POV-Ray : Newsgroups : povray.binaries.images : Problem with depth_thresh, Cartoon Tut! Server Time
20 Oct 2026 03:39:44 EDT (-0400)
  Problem with depth_thresh, Cartoon Tut! (Message 1 to 8 of 8)
Subject: Problem with depth_thresh, Cartoon Tut!
Date: 25 May 2000 18:26:11
Message: <392DA9CB.ADC2C195@infomaniak.ch>
In he first image, depth_thresh of find_edges is set to 1:
find_edges {1,.03,1,1.33,1,rgb 1}
and in the second, it is set to 10000 and so the big odd colored areas
are disapearing, but to the detriment of some edges.
See "Cartoon Tut!" in p.t.tutorials
DEPerere
Download 'ionic5_pp_nga.jpg' (17 KB) Download 'ionic5_pp_ngb.jpg' (15 KB)
Preview of image 'ionic5_pp_nga.jpg'
Preview of image 'ionic5_pp_ngb.jpg'
Subject: Re: Problem with depth_thresh, Cartoon Tut!
Date: 25 May 2000 18:30:14
Message: <392DAAAF.A5C9DC26@infomaniak.ch>
> DEPerere
I forget to say that I did used "Ionic5", Persistence Of Vision
raytracer version 3.0 sample file.
DEPerere
Date: 25 May 2000 18:56:46
Message: <392dafae@news.povray.org>
Could you, as an example, post the non-cartoon version of this picture?
Date: 25 May 2000 21:33:11
Message: <392dd457@news.povray.org>
DEPerere <per### [at] infomaniakch> wrote...
The optimal value of the depth threshold is very dependant on the size of
the scene geometry.  For example, in this scene, the geometry is rather
large.  Because of the size, two neighboring pixels that are on the same
surface may differ in depth by more than 1.0, causing an incorrect edge
detection.  This perticular scene contains rather large objects.  A depth
threshold of 6.0, for example, will detect the depth edges but not cause
those 'shadows'.
-Nathan
Subject: Re: Problem with depth_thresh, [22k]
Date: 26 May 2000 18:19:24
Message: <392EF6AC.D3B4539@infomaniak.ch>
This image is a bit different on the lower part, but more similar of the
original made by Mike Miller.
DEPerere
Download 'ionic5.jpg' (22 KB)
Preview of image 'ionic5.jpg'
Date: 26 May 2000 18:19:25
Message: <392EF99C.5BDDFA9A@infomaniak.ch>
> those 'shadows'.
> -Nathan
Thanx for the explanation. 2.5 is a quite good value here. There's still
same little pieces of edges missing, but without shadows.
If I'm changing the scales of the objects, do I've to change the
depth_thresh too?
DEPerere
Date: 27 May 2000 13:08:52
Message: <39300124$1@news.povray.org>
> depth_thresh too?
Yes.
-Nathan
Date: 27 May 2000 16:16:47
Message: <39303AC5.2E62DBF0@netvision.net.il>
I would love to see an animation of this
> DEPerere
>  [Image]  [Image]
