POV-Ray : Newsgroups : povray.binaries.images : Help: SplineTree Leaves(54.6k) Server Time
25 Oct 2026 05:53:35 EDT (-0400)
  Help: SplineTree Leaves(54.6k) (Message 1 to 12 of 12)
Subject: Help: SplineTree Leaves(54.6k)
Date: 20 Apr 2000 10:52:38
Message: <38FF0BBC.77775BEA@gci.net>
I am having trouble with the leaves in this render.
I am using the Spline tree macro for the tree.
Is there any help for the outline around the leaves?
Download 'image1.png' (55 KB)
Preview of image 'image1.png'
Subject: Re: SplineTree Leaves(54.6k)
Date: 20 Apr 2000 11:17:31
Message: <38ff1f8b@news.povray.org>
"Mr. Art" <mr.### [at] gcinet> wrote in message
news:38FF0BBC.77775BEA@gci.net...
    Without seeing the code, it looks like a media problem.
Subject: Re: Help: SplineTree Leaves(54.6k)
Date: 20 Apr 2000 11:59:14
Message: <38FF298C.D2C7ACDD@spiritone.com>
It looks like an image mapped to part of a sphere. You might need to make them
hollow, or use filter instead of transparency. I can't remember which, but
I've run into this before with media.
Josh English
eng### [at] spiritonecom
Date: 20 Apr 2000 13:06:04
Message: <38ff38fc@news.povray.org>
Don't know if this will work, but try adding max_trace_level to the
global_settings block of your scene file, something like:
global_settings {max_trace_level 50}
You might need a higher figure than 50, but don't count on it working as
it's only a guess.
Alan.
Date: 20 Apr 2000 16:37:07
Message: <38FF6A58.20D215A0@ibm.net>
Hello,
I am assuming you are using the default leaves with the macro and also have
fog with media in your scene.  I've had this problem before, and the only
solutions are to...
1) remove the fog or
2) remove the media
3) use a leaf object without transparent areas.  I think there is a good leaf
macro included in the Gilles Tran' tree generator.
I think it should work fine with fog or media alone.  I seem to think that
object media works ok as well.  Hope this helps,
Andrew C
Date: 20 Apr 2000 17:22:31
Message: <38FF82B5.9F549299@netvision.net.il>
You need to make all objects that construc the leaves hollow:
just add:
	hollow
or
	hollow on
and it should work.
Date: 20 Apr 2000 18:32:01
Message: <38FF8546.1D90FFEF@ibm.net>
If he is using the default leaves they should be already hollow - I
don't think this is the problem.
Andrew C
> just add:
>         hollow
> or
>         hollow on
> and it should work.
Date: 20 Apr 2000 19:42:13
Message: <38FF9590.3D5C5CBB@pacbell.net>
I think the problem with having to use hollow to enable object media
is that it also allows for the fog to enter the object as well. This
causes the fog and media to mix causing the effect seen in this image.
I have never really been able to resolve the conflict either.
Date: 20 Apr 2000 21:01:01
Message: <38FF9A62.5B9512A3@gci.net>
Thanks for all the responses that you people have
given. I checked into the media/fog ideas and
found a few fog statements in one of the include
files that I was using. As this scene takes about
8 hours to render, I'll have to get back to you on
how much this helps.
Date: 20 Apr 2000 23:48:41
Message: <38ffcf99@news.povray.org>
Don't forget to not use a fog with filtered color or you'll likely never get it to
look right, only
'transmit' or 'rgbt' or none at all in fog works perfectly.
"Mr. Art" <mr.### [at] gcinet> wrote in message news:38FF9A62.5B9512A3@gci.net...
| >  [Image]
Date: 21 Apr 2000 16:24:40
Message: <3900AB15.CC4526EF@gci.net>
Well, here is what I came up with.
The lamp is by Gilles Tran.
The tree is the splinetree.
The sky I got off the ng's here.( I made small
modifications to it.)
> >  [Image]
Download 'display.jpg' (70 KB)
Preview of image 'display.jpg'
Date: 25 Apr 2000 09:06:56
Message: <3905986F.DEE36206@iname.com>
	Pretty nice, I like it...
	If I may hazard a suggestion, I would remove the ambient
and replace it with a shadowless light source near the
camera, this way the lamp would have more relief.
		Jerome
******************************* Jérôme M. BERGER
