POV-Ray : Newsgroups : povray.binaries.images : Fire Opal - W.I.P.(60 K) Server Time
24 Nov 2026 11:15:21 EST (-0500)
  Fire Opal - W.I.P.(60 K) (Message 1 to 18 of 18)
Subject: Fire Opal - W.I.P.(60 K)
Date: 9 Jul 2000 16:05:50
Message: <3968db1e@news.povray.org>
Well, this is unfinished.. I'm still not completely happy with the opal
texture and the gold needs some work. I need to add a chain up above and I'd
like to hang it on a velvet (now how do I simulate velvet?) stand instead of
a piece of wood.
As usual, comments/advice as welcomed.
David
Download 'fireopal.jpg' (61 KB)
Preview of image 'fireopal.jpg'
Subject: Re: Fire Opal - W.I.P.(60 K)
Date: 9 Jul 2000 16:10:24
Message: <3968E99D.9C669102@netvision.net.il>
I like the opal texture, and the modelling is very nice.
Try adding reflectiveness to the gold texture, and I think it will look
great. Don't forget to photon!
> a piece of wood.
> David
Date: 9 Jul 2000 16:29:25
Message: <3968e0a5@news.povray.org>
Wow, I always wanted to make a good opal - this is great! Can it work for
the blue/green opals too?
-Dave
"David Heys" <sou### [at] gcinet> wrote in message
news:3968db1e@news.povray.org...
I'd
of
> a piece of wood.
> David
Date: 9 Jul 2000 16:46:40
Message: <3968e4b0@news.povray.org>
Well, since the the texture is mostly just an emitting media with a density
map, it'd just be a matter of changing the colors. Here's the texture:
  pigment {Gold/2 filter 0.5 transmit 0.5}
  finish {blinn 40 facets 0.062105 reflection 0.15}
  interior {
   ior 1.5
   media {
    emission 1.0
    method 3
    density {
     bozo
     scale <.4,0.3,0.3>
     turbulence .85
     octaves 2
     lambda 1.01
     omega .75
     rotate 90*z
     density_map {
      [0    Gold/2]
      [0.1  Gold/4]
      [0.2  Coral/4]
      [0.3  Coral/2]
      [0.4  agate
            color_map {
             [0 Gold/2]
             [0.2 rgb 0]
             [0.4 Coral/2]
             [0.6 rgb 0]
             [1.0 SpicyPink/3]
            scale 0.1
      [0.5  rgb -.25]
      [0.6  granite
            color_map {
             [0 SpicyPink/3]
             [0.2 rgb 0]
             [0.4 Gold/2]
             [0.6 rgb 0]
             [1.0 Coral/2]
            scale 0.1
      [0.7  Coral/2]
      [0.8  Coral/4]
      [0.9  Gold/4]
      [1    Gold/2]
    scale 5
Date: 9 Jul 2000 16:50:06
Message: <3968e57e@news.povray.org>
Lewis <nle### [at] netvisionnetil> wrote in message
news:3968E99D.9C669102@netvision.net.il...
There is a small reflectiveness on the gold, but I'll likely bump it up. If
you look at the very bottom of the image, you'll see some photons at work. I
think that the emitting media muddled up most of them though. Then again, as
Opal is a fairly opaque material, I guess you shouldn't see a lot of photons
going through it. I used:
 photons{
  count 4000000
  autostop 0
  jitter .4
  media 100
Date: 9 Jul 2000 18:01:10
Message: <3968f626@news.povray.org>
Wow, very nice. I like esp. those indentations on the upper band (?).
Is this swelling at the lower right band intentional?
Marc-Hendrik
David Heys schrieb in Nachricht <3968db1e@news.povray.org>...
I'd
of
>a piece of wood.
>David
Date: 9 Jul 2000 18:10:00
Message: <3968f838@news.povray.org>
Cool. Thank you, sir.
news:3968e4b0@news.povray.org...
for
density
>   interior {
>    ior 1.5
>    media {
>     emission 1.0
>     method 3
>     density {
>      bozo
>      scale <.4,0.3,0.3>
>      turbulence .85
>      octaves 2
>      lambda 1.01
>      omega .75
>      rotate 90*z
>      density_map {
>       [0    Gold/2]
>       [0.1  Gold/4]
>       [0.2  Coral/4]
>       [0.3  Coral/2]
>       [0.4  agate
>             color_map {
>              [0 Gold/2]
>              [0.2 rgb 0]
>              [0.4 Coral/2]
>              [0.6 rgb 0]
>              [1.0 SpicyPink/3]
>             scale 0.1
>       [0.5  rgb -.25]
>       [0.6  granite
>             color_map {
>              [0 SpicyPink/3]
>              [0.2 rgb 0]
>              [0.4 Gold/2]
>              [0.6 rgb 0]
>              [1.0 Coral/2]
>             scale 0.1
>       [0.7  Coral/2]
>       [0.8  Coral/4]
>       [0.9  Gold/4]
>       [1    Gold/2]
>     scale 5
Date: 9 Jul 2000 18:28:32
Message: <3968fc90@news.povray.org>
All of the gold, except for the hook at the top, is one large blob
construct. The outer ring is a #while loop with one positive and four
negative strength components for each point around the circumference. The
three lower curls, and the two upper curls are blob component #whiles. All
of them are somewhat freeform and certainly not perfect. I didn't want them
to be such, actually. The negative blobs all around the circumference all
had their own influences on the curls and I think it's given it a rather
individual look.
David
Date: 9 Jul 2000 18:45:24
Message: <39690084$1@news.povray.org>
I would have never thought this holder is a blob! I would have spend hours
to model it with csg :-) I really like it!
Marc-Hendrik
Date: 9 Jul 2000 18:55:39
Message: <MPG.13d308ddd890053d989739@news.stmuc.com>
On Sun, 9 Jul 2000 11:59:04 -0800, David Heys wrote...
> a piece of wood.
I hate to nitpick (actually, that's a lie, I *like* nitpicking <grin>),
especially with such a pretty image, but there seem to be some rather
nasty jaggies happening in the top left corner of the image.
Specifically, the left hand side of the upper band of gold which passes
in front of the opal seems to have some very visible stepping, as if it
were constructed out of lots of cubes.
Otherwise it's a very nice image, and I wouldn't meddle too much with it,
as I've ruined far too many perfectly good scenes by attempting to put
more detail into them long past the point at which I should have stopped.
Bye for now,
     Jamie.
Date: 9 Jul 2000 19:14:01
Message: <39690739$1@news.povray.org>
Jamie Davison <jam### [at] dh70qdu-netcom> wrote in message
news:MPG### [at] newsstmuccom...
Oh, please, nitpick away. :{)
The jagginess you mention was intended.. in a way.. I specifically wanted to
give this a hand-hammered feel. As if the gold had been hand formed around
the gemstone. If I bumped up the # of compponents on the #while sweep around
the gem, I'd eliminate most of this, and an adjustment to some ofthe other
influences would get rid of those imperfections. But I wanted them there. I
was trying to go for a more organic feel to the gold work. I've found that's
really hard to do. :{P
David
Date: 9 Jul 2000 19:15:49
Message: <396907a5$1@news.povray.org>
Marc-Hendrik Bremer <Mar### [at] t-onlinede> wrote in message
news:39690084$1@news.povray.org...
<smile> Blobs can be a lot of fun.. at times.. at other times they can be
very frustrating. In this scene, "most" of what I wanted the components to
do came relatively easily.
David
Date: 9 Jul 2000 21:20:52
Message: <396924f4@news.povray.org>
Antique look to it, the opal surface is totally blemish-free though and so it
doesn't seem to go.  Maybe use a bozo color map for the container having clear
to not so clear parts?  Or maybe a texture map for that matter.  I like the
dulled "gold" but it tends to look like tarnished brass to me.  My guess is it
needs higher color with lower diffuse.
I posted a Crushed Velvet Texture tp p.t.s-f Feb. 7th, 2000
389e81fc@news.povray.org  if that will help.
Date: 9 Jul 2000 21:35:48
Message: <39692874@news.povray.org>
Oops, sorry about the link addition here, I never have linked to a newsgroup
posting before and I just put what looked appropriate from the message
properties.  Again, sorry, please ignore it.
| 389e81fc@news.povray.org   <=== goes to email, don't use please!
Date: 9 Jul 2000 22:19:12
Message: <396932a0$1@news.povray.org>
it
clear
the
is it
Hmm.. I'll give it a shot.
I'll go look for it right now. :{)
David
Date: 9 Jul 2000 22:24:39
Message: <slrn8mibc1.ttu.steve@zero-pps.localdomain>
A great piece of work.  I've saved the texture that
you posted and might give it a try in something soon.
Bob's velvet in bottle green will look real good
behind this.
  2:24am  up 11 days,  2:05,  2 users,  load average: 1.02, 1.08, 1.03
Date: 9 Jul 2000 23:40:13
Message: <5qgimsofcim2uoomg4eokas7oabuu1p63b@4ax.com>
On Sun, 9 Jul 2000 11:59:04 -0800, "David Heys" <sou### [at] gcinet>
Wow, very, very... opalescent! :)
Peter Popov ICQ : 15002700
Date: 12 Jul 2000 21:40:15
Message: <396D1E86.C7E97ABA@home.com>
>  photons{
>   count 4000000
>   autostop 0
>   jitter .4
>   media 100
Hmmm...  same count i always use....  but i might start stepping them up some...
