POV-Ray : Newsgroups : povray.binaries.images : Media Trouble Server Time
24 Nov 2026 12:39:05 EST (-0500)
  Media Trouble (Message 1 to 4 of 4)
Subject: Media Trouble
Date: 29 Apr 2000 10:36:42
Message: <390AF473.559D7F18@rapidnet.com>
I have been working on a project using P.O.V.-Ray 3.1's media
functions to simulate a space environment. The most obvious way to do
this is to use media independanty, but I can't get anything more that
random dots of color, sparsely placed around the screen. If, however, I
use media internally, I get somewhat better results, but the major part
of the picture is engulfed in a white blob which, though it is
interesting, leaves little space for anything else in the scene.
Do you have any suggestions on how I might shrink the "Star" at the
center of my image so that it appears as though viewed from a great
distance, or can you direct me to a more in depth tutorial on the
subject of Media in objects and athmosphere?
ban### [at] rapidnetcom
Download 'solar.jpg' (122 KB)
Preview of image 'solar.jpg'
Subject: Re: Media Trouble
Date: 29 Apr 2000 12:44:42
Message: <3909C2A5.5CC2999A@earthlink.net>
A beautiful image indeed, i would love to see the code...
(1) Try scaling the density alone...
(2) Try scaling the container flat to give space in the foreground...
(3) Move the camera...?
I love media... =)
Date: 29 Apr 2000 13:54:21
Message: <390b21cd@news.povray.org>
Using a spherical 'density_map' you would just say:
[0.5 rgb 0]
[0.75 rgb 1]
for example to get a outer half of a sphere clear then reach full density
at 3/4 the way in.
Also could use predefined densities in place of the 'rgb' so that
there are differing types for outer and inner.
Just create however many density {density_map}} statements
you need.
Date: 29 Apr 2000 15:48:24
Message: <chrishuff_99-429444.14512829042000@news.povray.org>
Well, I will just ignore the fact that space is largely a vacuum then...
> The most obvious way to do this is to use media independanty, but I
> can't get anything more that random dots of color, sparsely placed
> around the screen. If, however, I use media internally, I get
> somewhat better results, but the major part of the picture is
> engulfed in a white blob which, though it is interesting, leaves
Are you talking about media without and with a container object?
It is always a good idea to put media in a container object of some
kind, it avoids a lot of problems.
Try increasing the samples a bit(to get rid of some of the grainyness)
and decrease the density of the media by a large amount. The density is
controlled by the color of the media, if the color is too bright, things
get washed out. You may also want to try different scattering models, I
would suggest type 2 or 3.
It is hard to give any more help without access to the source for the
scene, could you post it to povray.text.scene-files?
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
