good example of that.
Come on now, someone could render a copy of this photo can they not?  No
image mapping allowed though.
Date: 7 Aug 2000 01:27:50
Message: <398E4702.56207A8C@pacbell.net>
Someone would be quick to point out that the cloud in the center was
not realistic in appearance. Me for example :)
Date: 8 Aug 2000 01:17:40
Message: <398F95F7.C6BD1986@faricy.net>
Yes, you are correct. It only took 28 days, too (look at the post times). I am
immensely proud of my accomplishment. If you look closely, you will also
notice I modelled and very accurately textured some helicopter-window
plexiglass right in front of the camera. Come on, if Gilles can make Wet Bird,
who's to say I can't make this? :-) Of course, I owe a lot of thanks to Nathan
for all the great MegaPOV features.
Date: 8 Aug 2000 17:07:58
Message: <399076C4.F64EE72A@schunter.etc.tu-bs.de>
Your pict. shows a lot of different aspects of erosion: on the lower parts,
there is water erosion in "soft materials".  I don't see much wind erosion
anywhere.
Most erosion effects on massive mountains IMO are "thermal erosion", meaning the
destruction of the rock structure due to temperature changes.  Of course, water
and wind influence these effects in certain ways.
I think both photos show very much of this type of erosion, but it is not easy
to simulate, because it much depends on the internal structure of the rock.
