POV-Ray : Newsgroups : povray.binaries.images : Cylinder Hf ~ 2 images: 155kb, 94kb Server Time
20 Oct 2026 02:52:25 EDT (-0400)
  Cylinder Hf ~ 2 images: 155kb, 94kb (Message 1 to 8 of 8)
Subject: Cylinder Hf ~ 2 images: 155kb, 94kb
Date: 9 Jun 2000 18:48:12
Message: <3941743C.2D632C01@aol.com>
I've still been playing with eval_pigment. I've made code that takes a
pigment and makes sort of a heightfield from it using cylinders and
spheres. The color at each vertex is blended with the next, achieving
color-interpolation.
The first image is the Van Gogh painting again, with diffuse 0 and
ambient 1 to show off the color-interpolation.
The second image is the Mona Lisa. She has 76,800 objects in her. Parse
took 54 seconds and the trace took 2 minutes, 37 seconds with AA. Peak
memory was 113158861 bytes.
I might post a macro to povray.text.scenes-files, although I think
something like this has been done before... I'm not sure.
Any questions or comments?
Samuel Benge
E-Mail: STB### [at] aolcom
Visit my isosurface tutorial at http://members.aol.com/stbenge
Download 'ipolate1.jpg' (155 KB) Download 'ipolate2.jpg' (94 KB)
Preview of image 'ipolate1.jpg'
Preview of image 'ipolate2.jpg'
Subject: Re: Cylinder Hf ~ 2 images: 155kb, 94kb
Date: 9 Jun 2000 19:29:45
Message: <39417DE9.7D2685F3@gmx.de>
That sounds like a good idea, at least for noisy, low resolution images
I like the your Mona Lisa, the face looks a bit messy.  perhaps it would
help making it even more detailed :)
I thought about the comparison with heightfield you mentioned and had
the idea, that hexagonal basalt-structures you can see in vulcanic
regions could easily be modelled using this technique, maybe I will try
that sometime...
Making a macro sounds like a good idea, I am looking foreward to see it.
Date: 9 Jun 2000 19:45:13
Message: <39418229.DFAE3DBB@aol.com>
Part of the reason Mona looks so bad is that all the dark parts force the
cylinders downward, which includes the shadows on her face.
> that sometime...
I don't know how to go about doing that, at least if the columns are going to
be perfect hexagons. I could think of how to do one that has slightly
squished hexagonal columns...
It will have a problem I don't want to fix: the problem being that two sides
of the grid will have cylinders hanging out, while the other two won't.
Fixing it would mean increasing parsing time.
Samuel Benge
Date: 9 Jun 2000 19:50:42
Message: <39418374.44A311F7@aol.com>
Never mind that last thing I said. I forgot all about the ever-useful #if
statement! Call it fixed.
> Samuel Benge
Samuel Benge
Date: 10 Jun 2000 03:51:03
Message: <3941F368.E9FFD86D@gmx.de>
> > that sometime...
I found two links for better understanding:
http://cyberfair.gsn.org/Nespelem/Basalt_Columns_.html
http://home.t-online.de/home/realschule.linz.rhein/basalt.jpg
IIRC the columns are about 20cm diameter and quite irregular, no single
crystals, but that does not seem important to me because I like to place
them as objects like the cylinders.
Date: 11 Jun 2000 17:23:44
Message: <8F5091117spammindspringcom@204.213.191.228>
chr### [at] gmxde (Christoph Hormann) wrote in
<3941F368.E9FFD86D@gmx.de>:
Also take a look at
http://www.interknowledge.com/northern-ireland/ukiant01.htm
and the many other web sites with pictures of Giant's Causeway in Northern
Ireland.  These columns are several feet across.
Rich Allen
(Remove SPAM from my address to reply by e-mail)
Date: 13 Jun 2000 15:16:17
Message: <39468762.EB217400@faricy.net>
Yep, this is definitely a signal from an intelligent life form...
(Still thinking about those SETI graphs)
Date: 20 Jun 2000 11:47:13
Message: <01bfdacf$8d0eb520$9f1ba1d0@mk>
That macro is pretty amazing .. take any picture and make it into a
latch-hook
template =)
Seriously, what a cool idea.  Try some other famous works.  I wonder how a
pointillist painting shows up on this.
