POV-Ray : Newsgroups : povray.binaries.images : Twisted Lathe (35 KB) Server Time
20 Oct 2026 03:38:46 EDT (-0400)
  Twisted Lathe (35 KB) (Message 1 to 19 of 19)
Subject: Twisted Lathe (35 KB)
Date: 3 Jun 2000 19:34:32
Message: <3939960B.D322FE9B@hotmail.com>
Here is the result of my recent experimenting
with lathe macros (cubic_spline).
One macro generates the basic 2D lathe co-ordinates
(as in my postings to this news group 23. May
and 25. May).
And then some other macros I made recalculates
these co-ordinates for further "twists" and does
all the necessary cuts, "tilts" and translations.
I believe that the re-calculated lathe co-ordinates
can also be used and for prism shapes connected
to such lathe shapes. (I have not done this yet.)
Any comments or suggestions ?
Tor Olav
mailto:tor### [at] hotmailcom
Btw: This twisted lathe has a "minor radius"
defined by this function:
2/3*cos(4*Phi) - 1/3*sin(6*Phi - pi/2)
Download 'lathemacro05_08.jpg' (35 KB)
Preview of image 'lathemacro05_08.jpg'
Subject: Re: Twisted Lathe (35 KB)
Date: 3 Jun 2000 21:01:08
Message: <3939aa54$1@news.povray.org>
Remarkable object.  Is it made up of tens, hundreds, or thousands of
individual pieces?
Date: 3 Jun 2000 21:18:13
Message: <3939AE63.538A520A@hotmail.com>
> individual pieces?
It's made of 10 individual lathe pieces.
Tor Olav
Date: 3 Jun 2000 21:27:22
Message: <3939b07a@news.povray.org>
Ah, okay, thanks.  I was going to guess that and then figured the spline might
be consuming more.
"Tor Olav Kristensen" <tor### [at] hotmailcom> wrote in message
news:3939AE63.538A520A@hotmail.com...
| > Is it made up of tens, hundreds, or thousands of individual pieces?
Date: 3 Jun 2000 21:36:10
Message: <3939B367.8323DA92@yahoo.com>
very cool.  could be used for curved hand rails, snakes going over
terain, or something like that.  is it random? or do you have control?
> and 25. May).
> Tor Olav
> http://www.crosswinds.net/~tok/tokrays.html
Date: 3 Jun 2000 21:51:43
Message: <3939B63E.A6C4A70D@hotmail.com>
ryan constantine wrote:
> very cool.
Thank you.
No it's not random.
These are real lathe objects (in plain POV-Ray
v3.1) where each is made up by many 2D control
points (macros re-calculates these points for
each lathe segment.)
Other macros cuts the lathe objects into segments
and puts them into their positions.
I have control, but at the moment I have not
finished the "front end" macro so it's a little
bit cumbersome to gain exact control over the
overall shape.
Date: 4 Jun 2000 05:33:45
Message: <393a2279$1@news.povray.org>
Yess! I'd like to see the finished macro for this. It's almost like a new
primitive!
Simen.
Date: 4 Jun 2000 15:08:14
Message: <393AA91E.E8D6E5C7@gmx.de>
This would be really nice for roads, rails, etc. following a terrain
surface in height and slope (for example using megapov's hf_height_at
feature).
I am waiting for a public version :)
Date: 5 Jun 2000 19:03:04
Message: <393C313A.9D97C790@online.no>
> be consuming more.
Yes. I had a feeling that you had already guessed the answer,
and that you just wanted to be sure.
Tor Olav
Date: 5 Jun 2000 19:15:34
Message: <393C342C.C3C042B1@online.no>
> primitive!
I have thought about doing this with torii for a long time.
But when I discovered how I could make a macro pass
an array of 2D points to a lathe, then I just had to try
it with lathes.
And when I saw that it worked, I said the same as you:
Yess!
It will take some time to finish the macro, so I'll post the
source code for the image as it is now.
And when I think that the macro set is finished, I'll post
again.
Tor Olav
Date: 5 Jun 2000 19:23:30
Message: <393C3603.7A9CA7E6@online.no>
Good ideas !
Thank you.
> feature).
Sounds interesting. Does that feature allow one to
"wrap" a height field around any shape ?
I'm working on it. And I'll post it when it's finished.
If you're interested in having a look at some preliminary
code, you can peek at the code I am about to post.
Tor Olav
Subject: Re: Twisted Lathe - Illustration of method (66 KB)
Date: 5 Jun 2000 19:25:36
Message: <393C3682.2374411F@online.no>
This image shows how the "Twisted" lathe shapes are assembled
from several lathe segments.
This time I entered the 2D co-ordinates for the red lathe shape
(linear_spline) by hand into an array. The yellow spheres shows
where these points "travels" in 3D for each lathe segment.
The blue shape shows how similar things can by achieved with
cylinders. (I think there are some macros out there for doing
different kinds of cylinder "spaghetti".)
The cyan cylinders represents the axes that the different
segments are turned "around". (They are of coarse created at
origo and then tilted and translated to their final positions.)
The transition from one segment to another always happens in a
plane. And the rotation centres of both these segments also
have to lie in this plane.
At this moment my macro takes an array of such planes as an
argument together with the initial array of 2D points for the
lathe. It also needs a 3D reference point; ("Origo" for the 2D
co-ordinates) that "walks" from line to line (magenta spheres).
For every subsequent pair of planes in the array of planes it
calculates the lines I mentioned above. (These lines are the
intersections of each subsequent pair of planes.)
Currently I am investigating possible methods for gaining a
more intuitive control over the final shape.
There are several possible methods, but finding a good one is
not easy (for me). (And if everything else "fails", I may have
to use iterative numerical methods to help the users achieving
a path as close as possible to their "wish"-path.)
Tor Olav
Download 'lathemacro05_10_03.jpg' (66 KB)
Preview of image 'lathemacro05_10_03.jpg'
Date: 5 Jun 2000 19:54:10
Message: <393C3D3F.D5076A0C@online.no>
> cylinders.
Ehh... I meant torii.
Sorry.
Tor Olav
Date: 6 Jun 2000 04:36:24
Message: <393CB809.13AFEC3A@gmx.de>
> > feature).
No, it just gives back the height at a specific point, allowing
automatic placement of objects on the surface.
Date: 6 Jun 2000 19:36:25
Message: <393d8af9@news.povray.org>
it looks nicely complicated, well done !!
Date: 6 Jun 2000 22:40:57
Message: <393DB5D9.EE109890@online.no>
Serge LAROCQUE wrote:
> I am reminded of a Simpsons episode (everything reminds of a Simpsons episode
> ;) ) in which someone mentioned a Play Doh factory, then they showed it, there
> was a giant ruler with holes of various shapes (star, triangle, etc). Then the
> foreman called for a "Crescent moon, crescent moon", and you would see it
> squeeze through the crescent-moon-shaped hole and go onto a waiting truck :-)
Sorry. I like the Simpsons, but I haven't seen more
than a few Simpsons episodes.
I can imagine that squeezing something soft through
different shaped holes would create similar shapes to
my "Twisted" shapes.
But I'm afraid that since I'm not a native speaker of
english, there may be something in the humour in the
episode you mention that I don't understand.  :(
E.g.: Are there any US-word games in there ?
And what is Play Doh ?
Tor Olav
Date: 6 Jun 2000 22:45:41
Message: <393DB6E9.6EA00397@online.no>
> Rick
Makes me smile. Because I have never thought that
anything could be described as "nicely complicated".
Thanks.
Tor Olav
Date: 6 Jun 2000 23:09:45
Message: <393dbcf9@news.povray.org>
"Tor Olav Kristensen" <tto### [at] onlineno> wrote in message
news:393DB5D9.EE109890@online.no...
episode
If I had said it (Play Dough) you might have understood better then  :-)
Something I'm not sure was noticed here is that Homer Simpson is famous for
his remarking "Doh!" all the time.
The Play Doh factory thing must have been a vision someone was thinking, a
childs toy turned into real place kind of thing.
Subject: Re: Twisted Lathe - Source code posted
Date: 12 Jun 2000 10:33:42
Message: <3944F4D6.7B8D5D1@hotmail.com>
Last week I wrote that I were about to post
the source code for this image.
Unfortunately I have been so busy with other
projects, that I have not had time to clean
up my code and post it. Sorry.
I have now posted it to:
news:povray.text.scene-files
Tor Olav
