Guess how these images have been made (answers in reply):
Download 'image1.jpg' (23 KB)
Download 'image2.jpg' (41 KB)
Download 'image3.jpg' (40 KB)
Preview of image 'image1.jpg'
Preview of image 'image2.jpg'
Preview of image 'image3.jpg'
Image 1:
intersection
{ cylinder { -x,x,1 }
cylinder { -y,y,1 }
cylinder { -z,z,1 }
cylinder { <-1,-1,-1>< 1, 1, 1>,1 }
cylinder { < 1,-1,-1><-1, 1, 1>,1 }
cylinder { <-1, 1,-1>< 1,-1, 1>,1 }
cylinder { < 1, 1,-1><-1,-1, 1>,1 }
Image 2:
union
{ #declare Angle=0;
#while(Angle<360)
torus { 1,.05 rotate z*45 translate -x*.3 rotate y*Angle }
#declare Angle=Angle+30;
Image 3:
union
{ #declare Angle=0;
#while(Angle<360)
union
{ cylinder { <0,-1,-.75>, <.75,1,.5>, .025 }
cylinder { <0,-1,-.75>, <-.75,1,.5>, .025 }
rotate y*Angle
#declare Angle=Angle+10;
torus { .75, .025 translate -y }
torus { vlength(<.75,0,.5>), .025 translate y }
> Image 3:
> union
> { #declare Angle=0;
> #while(Angle<360)
> union
> rotate y*Angle
> #end
any reason for using vlength??
-paul
Paul Daniel Jones
307 Chandlee Laboratory
Penn State University
814-865-2090
pdj### [at] psu edu
http://research.chem.psu.edu/glassgrp/paul
I was going to guess "CSG", but then you posted the answers. I think you're
supposed to keep us guessing for little while before you do that. :)
with povray.
Mike
wk: mik### [at] pyxis com www.pyxis.com
hm: mwe### [at] sciti com www.geocities.com/mikepweber
"Warp" <war### [at] tag povray org> wrote in message
news:391948c4@news.povray.org...
Paul Daniel Jones <pdj### [at] psu edu> wrote:
:> torus { vlength(<.75,0,.5>), .025 translate y }
: any reason for using vlength??
Yes: Laziness.
It was easier than calculating sqrt(.75^2+.5^2) = .9013878188 and putting
that (inaccurate) result there.
With a raytracer perhaps?
SCNR
Markus
or... a computer?
Mike
"Markus Becker" <mar### [at] student uni-siegen de> wrote in message
news:391### [at] student uni-siegen de...
> SCNR
> Markus
Warp,
Thanks for that - much appreciated!
I don't know about anyone else, but my brain is extremely receptive to
the "simple example, then code" method of teaching, and those three
examples were right on the mark.
Anyone know of a website out there which has more of this sort of stuff,
presented in this fashion?
I checked your VFAQ which pointed to:
http://www.povray.org/links/
POV-Ray_Include_Macro_and_Object_Files/
Object_and_Scene_Files/
...but decriptions like "POV-Ray scene files and objects -Misc" doesn't
really do much to inspire _my_ imagination.
A two-column table. Simple image on the left, code snippet on the
right. That's all I'm after.
Thanks again.
Henry.
In article <39196fa1@news.povray.org>, Warp <war### [at] tag povray org>
wrote:
> Yes: Laziness.
> putting that (inaccurate) result there.
I wouldn't call it laziness, I would say it is good style. It allows you
to easily change the code later for different parameters, and there
isn't any reason not to use an available function for it's intended
purpose.
Oh, and in MegaPOV, "sqrt(0.75^2 + 0.5^2)" would work just fine(the ^
operator has been added), and you could use "sqrt(pow(0.75, 2) +
pow(0.5, 2))" in official POV.
Christopher James Huff - Personal e-mail: chr### [at] yahoo com
TAG(Technical Assistance Group) e-mail: chr### [at] tag povray org
Personal Web page: http://chrishuff.dhs.org/
1) Intersecting cylinders
2) Rotating torii
3) Rotating cylinders (and it's a hyperbola BTW :-p)
And I haven't read any replies yet
David Fontaine <dav### [at] faricy net> ICQ 55354965
This one is cool.
(And this time you'll have to figure out the code yourself):
Download 'image.jpg' (36 KB)
Preview of image 'image.jpg'
Warp wrote in message <391a8be3@news.povray.org>...
> This one is cool.
torii, centered just to one side of the centre of that object,
rotated and translated around.
Gail
* gsh### [at] monotix co za * Reality.dat not found *
* http://www.rucus.ru.ac.za/~gail/ * Attempting to reboot universe *
* The best way to accelerate Windows NT is at 9.8 m/s^2 *
Warp wrote:
> This one is cool.
Yes.I think so too.
It looks familiar. Heres how I did it:
#declare MajR = 5;
#declare MinR = 1.5;
#declare SmallTorus = torus { MajR, 0.25 }
#declare TVector = MajR*y + MinR*z;
#declare TVector = TVector - 2.5*y; // Remove this line to get a proper torus
#declare TiltedTorus = vtilt(SmallTorus, TVector)
object {
CircleSpread(TiltedTorus, MinR, 24)
pigment { color Green }
(See below for the rest of my code.)
Tor Olav
mailto:tor### [at] hotmail com
#macro VectorAngles(Vector)
<acos(vnormalize((x+z)*Vector).x)*(Vector.z < 0 ? -1 : 1),
acos(vnormalize(Vector).y),
0>
#end // macro VectorAngles
#macro vtilt(Thing, TVector)
#local RotateAngles = VectorAngles(TVector);
object {
Thing
rotate degrees(RotateAngles.x)*y
rotate -degrees(RotateAngles.y)*z
rotate -degrees(RotateAngles.x)*y
#end // macro vtilt
#macro CircleSpread(Thing, Radius, Nr)
#local deg = 360/Nr;
#local MaxCnt = int(Nr);
#local Cnt = 0;
merge {
#while (Cnt < MaxCnt)
object {
Thing
translate Radius*x
rotate Cnt*deg*y
#local Cnt = Cnt + 1;
#end // while
#end // macro CircleSpread
#declare MajR = 5;
#declare TiltedTprus = vtilt(SmallTorus, TVector)
object {
CircleSpread(TiltedTprus, MinR, 24)
torus {
MajR, MinR
pigment { color Red }
Actually it's a bit simpler:
union
{ #declare Angle=0;
#while(Angle<360)
torus { 1,.04 rotate z*30 translate z*.25 rotate y*Angle }
#declare Angle=Angle+15;
> union
> { #declare Angle=0;
> #while(Angle<360)
> #end
I knew that it could be done that way.
But I did it my way! =)
Since I'm lazy when it comes to laborious math calculations,
I first defined the important parameters and then let the
macros (which I already had) do the calculations.
And btw:
How would you for instance calculate the dimensions of the
bounded_by shapes if you where to model shapes like the one
I posted in TorusClutter?
For that TorusCluster it was just:
bounded_by { torus { MajR, MinR1 + MinR2 } }
for the "first" level and
bounded_by { torus { MajR, MinR1 + MinR2 + MinR3 } }
for the "second" level
Tor Olav
> union
> { #declare Angle=0;
> #while(Angle<360)
> #end
Slightly simpler: change the relevant line to
torus { 1, 0.04 translate x*0.25 rotate <30,Angle,0> }
Anton Sherwood -- br0### [at] p0b0x com -- http://ogre.nu/
