POV-Ray : Newsgroups : povray.binaries.images : Diamond ring Server Time
20 Oct 2026 03:40:22 EDT (-0400)
  Diamond ring (Message 1 to 19 of 19)
Subject: Diamond ring
Date: 31 May 2000 03:54:24
Message: <3934C436.59597EF6@dod.no>
A girl would love to get this... alas, the diamond is too bright, and I
don't understand why. :-(
Børge Berg-Olsen
  +47 90 62 71 78          DoD#2101, DoDRT#017, NIC#015, PJ#006, OGM#007
  azo### [at] dodno, Ducati M600              Ubesudlet: Aldri eid en J&%#PS.
Download 'ring.png' (58 KB)
Preview of image 'ring.png'
Subject: Re: Diamond ring
Date: 31 May 2000 06:09:40
Message: <3933963C.543AAFE0@earthlink.net>
it looks as though it is on fire, glowing, lit intensively from above or all
of the above...
> Børge Berg-Olsen
Date: 31 May 2000 11:42:12
Message: <slrn8ja3tv.30o.sjlen@zero-pps.localdomain>
The diamond looks way too bright.
  2:00pm  up 13:31,  2 users,  load average: 2.05, 2.09, 2.08
Date: 31 May 2000 13:44:30
Message: <39354f7e@news.povray.org>
> Børge Berg-Olsen
Hey, maybe that is what a diamond looks like to a girl.
Date: 31 May 2000 20:19:12
Message: <3935ac00@news.povray.org>
Usually 'ignore_photons' is used within a glass (or similar) objects photon statement.
That's what appears to be wrong here.
"Børge Berg-Olsen" <azo### [at] dodno> wrote in message news:3934C436.59597EF6@dod.no...
Date: 31 May 2000 23:11:58
Message: <3935d47e@news.povray.org>
The diamond looks like a light source itself!
Date: 1 Jun 2000 11:16:47
Message: <39367E59.780F3E3A@hotmail.com>
Nice ring.
But the surface seems a little bit uneven.
Is it made of "white" gold ?
The source for the diamond I posted to
povray.binary.scene-files has several light
sources strung up inside the diamond shape.
So if that is the code you are using, then just
use Diamond instead of LitDiamond.
Or just decrease the 0.15 number in the DimLight
declaration to make the lights dimmer.
Tor Olav
mailto:tor### [at] hotmailcom
Date: 4 Jun 2000 15:01:08
Message: <393AA77B.25263E31@kyrre.net>
statement.
Diamonds become white in pov for some reason, regardless of photons. The
attached image uses no photons, only difference is max trace: 15 for the
left one and 4 on the right. Any idea why?
    pigment {color rgb <.81,.88,.97> filter .94 }
    interior {
         ior 2.417
         fade_power 1000 fade_distance 15
    finish { reflection_min .03 reflection_max .5 reflection_falloff 1 }
sig
ICQ 74734588
Download 'cut1.jpg' (11 KB)
Preview of image 'cut1.jpg'
Date: 4 Jun 2000 16:43:48
Message: <nnfljsk5irulssr3p8tasvserfbg6m17tm@4ax.com>
On Sun, 04 Jun 2000 21:01:15 +0200, Sigmund Kyrre Aas
Any ray that exceeds the max_trace_level is given the background color
which is black by default (but you can change it, of course).
Peter Popov ICQ : 15002700
Date: 4 Jun 2000 17:05:06
Message: <393AB1D3.D13C3152@kyrre.net>
Background is black, diamond becomes white as max trace level increases.
ICQ 74734588
Date: 4 Jun 2000 17:31:36
Message: <heiljs46cg9lepgrtrfo0gjtlh06bp4pl2@4ax.com>
On Sun, 04 Jun 2000 21:45:23 +0200, Sigmund Kyrre Aas
Ah, I see... you're not giving it a filter or transmit greater than 1
so that's not the problem... You know what, try using conserve_energy.
I can see how it could be a problem with a lot of TIR taking place.
Date: 4 Jun 2000 22:49:45
Message: <393b1549@news.povray.org>
"Peter Popov" <pet### [at] usanet> wrote in message
news:heiljs46cg9lepgrtrfo0gjtlh06bp4pl2@4ax.com...
More of the diamonds' inside showing up due to internal reflection as Peter
has said.
I was going to suggest that too.
Date: 6 Jun 2000 12:11:51
Message: <393D22AE.84DA29E9@dod.no>
> has said.
Sorry, I've been away with workrelated stuff. Where should the
conserver_energy statment go, and is there any documentation of the
statement?
Thanks! :-)
Børge Berg-Olsen
Date: 6 Jun 2000 14:11:57
Message: <k8ed7lu7k82.fsf@jeeves.stud.ntnu.no>
Peter Popov <pet### [at] usanet> writes:
Aha! So that's what conserve_energy is. Thank you very much. I've made a
low-quality render which looked very promising. (8+1 hours photons+trace)
I'll tweak some more and post it so Steve et al. can have a go with it.
sig
Date: 6 Jun 2000 14:16:07
Message: <393D3FFF.4AD3A29D@209software.com>
It's POSSESSED!
Bryan Valencia
Software Services - Making Windows Scream
http://www.209software.com
mailto:bry### [at] 209softwarecom
Date: 6 Jun 2000 14:17:42
Message: <k8eaegy7jyh.fsf@jeeves.stud.ntnu.no>
Børge Berg-Olsen <azo### [at] dodno> writes:
It's a feature of Megapov. You really should get it :)
sig
Date: 6 Jun 2000 23:37:22
Message: <393dc372@news.povray.org>
"Sigmund Kyrre Ås" <as### [at] jeevesstudntnuno> wrote in message
news:k8e### [at] jeevesstudntnuno...
finish {conserve_energy}  in the objects texture statement  :-)  Just think of
it as a counterpart to 'reflection'.
Date: 7 Jun 2000 12:29:40
Message: <393E785D.7ED1B6E2@dod.no>
Duh! :-) I already got it... what do you think I traced the diamond ring
with, eh? My fingers?
Børge Berg-Olsen
Date: 7 Jun 2000 12:32:18
Message: <393E78FB.6EA42432@dod.no>
Alas, conserve_energy doesn't seem to help much on the way too bright
diamond. :-/
Børge Berg-Olsen
