POV-Ray : Newsgroups : povray.binaries.images : A little abstract. - cracked.jpg Server Time
20 Oct 2026 15:20:05 EDT (-0400)
  A little abstract. - cracked.jpg (Message 1 to 8 of 8)
Subject: A little abstract. - cracked.jpg
Date: 4 Mar 2000 06:10:44
Message: <38c0ef34@news.povray.org>
There's gotta be a better way to NURBS into POV! This is just conversion
to smooth triangles. Check out the edges of the shadow.
Download 'us-ascii' (0 KB) Download 'cracked.jpg' (39 KB) Download 'us-ascii' (1 KB)
Preview of image 'cracked.jpg'
Subject: Re: A little abstract. - cracked.jpg
Date: 4 Mar 2000 10:37:35
Message: <38C12E17.471ACCC2@t-online.de>
...not so smooth, right?
Which tool did you use?
Karl
Date: 4 Mar 2000 11:30:45
Message: <38c13a35@news.povray.org>
Karl Pelzer <Kar### [at] t-onlinede> wrote in message
news:38C12E17.471ACCC2@t-online.de...
Right.
The object was created in Rhino and exported to POV as smooth triangles.
Date: 4 Mar 2000 23:27:56
Message: <ufo3csohsb0el96d3tois4ig131hsodhnv@4ax.com>
On Sat, 4 Mar 2000 11:32:37 -0500 "David Curtis" <spa### [at] junkmailcom>
  When exporting from Rhino, can the smoothing be user-adjusted?
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 6 Mar 2000 09:06:52
Message: <38c3bb7c@news.povray.org>
Hi David, indeed hi all as this is only my first proper post.
I've found that this works best if, in Rhino, you mesh each polysurface
individually using the 'Mesh' tool, rather than saving all NURBS to a POV
file with the default settings.
Also, when meshing, use the 'Detailed Controls' and play about with the
settings.  For best results, reduce the 'Max Angle' setting to an
appropriate value (this is the angle that the NURBS surface must sweep
through before a new facet is created and as you can imagine, the default
value of 20 is a bit 'dirty' and would only split a circle into an 18 sided
polygon).
Hope that helps :)
Damian
PS, Nice image :)
Date: 6 Mar 2000 11:20:32
Message: <38c3dad0$1@news.povray.org>
Damian Ridgley <dri### [at] wildeandpartnerscouk> wrote in message
news:38c3bb7c@news.povray.org...
sided
> polygon).
Damian, Thanks for your help. It seems that surface seams are the worst.
What I'd really like to see is a NURBS primitive in POV. Anybody else? There
seems to be a lot of resistance to the idea, but I don't understand why. So
old-schoolers with their hand-written code won't have any use for it, but
who cares? If they don't want it they don't have to use it. I'm not asking
anybody to program the code for the primitive, I'll do it myself. Hopefully
others would be interested enough to help.
Dave.
mic### [at] sympaticoca
Date: 6 Mar 2000 13:11:08
Message: <chrishuff_99-2DA3AC.13124906032000@news.povray.org>
In article <38c3dad0$1@news.povray.org>, "David Curtis"
> There seems to be a lot of resistance to the idea, but I don't
> understand why.
I think you misunderstand things. There isn't resistance to the idea of
adding a NURBS primitive to POV, just disinterest in going through the
work of coding and designing for a feature which is unuseable without a
modeller and which most people don't feel they need, and which many see
as being a modeller feature and not a renderer feature.
If you write a patch which adds a NURBS primitive, it will probably get
put into MegaPOV as soon as possible, but there won't be any people
using it until someone writes either a converter or a modeller which can
export to it. And until there are those tools, it almost definitely
won't get in the official version.(unless you write it so it can be
edited by hand)
> So old-schoolers with their hand-written code won't have any use for
> it, but who cares? If they don't want it they don't have to use it.
You imply that the people who hand code are stuck at a lower level and
are "behind the times". This simply isn't true. Most of the patch
writers are hand coders. Just testing the thing would be difficult
without any hand-editable test data.
Since there are already meshes and bezier patches, the only real reason
to add a NURBS primative would be adaptive subdivision. I think there
would be more interest in adding subdivision capabilities to meshes than
to adding a NURBS object.
> I'm not asking anybody to program the code for the primitive, I'll do
> it myself.
Then go ahead, nobody said anything about not adding an existing patch.
Unwillingness to volunteer time and energy to add a feature one sees as
useless to oneself and the majority of users does not equal resistance
to the idea of adding the feature.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 6 Mar 2000 15:55:36
Message: <38c41b48$1@news.povray.org>
Chris Huff <chr### [at] yahoocom> wrote in message
news:chrishuff_99-2DA3AC.13124906032000@news.povray.org...
No, I wouldn't imply that. I'm a hand coder myself. The 'old-schoolers' bit
wasn't necessary. Sorry.
Dave.
