While working with one of my latest macros, this is one of the
images that appeared.
Tor Olav
mailto:tor### [at] hotmail com
Download 'roundoffplanes22.jpg' (60 KB)
Preview of image 'roundoffplanes22.jpg'
nice.... very nice. I think a diffuse shadow would put the icing on the
cake.
-paul
> Tor Olav
> http://www.crosswinds.net/~tok/tokrays.html
> [Image]
Paul Daniel Jones
The Pennslyvania State University
pdj### [at] psu edu
http://research.chem.psu.edu/glassgrp/paul
C The way is near, but men
// \ seek it afar. It is in the
N N easy things, but men seek it
| || in the difficult things.
C C -Menicius
C
"Paul Jones" <pdj### [at] psu edu> wrote in message news:3906DBC2.3524E3A8@psu.edu...
| cake.
If not a diffuse shadow maybe at least some ambient light in the shadows
could be good too. It's kind of reptilian in nature, isn't it?
A little softening of the shadows would help. Nice colors!
David Fontaine <dav### [at] faricy net> ICQ 55354965
Please visit my website: http:/www.faricy.net/~davidf/
On Wed, 26 Apr 2000 13:30:09 +0200, Tor Olav Kristensen wrote:
>This is a multi-part message in MIME format.
>--------------D00171870401AA08EF3CB13D
>Content-Type: text/plain; charset=us-ascii
>Content-Transfer-Encoding: 7bit
I like it, it's made it into the future wallpaper folder.
Steve email mailto:sjl### [at] ndirect co uk
%HAV-A-NICEDAY Error not enough coffee 0 pps.
or http://start.at/zero-pps
10:28pm up 29 min, 3 users, load average: 1.06, 1.02, 0.84
Paul Jones wrote:
> nice.... very nice.
Thank you very much!
> cake.
I agree. But I'm not sure how to do that.
Tor Olav
> could be good too.
I have tried to increase the ambient_light value but then I loose contrast
in the picture and the hexagons and pentagons becomes difficult to see.
Any suggestions?
Are you thinking of the skin of a reptile?
Hmmm ... interesting thought...
Tor Olav
I agree, but I'm not sure how to do that.
I have tried to increase the ambient_light, but then I lost some
contrast.
> Nice colors!
Thank you.
But I have to agree that I just copied a colour that Bob Hughes used
in some code when he replied on one of my postings:
gradient y color_map {[0,1 color rgb <.9,.2,.1> color rgb <.2,.4,.8>]}
Tor Olav
I'm glad you like it!
Maybe I should try it as a wallpaper too.
Tor Olav
By "diffuse" lighting I'm sure that's meant to be 'area_light' put into the
'light_source' statement. Gives it that fuzzy shadow look.
The global ambient would indeed ruin this picture. What I meant was
the 'ambient' increase only in the red background object. Of course,
that would also mean lowering either the color values or 'diffuse' in order
to keep the same color intensity for the part still in the light.
"Tor Olav Kristensen" <tto### [at] online no> wrote in message
news:3907937E.D2641389@online.no...
| contrast.
| > Nice colors!
| Thank you.
| Tor Olav
> contrast.
light_source { .... area_light <axis_1> <axis_2> size1 size2 [adaptive
[n]] [jitter [n]] }
The axes define the rectangular area the light_source occupies. The
"sizes" are actually resolutions, size1*size2 is the number of lights POV
must calculate for, more is better but slower.
jitter "jitters" the lights a bit for each pixel to eliminate banding, but
can sometimes give grainy results. A number after it is a multiplier used
on the default ammount of jittering.
adaptive makes POV use further subsampling based on contrast between
neighboring rays to further eliminate banding. Adaptive will not go beyond
<size1,size2> in resolution. Because adaptive can give innacurate results
by not filling in all areas, a number after it specifies the minimum
number of times the array is subsampled before adaptive sampling is used.
example: light_source { .... x*10 z*10 5 5 adaptive 1 }
this creates a 10x10 light along the x-z plane at whatever location, uses
a minimum of 9 rays per sample (3x3; the corners [adaptive 0] and then one
subdivision [adaptive 1]) and may use up to 25.
if you are still confused read the docs
Thank you again.
I'll try your suggestions.
Tor Olav
> Any suggestions?
Area lights can help soften shadows without adding too much extra brightness
to the scene.
> [n]] [jitter [n]] }
Thank you for explaining!
Just a little bit confused, but I'll think that I will try out your and Bob
Hughes' suggestions with some (or many :) renderings.
Tor Olav
> to the scene.
Thank you.
Bob Hughes and David Fontaine also suggested that I could use area lights.
So now I hope that it will not take 10 times longer to render the picture. :-)
(I think it took 4-5 hours to render the image.)
Tor Olav
news:39079BE1.32B9C94C@online.no...
No, not ten times. But it will seem like it.
> > to the scene.
> Thank you.
I wonder if placing red two disks where the shadows fall on the blossom(?)
and bringing up their ambient values could compensate for the dark shadows?
It'd be "cheating" but it might render faster than area lights.
It's a bit difficult for me to do that because the surface that the shadows fall on
are not flat.
That surface is actually a mix of a lot of "CSG-ed" shapes (involving planes,
cylinders and spheres) placed by a macro I made.
But thank you for commenting.
Tor Olav
