POV-Ray : Newsgroups : povray.binaries.images : SineSpline: help me improve my macro! (13kbbu) Server Time
23 Jan 2026 04:53:21 EST (-0500)
  SineSpline: help me improve my macro! (13kbbu) (Message 1 to 6 of 6)
Subject: SineSpline: help me improve my macro! (13kbbu)
Date: 11 Apr 2000 14:07:43
Message: <38F36884.F0797519@my-dejanews.com>
I have a new macro to get a moderately smooth transition between points.
The values will not exceed the range of any interval and it does not
require one to think up two points before and after the range (8-P) as
with a cubic spline.  I tried to set it up elegantly with a linear
spline and then #switch case, but I could not get the syntax correct.
Instead, one has to first manually define the points as follows:
#declare pn=array[15]
#declare pn[0]=<0.00, -15>;
#declare pn[1]=<0.25, -125>;
#declare pn[2]=<0.35, -117.5>;
#declare pn[3]=<0.45, -110>;
#declare pn[4]=<0.50, -10>;
#declare pn[5]=<0.675, -17.5>;
#declare pn[6]=<0.75, -25>;
#declare pn[7]=<1.00, -15>;
#macro sinespline(n,xgive)
           //where n=number of pts-1 (or # in last increment);
           //          x= given x for which a Y is requested for return.
         #declare jj=0;
         #while(jj<n)
                //#debug str(jj,2,0)
                #if(xgive>pn[jj].x &xgive<pn[jj+1].x)
                        #declare
yreturn=pn[jj].y+(pn[jj+1].y-pn[jj].y)*sin(pi/2*(xgive-pn[jj].x)/(pn[jj+1].x-pn[jj].x));
                #else
                #debug str(jj,2,0)
         #declare jj=jj+1;
If anyone thinks this is of any value to humanity, please make it more
streamlined, if possible.....
Example code demonstrating differences between linear,  #init_spline,
and SineSpline:
#version unofficial MegaPov 0.4
#init_spline {"Lshininit",
<0.00, -15>,
<0.25, -125>,
<0.45, -110>,
<0.50, -10>,
<0.75, -25>,
<1.00, -15>
#init_spline {"Lshininit2",
<0.00, -15>,
<0.25, -125>,
<0.35, -117.5>,
<0.45, -110>,
<0.50, -10>,
<0.675, -17.5>,
<0.75, -25>,
<1.00, -15>
#declare Lshinlinear=spline{
linear_spline
0.00, -15,
0.25, -125,
0.45, -110,
0.50, -10,
0.75, -25,
1.00, -15
#declare inputspline=spline{
linear_spline
0.00, -15,
0.25, -125,
0.45, -110,
0.50, -10,
0.75, -25,
1.00, -15
         #declare jj=0;
         #while(jj<n)
                        #declare
                #else
                #debug str(jj,2,0)
         #declare jj=jj+1;
#declare nn=0.001;
#while(nn<1)
sphere {<(nn+0.02)*300,Lshinlinear(nn+0.02).y,0>,3
        pigment{Red}
        finish{ambient 1}
sphere {<nn*300,eval_spline ("Lshininit",nn),3>,3
        pigment{Green}
        finish{ambient 1}
sinespline(7,nn+0.01)
//#declare yg=ygive;
sphere {<(nn+0.01)*300,yreturn,-3>,3
        pigment{Blue}
        finish{ambient 1}
#declare nn=nn+.03;
camera
  location  <130, -75, -300>
  look_at   <130, -75,  0.0>
Download 'sinespline.jpg' (13 KB)
Preview of image 'sinespline.jpg'
Subject: Re: SineSpline: help me improve my macro! (13kbbu)
Date: 11 Apr 2000 15:03:36
Message: <38f37708@news.povray.org>
What is your goal? Is it to have a switch and case in your macro?
Mike
wk: mik### [at] pyxiscom  www.pyxis.com
hm: mwe### [at] sciticom  www.geocities.com/mikepweber
"Greg M. Johnson" <gre### [at] my-dejanewscom> wrote in message
news:38F36884.F0797519@my-dejanews.com...
Date: 11 Apr 2000 15:31:15
Message: <38F37C6E.E4207E7B@my-dejanews.com>
Is there a more easy way to declare everything instead of the list of
pn[0]=<a,b>,  etc..........
> Mike
Date: 11 Apr 2000 17:14:48
Message: <38F3948F.8C60200C@online.no>
Interesting macro!
I have not installed MegaPov on my PC yet, so I can not run your code... :-(
See my try below. (Source code for POV-Ray v3.1)
Tor Olav
mailto:tor### [at] hotmailcom
#version 3.1;
#macro sinespline(xgive, ptArray)
  #local jj = 0;
  #local nextx = ptArray[jj].x;
  #local Found = false;
  #while (!Found & (jj < dimension_size(ptArray, 1) - 1))
    #local lastx = nextx;
    #local jj = jj+1;
    #local Found = ((xgive >= lastx) & (xgive < nextx) ? true : false);
  #end // while
  (Found ? ptArray[jj-1].y +
           (ptArray[jj] - ptArray[jj-1]).y*
           sin(pi/2*(xgive - lastx)/(nextx - lastx))
         : 0)
#end // macro sinespline
#declare pn =
array[8] {
  < 0.000,  -15.0 >,
  < 0.250, -125.0 >,
  < 0.350, -117.5 >,
  < 0.450, -110.0 >,
  < 0.500,  -10.0 >,
  < 0.675,  -17.5 >,
  < 0.750,  -25.0 >,
  < 1.000,  -15.0 >
#declare Radius = 3;
#declare sc = <300, 1, -3>;
#declare Cnt = 0;
#while(Cnt < 1)
  sphere {
    <Cnt, sinespline(Cnt, pn), 1>*sc, Radius
    pigment{ Blue }
    finish{ ambient 1 }
  #declare Cnt = Cnt + .002;
#declare Cnt = 0;
#while(Cnt < dimension_size(pn, 1))
  sphere {
    <pn[Cnt].x, pn[Cnt].y, 1>*sc, Radius*2
    pigment{ Red }
    finish{ ambient 1 }
  #declare Cnt = Cnt + 1;
Date: 12 Apr 2000 11:14:53
Message: <38F491DF.CBCCF914@my-dejanews.com>
PERFECT!  Publish it.
> Interesting macro!
> Tor Olav
> http://www.crosswinds.net/~tok/tokrays.html
> #version 3.1;
>   #local jj = 0;
>     #local jj = jj+1;
>   #end // while
>          : 0)
> #declare pn =
> array[8] {
>   < 0.000,  -15.0 >,
>   < 0.250, -125.0 >,
>   < 0.350, -117.5 >,
>   < 0.450, -110.0 >,
>   < 0.500,  -10.0 >,
>   < 0.675,  -17.5 >,
>   < 0.750,  -25.0 >,
>   < 1.000,  -15.0 >
> #declare Cnt = 0;
> #while(Cnt < 1)
>   sphere {
>     pigment{ Blue }
>     finish{ ambient 1 }
> #end
> #declare Cnt = 0;
>   sphere {
>     pigment{ Red }
>     finish{ ambient 1 }
> #end
> camera {
Date: 12 Apr 2000 12:16:51
Message: <38F4A04C.F708347D@online.no>
> PERFECT!
Thank you!
> Publish it.
It's still your macro (and idea) ... I just polished it.
So you may publish it wherever you like.
Regards
Tor Olav
