POV-Ray : Newsgroups : povray.binaries.images : Planet with Rings Server Time
25 Oct 2026 10:25:58 EDT (-0400)
  Planet with Rings (Message 1 to 16 of 16)
Subject: Planet with Rings
Date: 6 Mar 2000 15:19:52
Message: <38C41292.2A9D67BF@iro.umontreal.ca>
Have anyone work'd out a good planetary ring texture?
Best,
    S.
Steven Pigeon                     Ph. D. Student.
University of Montreal.
pig### [at] iroumontrealca           Topics: data compression,
pig### [at] jspumontrealca          signal processing,
ste### [at] researchattcom           non stationnary signals
                                  and wavelets.
         http://www.iro.umontreal.ca/~pigeon
Download 'planete.jpg' (14 KB)
Preview of image 'planete.jpg'
Subject: Re: Planet with Rings
Date: 6 Mar 2000 16:03:12
Message: <38c41d10$1@news.povray.org>
What you've got there isnt bad, if you were to remove the reflection on it.
They should be dull.
Dirk
      -=<dir### [at] lemongeckoorg>=- -=<http://lemongecko.org>=-
   "The line noise is visually encapsulated into a small pill
     that's easy to swallow"  --O'Reilly's Programming Perl
  No PGP. Nothing I do is that important. This was an ASCII sig.
"Steven Pigeon" <pig### [at] iroumontrealca> wrote in message
news:38C41292.2A9D67BF@iro.umontreal.ca...
> Best,
>     S.
>                                   and wavelets.
Date: 6 Mar 2000 19:10:20
Message: <38C44967.9EC3A0DF@powersurfr.com>
add an alpha map like thng to this and use crackle scaled down really small
> Best,
>     S.
>                                   and wavelets.
Date: 6 Mar 2000 19:11:28
Message: <38C449AB.AF7FABD1@powersurfr.com>
also reflection is fine what if it was a metalic based ring? no polution from
dirt on the metal and it would be slightly glossed, just use mega pov blurred
reflection
> Best,
>     S.
>                                   and wavelets.
Date: 6 Mar 2000 19:17:30
Message: <38C44AAE.C8FE2BF0@gci.net>
What are the circle and line symbols over the planet
for?
> Best,
>     S.
>                                   and wavelets.
Mr. Art
"Often the appearance of reality is more important
than the reality of the appearance."
Bill DeWitt 2000
Date: 6 Mar 2000 19:36:08
Message: <38C44EAB.4EB695E4@stud.ntnu.no>
> Best,
This isn't bad at all. The rings on "our" planets vary greatly, so I can't see
why these shouldn't be just as possible. Well, I'm not sure if you that strong
highlight is realistic. And ambient should be 0 for planets.
I've made a fairly detailed Saturn ring texture, but I don't think you can use
it for anything else. It's in the binaries.scene-files group if you're
interested, posted 28.11.99. It's also available from
http://www.stud.ntnu.no/~as/down.
sig.
Date: 6 Mar 2000 21:47:01
Message: <38C4701D.A2873E34@aol.com>
Here's an image of what I would do. You will need the SuperPatch or MegaPov to
use it, though.
Here's the code for the ring:
disc{
 <0,0,0>,<0,1,0>,10,6
 pigment{
  function noise3d( sqrt( x^2+z^2 ), 0, sqrt( x^2+z^2 ) )
  scale .4
  color_map{[0 rgbf 1][1 rgb<1 1 .9>]}
 finish{
  ambient 0
  diffuse 1.5
> Best,
>     S.
>                                   and wavelets.
Samuel Benge
E-Mail: STB### [at] aolcom
Visit the still unfinished isosurface tutorial: http://members.aol.com/stbenge
Download 'ringed.jpg' (13 KB)
Preview of image 'ringed.jpg'
Date: 7 Mar 2000 01:10:54
Message: <Yu8xECA$kFx4EwAR@econym.demon.co.uk>
>reflection
Each individual particle might reflect, but those reflections would be
in totally random directions because the particles are oriented
randomly. Take a look at a pile of iron filings.
Mike Williams * ##
Gentleman of Leisure
Date: 7 Mar 2000 02:40:07
Message: <YbHEOCyT0e9g6HUbjZfGk3uJmCVv@4ax.com>
On Tue, 7 Mar 2000 01:19:59 +0000, Mike Williams <mik### [at] nospamplease>
Isn't this precisely how blurred reflection in MegaPOV works?
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 7 Mar 2000 19:32:26
Message: <38C59F76.A5401909@iro.umontreal.ca>
> > Best,
Actually, it is 0. But on the other hand earth shines quite a lot. It doesreflect
~39% of the light it receives. A ring in low orbit would have a
good 'earth shine'. If the moon does, after all...
> sig.
                                  and wavelets.
Date: 7 Mar 2000 19:36:34
Message: <38C5A06E.7FB3F85@iro.umontreal.ca>
> use it, though.
> disc{
>  pigment{
>   scale .4
>  finish{
>   ambient 0
>   diffuse 1.5
Hmmm! They look good. I'll try that and Noah's suggestion... touse some Alpha blending
and all
> > Best,
> >     S.
> >                                   and wavelets.
> >  [Image]
> Samuel Benge
                                  and wavelets.
Date: 7 Mar 2000 20:14:26
Message: <38C5A9EF.76103EB9@powersurfr.com>
i thought it would have the samme scatter effect..... life aint perfect
nither is 3d
> Peter Popov
> pet### [at] usanet
> ICQ: 15002700
Date: 7 Mar 2000 20:16:41
Message: <38C5AA75.DE8AAC9A@powersurfr.com>
ooo my toil has been recognised! anyways.... where can i get megapov anyways?
> > use it, though.
> > disc{
> >  pigment{
> >   scale .4
> >  finish{
> >   ambient 0
> >   diffuse 1.5
blending
> and all
> > > Best,
> > >     S.
> > >                                   and wavelets.
> > >  [Image]
> > Samuel Benge
> >  [Image]
>                                   and wavelets.
Date: 7 Mar 2000 20:27:14
Message: <chrishuff_99-FE6B36.20285807032000@news.povray.org>
In article <38C5AA75.DE8AAC9A@powersurfr.com>, Noah A
> anyways?
http://nathan.kopp.com/patched.htm
Chris Huff
e-mail: chr### [at] yahoocom
Date: 7 Mar 2000 21:39:41
Message: <38c5bd6d@news.povray.org>
Actually, the reflectivity (or albedo) of the earth is a very important
phenomena.  Back when I was Atmospheric Chemistry simulation (i.e. solving
an approximation to the 3D multicomponent Navier-Stokes equation), albedo
was one of the most important parameters in understanding the impact of
solar radiation on the thermal characteristics of the planetary atmosphere.
Jim
Check out my web site  http://www.kressworks.com/
Steven Pigeon <pig### [at] iroumontrealca> wrote in message
news:38C59F76.A5401909@iro.umontreal.ca...
> > > Best,
can't see
strong
doesreflect
can use
> > sig.
>                                   and wavelets.
Date: 8 Mar 2000 00:20:38
Message: <38C5E3A4.288F202A@powersurfr.com>
thanks
> > anyways?
> Chris Huff
> Web page: http://chrishuff.dhs.org/
