Posting this for the reason of showing a CSG-gone-wrong situation.
In the zoomed view of the dragonfly you will be able to see how a separate
cylinder doesn't mix with the rest of the object at all, it actually removes
(or more precisely, makes invisible) the parts behind it.
All I could figure is that maybe one of the new MegaPov features is somehow
acting upon it, such as the 'projected_through' or 'no_image', something
anyhow; although perhaps nothing to do with it. I put 'sturm' in the 'blob'
which is the part behind the cylinder. No CSG 'difference' is being done with
the blob itself, only 'union'. Here's that part of the pov script rendered
under MegaPov 0.5a:
union {
// wings left out for sake of brevity
blob {threshold .5
cylinder {-.125*y,0*y,.03,1 pigment {rgb<.3,1.2,2.5>} normal {gradient y .6
scale .06} finish {ambient .125 specular .25}}
cylinder {0*y,.125*y,.0375,1 pigment {rgb<.3,1.2,2.5>} normal {gradient y .6
cylinder {.125*y,.33*y,.0425,1 pigment {rgb<.3,1.2,2>} normal {gradient y .6
cylinder {.33*y,.5*y,.06,1 pigment {rgb<.6,.3,.1>} normal {gradient y .6 scale
sphere {<.02,.5,.035>,.03,1 pigment {rgb<.3,3,.09>} finish {ambient .25
specular .25 roughness .1}}
sphere {<.02,.5,-.035>,.03,1 pigment {rgb<.3,3,.09>} finish {ambient .25
// sturm
// legs object
difference {
cylinder {.33*y,.45*y,.05
pigment {gradient y turbulence .14 frequency 6
color_map {
[.3 color rgbf<.3,.6,.5,0>]
[.3 color rgbf 1]
} scale .2}
// interior {ior 1} // just a check for any ior error
cylinder {.333*y,.451*y,.025 translate .05*x pigment {rgbf 1}
cylinder {.333*y,.451*y,.025 translate -.05*x pigment {rgbf 1}
scale <.75,1,1> translate -.05*x
// end legs object
scale .0025 rotate 90*z rotate <10,190,15>
translate <3.25,.1025,.35>
I was also guessing it might have been the tiny scale used. It's not.
Anyway, enjoy the rendering. If there is a solution I'd love to hear it. TIA
anyone.
omniVerse http://users.aol.com/persistenceofv/all.htm
Download 'dfdesertisles.jpg' (33 KB)
Download 'dfcsg.jpg' (11 KB)
Preview of image 'dfdesertisles.jpg'
Preview of image 'dfcsg.jpg'
On Wed, 21 Jun 2000 17:29:10 -0500, Bob Hughes wrote...
> under MegaPov 0.5a:
What have you got max_trace set to?
That's about the only thing I can think of which might cause that sort of
effect, especially if you've got the bg colour set to white...
Bye for now,
Jamie.
"Alf Peake" <alf### [at] peake42 freeserve co uk> wrote in message
news:3954cfab@news.povray.org...
| Bob Hughes <per### [at] aol com?subject=PoV-News:> wrote in message
| news:39514220@news.povray.org...
| separate
| removes
| The only time I had a similar problem it was solved by raising
| max_intersections.
| Check your stats for I_stack overflow.
I wasn't getting a I_stack overflow, tried raising max_intersections per your
suggestion anyway.
Thing is, I know what the problem is, or at least related to anyhow. It's the
very small scales I had been using. I've known that 'sphere' will begin to
deteriorate in strange ways at a scale of about >0.02 unit from what I had
learned, which is nearly the starting diameters of the blob components. Then
I further scaled down to 0.0025. What fooled me was that it rendered properly
outside of the CSG so I thought I was safe. Fact is, in using what I'd call
imprecise decimal numbers you always risk a degradation, especially of
'sphere' objects and quite obviously other primitives too ('cone' seems very
sturdy however). Keep in mind this is CPU and OS dependant stuff from what I
understand.
So, with the blob components being at around 0.02 or greater in diameter the
problem vanishes, if you'll pardon the pun.
Thanks for trying, you and the others. It was pretty stupid of me to struggle
over this with what I already understood.
