POV-Ray : Newsgroups : povray.binaries.images : Torus problem (69KB) Server Time
25 Oct 2026 05:53:19 EDT (-0400)
  Torus problem (69KB) (Message 1 to 24 of 24)
Subject: Torus problem (69KB)
Date: 20 Apr 2000 23:06:38
Message: <38FFC5BF.757B1EBB@hotmail.com>
I have made the "fence" in the image below
from two different shapes, both made with
a torus.
But there seems to be a problem with the
light reflections from the texture,
(which is common to the two shapes;
Soft_Silver with a Red pigment):
The reflection normal of the surfaces
appears to make a sudden change of
direction in the region where the two
shapes meet.
(There is only one light source.)
Is this correct behaviour?
(I'm using standard POV-Ray v3.1g for
Windows.)
And also: Does anyone know of any other
basic shapes in POV-Ray, or a quartic
equations, that can be used to make a
"cigar" shape (like the "convex cylinder")
in my image ?
Tor Olav
mailto:tor### [at] hotmailcom
Download 'invtorus07.jpg' (69 KB)
Preview of image 'invtorus07.jpg'
Subject: Re: Torus problem (69KB)
Date: 20 Apr 2000 23:34:34
Message: <38ffcc4a@news.povray.org>
Apparently you have the end parts of each tube piece made with the inside
donut hole of the torus.  Try 'inverse' in those.  What texture is used exactly?
Is there a 'normal' statement involved or is it just a 'finish'?
"Tor Olav Kristensen" <tor### [at] hotmailcom> wrote in message
news:38FFC5BF.757B1EBB@hotmail.com...
| a torus.
| shapes meet.
| Windows.)
| in my image ?
| Tor Olav
| http://www.crosswinds.net/~tok/tokrays.html
Date: 21 Apr 2000 05:34:49
Message: <390020b9@news.povray.org>
I think the texture difference; while perhaps unintended, looks very cool :>
Mike Metheny
lon### [at] vtedu
http://www.loneshepherd.com/
"When one's words are no better than silence, one should keep silent."
Date: 21 Apr 2000 17:33:11
Message: <3900C930.F7039ED4@hotmail.com>
Yes the 'end'-part is done that way: The concave
shape is a difference between a sphere and a torus.
I have now tried to replace the difference with an
intersection of a sphere and a torus with the
'inverse' keyword. (Is this what you meant?)
==> Same result. No change in the reflections. :(
  texture { Soft_Silver }
  pigment { color Red }
No. Just the above two statements.
Extract from the 'texture.inc' file that came
with POV-Ray:
#declare Silver1_Colour = color  rgb <0.94, 0.93, 0.83>;
#declare Soft_Silver =
    pigment { Silver1_Colour }
    finish {
        metallic
        ambient 0.2
        diffuse 0.35
        specular 0.85
        roughness 0.01
        reflection 0.45
        brilliance 1.5
Tor Olav
Date: 21 Apr 2000 17:35:45
Message: <3900C9CE.ECF0E25E@hotmail.com>
Heh! :)
I was so focused on the problem that I did not see that!
Thank you.
Tor Olav
Date: 21 Apr 2000 22:13:00
Message: <39010aac@news.povray.org>
news:3900C930.F7039ED4@hotmail.com...
Nope.  I was talking about the torus surface itself, maybe if it's inversed then
perhaps the reflection will right itself by then being on the "outside".
Realize though that by turning the torus inside-out then the CSG will
change too.  I think that a inverse used in the intersection or difference
should cancel that change.
Rather than try and make guesses I just tried to make such a thing myself
and I couldn't even see any reversed (or whatever) reflection:
light_source { <-5,10,-10> color rgb 1.5
  location  <-1,1,-10>
  angle 25
  look_at   <0, 0, 0>
sphere {0,1
        pigment {gradient y color_map {
                [0,1 color rgb <.9,.2,.1> color rgb <.2,.4,.8>]
        }} scale 30
#declare Connector=
union {
difference { // torus core, capped
        sphere {0,1}
        torus {1.5,1}
      translate -y*.6615 // approximation only
difference { // torus anti-core
        torus {1.5,1}
        sphere {0,1 inverse}
      translate y*.6615 // approximation only
        pigment {rgb <.25,1,.25>}
        finish {reflection .5}
object {Connector
         scale <.5,2,.5> rotate <-30,70,-90> translate -y
object {Connector
         scale <.5,2,.5> rotate <30,-70,90> translate y
Date: 22 Apr 2000 10:56:34
Message: <3901BDA8.C6F8691D@hotmail.com>
First: Thank you very much for trying to help me!
I'm quite frustrated, because I need the reflections from this
middle "cigar" shape to behave correctly(?) in other scenes.
I have now included some of my source code below so that you can see
what I'm actually doing.
Note that my convex "cigar" shape is made with a torus that has a
greater minor radius than major radius.
And I now wonder if this could cause the odd change in reflections?
(As I understand from your code, you are making a similar shape by
scaling a sphere along an axis.)
Regards
Tor Olav
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#version 3.1;
#include "textures.inc"
#declare v3Origo = <0, 0, 0>;
#macro Pythagoras(hyp, kat)
 sqrt(hyp*hyp - kat*kat)
#end // macro Pythagoras
#declare RadW = 1.0; // Max Radius for Wide   part (Cigar Shape)
#declare RadN = 0.5; // Min Radius for Narrow part (Spoke shape)
#declare RadMinC = 26; // Minor Radius for Cigar shape
#declare RadMinS = 26; // Minor Radius for Spoke shape
#declare HoleClearing = 0.1;
#declare RadMajC = RadMinC - RadW; // Major Radius for Cigar shape
#declare RadMajS = RadMinS + RadN; // Major Radius for Spoke shape
#declare ss = Pythagoras(RadMinC + RadMinS, RadMajC + RadMajS);
#declare tt = ss*RadMinS/(RadMinC + RadMinS);
#declare DistBetween = 2*ss; // RadW + RadN
#declare Cigar =
difference {
  sphere { v3Origo, Pythagoras(RadMinC, RadMajC) }
  torus { RadMajC, RadMinC }
  cylinder { (RadW + RadN)*x, -(RadW + RadN)*x, RadN + HoleClearing }
//  plane {  y, tt - ss }
//  plane { -y, tt - ss }
#declare Spoke =
difference {
  sphere { v3Origo, vlength(<RadMajS, RadMinS>) }
  torus { RadMajS, RadMinS }
  plane {  y, -tt }
  plane { -y, -tt }
//#declare SpkCig =
merge {
  object { Cigar translate +ss/2*y }
  object { Spoke translate -ss/2*y }
Date: 22 Apr 2000 20:02:16
Message: <39023d88$1@news.povray.org>
I checked out what you had there and also didn't see any way of getting the inside to
become outside, which is the case for that torus with the larger minor radius than
major.
Not that it was going to be possible using inverse or variations thereof (I even gave
scale -1 a try), but as it turns out I couldn't even get the MegaPov
'interior_texture' to
put it right.
This means to me that something goes wrong with that torus.  Not a complete surprise
either since it's been said before by other people how that particular shape isn't
reliable.
The problem is in the inner part of the torus, even though usually an outer surface,
ends
up inside itself.  So the raytracer must be confusing it entirely.
Date: 24 Apr 2000 21:40:28
Message: <3904F7A6.AF260EC3@hotmail.com>
> reliable.
ends
So it is the "ciagar" shape that messes up the
reflections.
That's a pity. =(
Is this to be considered as a bug ?
And if so, do you know if the other people you
mentioned have posted a bug report on the subject?
I have also noticed that this shape is hollow.
And therefore it doesn't behave in CSG operations.
Tor Olav
Date: 24 Apr 2000 21:55:43
Message: <3904fb1f@news.povray.org>
I don't know if it's a mathematic problem with the torus and if not then it must be
related to the raytracer.
Maybe there's a possible fix but I'm not one who could even begin to guess the answer.
I think it might have been said to be a "bug", but again I couldn't say.  Straining to
remember
I think people were conceding it to be a problem with the raytraced surface and might
not
be
easily fixed.  Takes those math geniuses out there (and here) I'm sure.
news:3904F7A6.AF260EC3@hotmail.com...
surprise
| > reliable.
surface,
ends
| reflections.
| That's a pity. =(
| Tor Olav
Date: 24 Apr 2000 22:10:03
Message: <chrishuff_99-1B983E.21130124042000@news.povray.org>
In article <3904F7A6.AF260EC3@hotmail.com>, Tor Olav Kristensen
> reflections.
> That's a pity. =(
I think the reason you end up with a "cigar" shape at all is a bug. As I
recall, this is because the bounding gets messed up by the radius
settings, I think someone was working on a fix for it...which wouldn't
give a cigar shape, but the actual torus shape.
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 24 Apr 2000 22:38:52
Message: <39050553.8CB4B93F@hotmail.com>
As far as I remember you do get the torus shape if you do not
subtract it from another shape.
Btw: Are there other shapes that intersects with themselves
like this?
(Maybe one could introduce a new "self_intersection" keyword ? :)
> As I recall,
But, but, but ...
...How are we supposed to model such cigar shapes then?
(Scaling a sphere along an axis gives a shape that's round
at the ends, while this cigar shape ends in a sharp point.)
Tor Olav
Date: 24 Apr 2000 23:54:49
Message: <390516B5.CA6D79B1@pacbell.net>
Tor Olav Kristensen wrote:
> But, but, but ...
A lathe can do it with ease and can also be used in CSG operations.
Date: 25 Apr 2000 06:47:55
Message: <chrishuff_99-D8FB78.05505325042000@news.povray.org>
In article <390516B5.CA6D79B1@pacbell.net>, lin### [at] povrayorg
> > But, but, but ...
You can also do it with the poly or quartic objects, and it is quite
easy to do with the isosurface object.
Date: 25 Apr 2000 18:01:25
Message: <a40cgso5faq571fcitr6litaijcvm8lfeq@4ax.com>
>> But, but, but ...
 I have been having exactly the same problem with the chimney of a loco that I
am modelling.  I was using a cone with the fillet radii being produced by the
outside surface of two tori.  These fillets have a different texture to the rest
of the chimney, presumably because of the normal being the wrong way.
A lathe object should solve this problem, but at the expense of a much more
involved definition requiring a bezier_spline definition.
David
dav### [at] hamiltonitecom
http://www.hamiltonite.com/
Date: 25 Apr 2000 18:09:38
Message: <3906173C.3C11324C@pacbell.net>
This is one of the areas where I will always used an external utility.
Hand coding splines is a waste of time when you can use a utility to
simply point and click your shape definition.
Date: 28 Apr 2000 20:40:44
Message: <390A2FC0.338AB835@hotmail.com>
Thank you. I did not think of that.
(But it would still be nice to have a basic shape like
this one. Because then I wouldn't have to calculate
the co ordinates for the appropriate quadratic_spline or
cubic_spline.)
Btw.: Will such a lathe render slower than my "cigar" shape ?
Tor Olav
Date: 28 Apr 2000 20:47:45
Message: <390A3169.9A2EE8C@hotmail.com>
I have been thinking about that, but I have not found the
proper equation for that yet.
(Where the minor and major radii are a part of the equation.)
Any suggestions?
And would it be possible to use a quartic object (and an
isosurface) in a CSG expression?
Tor Olav
Date: 28 Apr 2000 20:53:55
Message: <390A32DC.3ADF862B@hotmail.com>
Do you have any suggestions on how to calculate a set of co-ordinates
for a bezier_spline lathe that models such a "cigar" accurately?
Tor Olav
Date: 28 Apr 2000 20:56:08
Message: <390A3364.5028AD4@hotmail.com>
But I can not tell my macros to go and use an external utility...
... Or can I ? :)
Tor Olav
Date: 28 Apr 2000 21:24:14
Message: <390A3816.A7666B7@pacbell.net>
> ... Or can I ? :)
...but there is no reason why you cannot create the points for your
lathe object first and then utilize them in your macro.
Date: 28 Apr 2000 21:45:46
Message: <390A3D1E.C86A918D@pacbell.net>
Lathes can render quickly if you use a linear or quadratic spline.
Cubic splines are little slower. A lot of it depends on how many
points for the spline are specified and how well behaved it is.
If you specify a lot of points or require sharp bends from the
spline is can slow things down. For a simple cigar shape I see
no reason why it would not render in an acceptable amount of
time.
Date: 29 Apr 2000 15:51:36
Message: <390B3D47.F682C002@ipfw.edu>
> Any suggestions?
Maybe this is what you are asking about?
Equations for a torus,
major radius R>0 centered at (x,y,z)=(0,0,0)
minor radius r>0 (any value: r<R, r=R, or r>R, all OK)
rotational symmetry axis = z-axis
Parametric equations, depending on parameters s and t from 0 to 2*Pi:
x:=(R+r*cos(t))*cos(s);
y:=(R+r*cos(t))*sin(s);
z:=r*sin(t);
Implicit quartic equation:
0 = (x^2+y^2+z^2+R^2-r^2)^2-4*R^2*(x^2+y^2)
which expands to:
0 = r^4 - 2*x^2*r^2 - 2*y^2*r^2 - 2*r^2*R^2 - 2*r^2*z^2 + R^4 -
2*R^2*x^2 - 2*y^2*R^2 + 2*R^2*z^2 + x^4 + 2*x^2*y^2 + 2*x^2*z^2 +
2*y^2*z^2 + z^4 + y^4
I gave an example of this when replying to a post in this newsgroup by
D. Fontaine, 12-19-99.
Adam C.
Date: 1 May 2000 09:37:08
Message: <390D887F.A1D5D706@hotmail.com>
Yes. That helped a lot!
Thank you.
Sorry.
I had not discovered these news groups at that time.
Tor Olav
