There are 400005 blades of grass in this pic - took 5 hrs to render - 3hrs
45 mins to parse!
Mick
Download 'tester.jpg' (130 KB)
Preview of image 'tester.jpg'
> 45 mins to parse!
> Mick
Wow! That's really big. How much memory did it use?
Christoph Hormann <chr### [at] gmx de>
Does this use the source I sent you? Looks nice. I wonder what this would
look like on a far away hill? (Maybe you should borrow some RAM from a
couple friends, and give a full scene a try. :)
Yep, my next project - I want to create some rocks based on samuals basalt
columns and about 2 million blades of grass on a HF using your mod and some
of mine on Samuals code. Then I'll throw in some media, a few rocks and
radiosity and go on holiday for a month!!!!!
Mick
"Tony[B]" <ben### [at] panama c-com net> wrote in message
news:39574eda@news.povray.org...
In article <395775a3@news.povray.org>, "Mick Hazelgrove"
> basalt columns and about 2 million blades of grass on a HF using your
> mod and some of mine on Samuals code. Then I'll throw in some media,
> a few rocks and radiosity and go on holiday for a month!!!!!
Don't forget focal blur, and a bunch of transparent and reflective
objects with blurred reflections. And maybe you could fit my proximity
pattern in there somewhere, too. :-)
Christopher James Huff - Personal e-mail: chr### [at] mac com
TAG(Technical Assistance Group) e-mail: chr### [at] tag povray org
When I create a field of grass with 50.000 objects or up my computer runs
out of memory! I use a PIII-600 with 256Mb ram! That should be enough,
shouldn't it?
Greetings, Bugs74
Should be more than enough - I used to regulary use a million or two objects
in experiments on my old 300 mhz P2 with 128 mb of ram
Mick
"Bugs74" <bug### [at] wanadoo nl> wrote in message
news:39578114@news.povray.org...
> shouldn't it?
> Greetings, Bugs74
> 45 mins to parse!
Looks impressive, but the shadows are a bit harsh in places. If you put
in a good looking sky and filled in the shadows a bit with some
radiosity, this could be an awesome pic...
...going on vacation anytime soon? ^_-;
Xplo Eristotle
http://start.at/xplosion/
"And then one day you find ten years have got behind you
No one told you when to run, you missed the starting gun"
-Pink Floyd
When I've spent a couple of months of my spare time working out the
code!!!!!!
"Xplo Eristotle" <inq### [at] unforgettable com> wrote in message
news:395786F5.5EEB9BA4@unforgettable.com...
3hrs
> > 45 mins to parse!
> Xplo Eristotle
> -Pink Floyd
Are you talking about the trace() modification? I would be real greatful if
you could post the changes that are necessary to the code.
Thanks,
Equiprawn
Tony[B] <ben### [at] panama c-com net> wrote in message
Wow Mick... I haven't even tried that many yet.... I guess the grass isn't so
fast when so many are used :) I wonder if making one smaller square of grass
and then copying it would save memory? You'd have to make sure nobody could
see the repetitions.
~Sam
> 45 mins to parse!
> Mick
> [Image]
I'm sorry, I wasn't very clear in my message: does anybody know what I'm
doing wrong? When I try to render a pic with 50.000 or more blades of grass
I get a mesagge that says POVray is reclaiming memory. I use 256 MB of
memory, so that should be enough.
I hope someone can help me!
Greetings, Bugs74
That's the usual technique but you'd loose the advantage of eval_pigment. I
don't think youd save much memory either. As most of the parsing time was
spent on creating bounding slabs, I guess that manual bounding is the way to
go when I work out how to do it!
Mick
"SamuelT" <STB### [at] aol com> wrote in message
news:39579386.268B1DA3@aol.com...
so
grass
could
> ~Sam
3hrs
> > 45 mins to parse!
> > Mick
> > [Image]
When do you get that message, normally you only get that when you stop the
rendering.
I can't off hand think why you are running out of memory - when I first
stared using Povray I had a 486 and regularly went up to 100,000 objects
with no apparent problems other than a loss of patience!
Mick
news:395793f3@news.povray.org...
grass
> Greetings, Bugs74
"Chris Huff" <chr### [at] mac com> wrote in message
news:chrishuff-D09E25.10384226062000@news.povray.org...
> and reflective objects with blurred reflections.
Also add a few dozen area lights (using fade_distance, of course).
Eric
wouldn't distance-dependent grass be better on render times? like if
the quality stuff was up front, then not so good, but faster, ending
with a regular texture far out? is there a not-so-good grass macro? or
are they all made for close up inspection? i've seen trees that are
supposed to be used far away, but not grass.
for the current image, how high up are you from the grass and what is
the length of the grass? oh, and how far out does it go? (just trying
to get a perspective here) also, is it one patch of grass or several?
is it possible to selectively smash down certain areas of the grass;
like alien landing sites in crops or the shape an animal makes when it
lays down? and what are the units you use? can you make the light and
dark areas (wind?) more smooth or are you stuck with what you get?
thanks.
> Mick
On Mon, 26 Jun 2000 19:01:42 +0100, "Mick Hazelgrove"
>> so fast when so many are used :) I wonder if making one smaller square of
>> grass and then copying it would save memory? You'd have to make sure nobody
>> could see the repetitions.
Not if you use a tileable pigment made with Chris' macro :)
I
A quadtree hierarchy of bounding boxes would be a good shot at it, I
guess.
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] usa net
TAG e-mail : pet### [at] tag povray org
Its Samual's grass macro but spacing between grass blades has been reduced
from 1 to .01pov units!!!!
Mick
"ryan constantine" <rco### [at] yahoo com> wrote in message
news:3957B67A.EEACDBD2@yahoo.com...
> thanks.
basalt
some
> > Mick
would
Care to explain in english!!!!
"Peter Popov" <pet### [at] usa net> wrote in message
news:4lfflso0j3b8m93i4e3oqu3j426l8dmcpb@4ax.com...
isn't
of
nobody
> I
to
> guess.
On Mon, 26 Jun 2000 22:05:15 +0100, "Mick Hazelgrove"
About the tileable pigment, Chris Colefax has a macro that would make
any texture tile seemlessly. Granted, a repetition *may* be noticed
but the probability would not be as high.
Now about the bounding quadtree. Imagine you have a big (and
relatively flat) grass patch consisting of, say, 32x32 smaller patches
whose bounds you know. Bound each patch into its own bounding box. You
now have 32x32 bounding boxes. Bow bound them in quads, 2x2 so that
you have 8x8 bounding boxes each of which has 2x2 bounded patches in
it. Then do this again so that you have 4x4 larger bounds, then again
to get 2x2 and finally bound them into a single box.
Why would you want to do that?
Imagine a ray-shape intersection test. A ray is shot from the camera.
If no bounding is used, it would have to be tested against each of the
32x32=1024 patches (consider them single objects for simplicity). With
a hierarchical bounding scheme such as the one described above, the
ray will first be tested against the outermost box, then if there's an
intersection it will be tested against the inner four and so on and
the test will traverse down the quadtree (quad because each 'branch'
has four sub-branches) and only follow those branches which are likely
to result in an actual intersection.
The best results would be achieved if the grass field is viewed from
above because the projections of the bounding boxes on the screen (the
vista buffers) would not overlap. I am sure a more efficient method
can be developed which would incorporate adaptive median subdivision
of the bounding boxes combined with minimizing the vista buffer
overlapping but I would probably leave this for povray.programming or
povray.unofficial.patches ;)
Hope it helps any.
In article <3957B67A.EEACDBD2@yahoo.com>, ryan constantine
> lays down?
Another possible use for the eval_*() functions...
BTW, I tried to do some tests of my own using 50,000 blades, and after 3
hours and a half of parsing, the machine gave me an out of memory message.
:-/ How do you do it? I only got as far as "Creating bounding slabs..."
Time to kick off the shoes and run barefoot.
That render-time says "no animation, nuh-uh".
> 45 mins to parse!
> Mick
Hmm, I counted only 399968 blades, seems like someone were left out of
frame...
Additionally I don't think that this picture will qualify as excellent
example of lawn: grass is in clumps and too long, seems like it hasn't
been rolled (??) couple of hundred years yet...
<j/k, pulling long face from envy.>
Suggest:
A white picket fence,
A cute little house,,
And something to do w/ children ( a swing set w/ swirly colors on the metal
or a nice wooden one),,,
> 45 mins to parse!
> Mick
> [Image]
