POV-Ray : Newsgroups : povray.binaries.images : Great images.... but....why.... Server Time
20 Oct 2026 15:20:41 EDT (-0400)
  Great images.... but....why.... (Message 1 to 21 of 21)
Subject: Great images.... but....why....
Date: 29 Feb 2000 10:30:28
Message: <38bbe614$1@news.povray.org>
I like looking at the images readers submit here... but what I find in most
is that they are so dark and difficult to see.  Is it that most are
modelling and rendering by the glow of the CRT and I have a bright room?
Mike
Subject: Re: Great images.... but....why....
Date: 29 Feb 2000 10:42:58
Message: <38BBE88A.B1ADFD6@pacbell.net>
> Mike
Most use the gamma excuse but I personaly think most computer users
generaly have their brightness and contrast controls turned up too
high. To compensate for this they use lower ambient and diffuse
settings than would those who have their monitor controls set properly.
  A good example of this can also be seen in the way people adjust
the controls on their TV's. I cannot even begin to remember the
number of friends houses I have visited where they have the color
adjustments over driven and the brightness and contrast controls
set way to high for comfortable viewing levels. People in the
TV and monitor repair business often complain of the same kind
of consumer abuse and would actually prefer that there were no
user settable controls on these types of equipment. If they can
be abused they will be 9 out of 5 times by people that just don't
know what they are doing.
Date: 29 Feb 2000 12:17:01
Message: <38bbff0d$1@news.povray.org>
I think that many users (me included) don´t use much lights because of
render-time-reasons or don´t try (i will do so soon) to use lights with more
than 100% power (is this possible?).
And many of the pictures look better in a dark frame (like the one you put
on the wall). Looking in Windows-White darkens the picture a lot ...
Hartmut
Mike Weber schrieb in Nachricht <38bbe614$1@news.povray.org>...
>Mike
Date: 29 Feb 2000 13:29:04
Message: <38bc0ff0@news.povray.org>
Hmmm, how is "normal" defined? I would guess "something that most the
people do" comes quite close.
In this case: If "most" of the people use higher settings than "normal",
then probably those higher settings *are* normal? Maybe it is monitor/TV
manufacturers which set their machines to "unnaturally" low levels? ;)
Johannes.
"Ken" <tyl### [at] pacbellnet> wrote in message
news:38B### [at] pacbellnet...>
in most
room?
> > Mike
properly.
> Ken Tyler -  1300+ Povray, Graphics, 3D Rendering, and Raytracing
Links:
> http://home.pacbell.net/tylereng/index.html
http://www.povray.org/links/
Date: 29 Feb 2000 14:03:20
Message: <38BC178F.5BD416CC@kivisalo.net>
Here is a test image to correctly adjust the monitor.
Kari Kivisalo                                          www.kivisalo.net
Download 'adjust.gif' (27 KB)
Preview of image 'adjust.gif'
Date: 29 Feb 2000 14:28:10
Message: <38bc1dca@news.povray.org>
I can't even see the boxes in the middle with everything turned up!!!!
       http://www.minda.swinternet.co.uk/index.htm
"Kari Kivisalo" <kar### [at] kivisalonet> wrote in message
news:38BC178F.5BD416CC@kivisalo.net...
Date: 29 Feb 2000 15:21:23
Message: <38BC29E6.59B5472E@kivisalo.net>
Then your monitor needs some service adjustments or your display
adapter has been misconfigured (gamma,brightness,contrast etc.).
If it's none of the above I recommend Sony Trinitron monitors :)
This test image produces consistent results with different monitors
when compared for example to Photoshop 5 gamma utility so it should
be ok. The image was ripped from Nokia's monitor test software
http://www.nokia.com/monitors/download/ntest.html
Since Win* uses full white as default document background the desktop
becomes too bright for comfortable viewing when the monitor is adjusted
for optimum performance (for graphics work).
Date: 29 Feb 2000 15:57:09
Message: <38BC4027.8504D940@home.com>
Ken wrote:
 If they can
A guy's gotta have SOME fun!
Date: 29 Feb 2000 16:22:23
Message: <chrishuff_99-068C99.16235429022000@news.povray.org>
There actually are gamma differences between monitors, though. I have
taken the steps to "calibrate" my two monitors by eye, but since I use a
Mac with a lower gamma than PC's, my images might appear darker when
viewed on a PC with software that doesn't do gamma correction.
> If they can be abused they will be 9 out of 5 times by people that
> just don't know what they are doing.
Huh? They will be abused 180% of the time?
Chris Huff
e-mail: chr### [at] yahoocom
Date: 29 Feb 2000 16:22:59
Message: <38BC383A.FCF67BD8@skynet.be>
From my - modest - experience, it seems that commonground PC
monitors tend to have increasing gamma from year to year !
4-5 years ago, typical screens had a gamma of around 2.3,
but now it seems that 2.8 or higher is pretty common...
maybe it has something to do with the size increase ?
don't know.
I suspect many people doesn't know that their graphic card has
some gamma setting feature.  Tuning brightness and contrast on
the monitor is'nt a good solution, as it shifts everything...
When explained right, gamma is easy to understand and set.
Personally, I usually set my gamma to around 2.1-2.2 (while
the monitor is naturally around 2.8), which allows me to view
almost everything fine.
Fabien.
Date: 29 Feb 2000 16:57:03
Message: <38BC4006.3E2A3FEA@faricy.net>
Glare. Turn off your lights. Don't listen to Ken ;-) (But don't abuse your
monitor either)
A little experiment: leave any dumb ol' pic or window sitting on your montior.
Look at it. Turn off the lights. Look at it again.
___     ______________________________________________________
 | \     |_                 <dav### [at] faricynet> <ICQ 55354965>
 |_/avid |ontaine               http://www.faricy.net/~davidf/
"Sitting on a cornflake, waiting for the van to come" -Beatles
Date: 29 Feb 2000 18:12:24
Message: <38BC533F.A768385B@pilot.msu.edu>
trinitrons have 2 lines across the screen.  I don't like them.
Date: 29 Feb 2000 18:20:38
Message: <38BC53E1.454EB78@kivisalo.net>
Noticed here too (mine is 2.5).
Brightness affects gamma because it shifts the black level.
That test image is designed for brightness and contrast only.
The brightness adjustment sets the black level so that all
levels are visible. If a monitor cannot display all the low levels
then there is obviously something wrong with it. This has nothing
to do with monitor gamma. Contrast is adjusted to get full white
and is dependend on ambient light level. Gamma affects things in
between.
Yes. Find monitor gamma with http://www.povray.org/binaries/gamma.gif.
Put gamma/desired_gamma to the adapters gamma box. Adjust brightness
so that black isn't visible. Adjust contrast to get full white.
Now, if we get all the readers to set their monitors to some fixed
gamma then there wouldn't be threads like this :)
Date: 29 Feb 2000 18:20:39
Message: <38bc5447$1@news.povray.org>
The two lines on a trinitron-screen are technical needed, as anyone can
imagine. But the ability of such a tube to show the pictures without
disturbing *any* pixel-line with small grids makes the two lines acceptable.
Comparing trinitron (or other screens with same technique) to ones with
"old-fashioned" tubes makes the difference clear ...
Hartmut
PS : I don´t use a trinitron because of financial reasons, i have a 15"
noname-screen ...
Nick Portelli schrieb in Nachricht <38BC533F.A768385B@pilot.msu.edu>...
Date: 29 Feb 2000 18:45:03
Message: <38BC597B.D5B075B0@pacbell.net>
You catch on quickly :)
Date: 29 Feb 2000 20:09:26
Message: <38bc6dc6@news.povray.org>
So OT and yet so relevant to this group.
I like less color saturation on a television screen, to the dismay of many
people over the years.  It's really funny when I see someone's TV having primary
red for skintones and greens for grass or leaves I can't see in the real things.
All I have to do is look at the stuff around the TV to know things aren't that
vividly colored.  It's as though people want to be looking into a screen with
natural-times-3 color, a sort of neon light reality.  Back in the days of
Black&White television I guess the debate was how gray or how black and white it
ought to be.
Many times I tried to adjust peoples sets or at least try to convince them of
their misguidance and I would get turned away from my attempts.
Right this minute I'm in a room with one energy-saving fluorescent type bulb
overhead (made to look incandescent though) and the increase in the redness of
everything makes it look like sunset inside here at night.  Doesn't matter
though, I would still compensate and tone the red down on the TV or monitor,
which looks fairly blue.  Artificial lighting could be the most common cause of
the discrepancies, and even filtered daylight being very blue when artificial
lighting isn't used might tend to make a phosphorescent screen lack in color I
guess.
Anyway, I couldn't get that test image to work right I think.  It had me setting
the brightness down all the way to see it as instructed.
The POV-Ray gamma gif test had shown 2.1 as the best fit.
| > Mike
| Ken Tyler -  1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
| http://home.pacbell.net/tylereng/index.html http://www.povray.org/links/
Date: 1 Mar 2000 01:28:01
Message: <38BCB9A3.C34A10AE@geocities.com>
> Hartmut
> PS : I donīt use a trinitron because of financial reasons, i have a 15"
> noname-screen ...
Since I'm a computer professional, I make a good excuse and get Trinitron
exclusively. It has kept me a size smaller, or to getting a little less in the
computer, but having used them so much and compared them with others, the money
is well worth it.
Another thing that I find very nice about Trinitron tubes is that since they
are sections of cylinders instead of spheres, they are completly flat on any
line from top to bottom. Thus, if you have reflected glare from overhead
lights, tilting the monitor just a tiny bit will usually get rid of it.
Date: 1 Mar 2000 02:23:30
Message: <e8hpbskiehv18hsftkmcelsg47gi9rmoss@4ax.com>
On Tue, 29 Feb 2000 19:01:25 -0600 "Bob Hughes"
  That's what I get when I walk into the tv department of a Sears or
Montgomery Ward's, multiplied by twenty television sets.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 1 Mar 2000 02:27:38
Message: <5dhpbs4dqp7o2d331jhi4v4t40vfmmko0t@4ax.com>
  Same folks who add an equalizer to their audio systems and then move
the sliders for each band to the maximum setting. Forget about a flat
frequency response in their listening area...
Date: 1 Mar 2000 13:47:31
Message: <slrn8bqkb9.7sj.sjlen@zero-pps.localdomain>
Don't get me started on sound, not only do my parents always think
that there's something wrong with the colours on the TV, but there's
always something wrong with the sound aswell.  They don't like it
if they can hear anything in the trebbel range, so if you hear a pin
drop in a film, they think that something's wrong with the sound.
Not only that but they have it turned up so loud I can't watch any
programs with them, I have to go into another room and watch a TV
with a volume setting that doesn't make the light fitting rattle.
Maybe we should move to Off-Topic.
  5:14pm  up 4 days, 13:06,  3 users,  load average: 1.04, 1.14, 1.09
Date: 1 Mar 2000 17:19:25
Message: <38bd976d@news.povray.org>
Yes, thats the other good thing on trinitrons (i sell 20" Trinitron since
1990!), and the demirroring (right word?) is the same as on someones
glasses. No disturbing wafer that disturbes the good picture, but looked at
better in a room with not direct light directed to the monitor ... EIZO
includes a micro-fibre-piece to clean this without chemicals and stripes ...
There are completely flat ones available, but i did not watch any of them
Hartmut
Jon A. Cruz schrieb in Nachricht <38BCB9A3.C34A10AE@geocities.com>...
they
any
