POV-Ray : Newsgroups : povray.binaries.images : radiosity lighting Server Time
24 Nov 2026 12:29:32 EST (-0500)
  radiosity lighting (Message 1 to 9 of 9)
Subject: radiosity lighting
Date: 5 May 2000 20:12:03
Message: <39136374.EA798673@209software.com>
Ok, I am using radiosity lighting, and I want my little (ambient 1)
gizmos to throw off a LOT of light., but they are only having an
effect for a very short range.  What should I change to make the light
cast for about 100+ units?
here are my settings.
global_settings{
  radiosity{
   brightness 5      //float value that is the degree to which ambient
values are brightened (3.3)
   count 50           //number of rays that are sent out  (100)
   distance_maximum 1  // (required) sets the distance in model units
from a sample at which the error is guaranteed to hit 100% (0)
   error_bound .01      //the fraction of error tolerated(.4)
   gray_threshold .8   //grays it down a little, to make your scene
more believable (.5)
   low_error_factor .6 //sets the amount that the error bound is
dropped during the preliminary image passes(.8)
   minimum_reuse .0015  //the fraction of the screen width which sets
the minimum radius of reuse for each sample point (.015)
   nearest_count 10     //the maximum number of old ambient values
blended together to create a new interpolated value (6) (<4 for
debugging)
   recursion_limit 1  //how many recursion levels are used to
calculate the diffuse inter-reflection. Valid values are one and two.
(1)
  ambient_light <.3,.3,.3>
  assumed_gamma   1
Bryan Valencia
Software Services - Making Windows Scream
http://www.209software.com
mailto:bry### [at] 209softwarecom
Subject: Re: radiosity lighting
Date: 5 May 2000 20:27:01
Message: <h2YTOS9IEtDJYyU89aeRgu7w60YN@4ax.com>
On Fri, 05 May 2000 17:12:37 -0700, Bryan Valencia
<bry### [at] 209softwarecom> wrote:
>What should I change to make the light cast for about 100+ units?
First, you need to ask this question on povray.general, or perhaps on
povray.advanced-users
You will find much better help that way.
( Remove the "7" from 7no### [at] ezwvcom to email me. )
Date: 6 May 2000 00:44:59
Message: <3913A2A4.4B5E03DB@faricy.net>
try ambient >1
David Fontaine     <dav### [at] faricynet>    ICQ 55354965
Please visit my website: http:/www.faricy.net/~davidf/
Date: 8 May 2000 12:02:10
Message: <3916E51F.9239A2E@209software.com>
David Fontaine wrote:
> try ambient >1
You can do that?
Bryan Valencia
Date: 8 May 2000 13:56:02
Message: <3916FF27.FF733980@pacbell.net>
> > try ambient >1
> You can do that?
Yes. You can also use color values greater than one in both pigments
and light sources.
Subject: Re: radiosity lighting (holy cow)!
Date: 8 May 2000 14:48:41
Message: <39170C27.26CC1B61@209software.com>
Thanks Ken;
    This is my "gravship" using only radiosity lighting.
    There are no light_sources at all.
    It rendered in MegaPOV in LESS THAN 3 MINUTES!
    This rocks! I am going to do that animation now!
> > > try ambient >1
> > You can do that?
> and light sources.
> Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
Bryan Valencia
Download 'gravship.jpg' (9 KB)
Preview of image 'gravship.jpg'
Date: 8 May 2000 18:30:53
Message: <39173F66.E4AFBC73@faricy.net>
I think the mabient value on the ship is a tad high, but it looks good.
Date: 9 May 2000 09:14:28
Message: <39180f34@news.povray.org>
Like night and day.  Nice going.
Many radiosity renders aren't so drastically changed.
But I wonder of the proposed animation...  the shift in positions
for either or both camera and ship might prove different than expected since
I'd think the perceived lighting might switch around a lot.  Well, might be okay
if enough 'count' is used I'm guessing.
"Bryan Valencia" <bry### [at] 209softwarecom> wrote in message
news:39170C27.26CC1B61@209software.com...
| Thanks Ken;
Date: 9 May 2000 10:03:36
Message: <39181AB3.C6F0DE69@iname.com>
> > try ambient >1
> You can do that?
	You can even use negative values for special effects (won't
help for your problem, but I thought it worth mentionning).
		Jerome
******************************* Jérôme M. BERGER
