POV-Ray : Newsgroups : povray.binaries.images : Volumetric Non-media clouds (320x240) Server Time
20 Oct 2026 07:30:14 EDT (-0400)
  Volumetric Non-media clouds (320x240) (Message 1 to 17 of 17)
Subject: Volumetric Non-media clouds (320x240)
Date: 11 Apr 2000 01:03:36
Message: <38F2B256.E12E59E9@aol.com>
Okay, these are really volume clouds this time. I stumbled on the
technique today (goofing around at work). I was playing with
motion_blur, finding ways to exploit its properties. On a whim I decided
to add the clock value to the threshold of an isosurface. To my
surprise, it appeared to have volumetric properties. I kept on prodding,
amazed it was actually creating shadows and stuff. I went with it, until
I got the render you see before you. I didn't add the clouds to a plane
density, since it increases the render time.
What do you all think? Do these clouds have promise? I already know the
answer to that question :) They render faster than media, according to
my limited comparison studies. I'd like to see somebody with more mhz do
something with them. This image took 30 minutes and 49 seconds on my
P166 mhz without aa.
//*************Code!
global_settings{ motion_blur 20,1 }
background{<.4 .6 .8>}
#declare Tex=function{pigment{bumps scale .5 turbulence .25
color_map{[.5 rgb 1][1 rgb 0]}}}
motion_blur{
 isosurface{
  function Tex(x,y,z)+.1
  threshold .5+clock sign 1
  accuracy .01 method 2 eval
  contained_by{box{-1,1}}
  pigment{rgb 1} finish{diffuse .85 ambient<.4 .6 .8>*.35}
  double_illuminate
Samuel Benge
E-Mail: STB### [at] aolcom
Visit the still unfinished isosurface tutorial:
http://members.aol.com/stbenge
Download 'blur_clouds.jpg' (11 KB)
Preview of image 'blur_clouds.jpg'
Subject: Re: Volumetric Non-media clouds (320x240)
Date: 11 Apr 2000 02:47:46
Message: <38f2ca92$1@news.povray.org>
Promising, no doubt! But what happens when the clouds cover the entire sky?
Will the isosurface-render drastically slow down? (Of course it will, but
how much?)
One problem is that the clouds look a bit dense; I suppose it is because of
this new "media type" is in principle absorbing, and that the pigment is
simpy white. Adding trasmittance/filter will probably make lighter clouds,
although it might be difficult to adjust the amount correctly. (I think.)
Simen.
Date: 11 Apr 2000 03:34:17
Message: <38F2D4E8.A7BEBFA3@hotmail.com>
-Oh my god Holy s**t that is cool
Date: 11 Apr 2000 10:49:47
Message: <38f33b8b@news.povray.org>
Looks great for smoke! Great job!
Date: 11 Apr 2000 11:13:23
Message: <chrishuff_99-A0CD25.10160011042000@news.povray.org>
In article <38F2B256.E12E59E9@aol.com>, "SamuelT." <STB### [at] aolcom>
Try playing with the brilliance value in finish, decreasing
ambient(which probably acts something like emission media), and giving
some transparence to the color(like decreasing extinction in media). The
brilliance will vary the amount of "scattering" dependant on angle. At
least, I think it should, it has in my other tests of this sort.
I never thought of trying motion_blur though(well, I tried it with
isosurfaces, and even used it to control the threshold, but never
thought of doing clouds or smoke)...these might behave differently under
those circumstances.
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 11 Apr 2000 16:21:30
Message: <38F389B7.7AB4A2E2@osu.edu>
my sentiments exactly, this is so very cool. how did you do this again?
source code! source code!
Date: 11 Apr 2000 18:02:57
Message: <38f3a111@news.povray.org>
it's there on his original message (read the entire thing ;-)
Andre
Date: 11 Apr 2000 18:58:56
Message: <38F3AE9F.A1475E4D@osu.edu>
> Andre
oh, i guess I was too busy drooling!
Date: 11 Apr 2000 22:53:07
Message: <38F3E549.6A9B423B@aol.com>
> how much?)
A lot. It should still be faster than media, though.
> Simen.
I think if transparency were added to the clouds, they might render even
slower.
This technique is closer to scattering media, I think.
Samuel Benge
Visit the still unfinished isosurface tutorial: http://members.aol.com/stbenge
Date: 11 Apr 2000 22:54:54
Message: <38F3E5B7.3A4960F8@aol.com>
Yes, I'm developing some smoke. Other functions render faster, by the
way.
Samuel Benge
Date: 11 Apr 2000 22:57:03
Message: <38F3E638.AC081566@aol.com>
I think maybe increasing the ambient will give it the appearance of being less
dense, as well as lowering the diffuse.
> The brilliance will vary the amount of "scattering" dependant on angle. At
Good idea.
Samuel Benge
Date: 11 Apr 2000 23:42:13
Message: <38F3F0F1.1F28A8BE@osu.edu>
You know what, this is actually the perfect density for cotton candy :)
I think this image will cause me to begin toying with isosurfaces...
Date: 12 Apr 2000 08:36:29
Message: <chrishuff_99-D37903.07390712042000@news.povray.org>
In article <38F3E638.AC081566@aol.com>, "SamuelT." <STB### [at] aolcom>
> less dense, as well as lowering the diffuse.
My reasoning was that ambient makes it visible without light falling on
it, similar to emitting media.
> > At least, I think it should, it has in my other tests of this sort.
> Good idea.
Hmm, turns out that because of the different directions the surfaces
point in(I used planar surfaces in my experiments), the results are not
always what you expect. I had some interesting results by placing a
light_source right in the middle of the smoke, though...
Date: 12 Apr 2000 22:00:37
Message: <38F52A7D.ACD6770A@aol.com>
Yes, I know what you were getting at, and you are right. I used just the right
ambient to make the smoke look like it's disappearing. It only works good if
the ambient value matches the objects behind the smoke.
I had interesting results too, but not very realistic. Perhaps a spherical
pigment with high ambient values can be translated on the isosurface where the
light_source is to produce a more realistic effect. It would be cheating in a
way, but it would probably look good.
Samuel Benge
Date: 16 Apr 2000 08:16:35
Message: <7nbjfs4ldbfkftrm4j3faeum60u8j6imkl@4ax.com>
  Hi, Samuel. Very nice work. Can you tell me what camera and lighting
settings you used for your scene?
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 17 Apr 2000 22:17:01
Message: <38FBC5E2.DA687BBF@aol.com>
Hello Alan. I don't have the original code any longer. Sorry! I can only
guess at what I used. Try something like this:
camera{location<0,5,-10> look_at 0 rotate y*-35}
light_source{<200, 100, -50>,1}
P.S. You're a member of the Pov Team, aren't you? I'm sure I've said this
before: thank you all very much! Pov is *the* best program I have ever
used. Allowing everyone to access the code and change it has helped it
become even better.
Samuel Benge
Date: 18 Apr 2000 20:28:50
Message: <6tupfs0k3htgd3mtsij966bsokna2tb3t4@4ax.com>
On Mon, 17 Apr 2000 19:18:11 -0700 "SamuelT." <STB### [at] aolcom> wrote:
>Sorry! I can only guess at what I used. Try something like this:
  Thanks, Samuel. Earlier, I placed a camera and lightsource in your
scene and it rendered nicely but not nearly as nice as your originally
posted image, hence the reason I was curious. No sweat, just trying to
keep from getting too rusty...
>become even better.
  It's very gratifying to the POV-Team when people come up with novel
ways to use both the official version and MegaPOV. First, it gives
others inspiration to keep creating new images and it also vindicates
the use of the various patches that people write for the benefit of
others. Thanks for your participation.
