POV-Ray : Newsgroups : povray.binaries.images : Baseball, 24kbu Server Time
20 Oct 2026 16:51:06 EDT (-0400)
  Baseball, 24kbu (Message 1 to 33 of 33)
Subject: Baseball, 24kbu
Date: 20 Feb 2000 09:08:03
Message: <38AFF53B.4A483B33@stud.ntnu.no>
Here is my current project and two questions:
* Why can't I get blobs blobby? This is my first attempt with blobs, and as you
can see there is a sharp edge where the bump making spheres intersects the ball
sphere.
* How do I prevent the image maps from appearing at the reverse side? I've
tried gradient texture maps, but was told that texture maps couldn't be used in
layered textures. (or something)
sig.
Download 'baseball.jpg' (24 KB)
Preview of image 'baseball.jpg'
Subject: Re: Baseball, 24kbu
Date: 20 Feb 2000 10:18:52
Message: <38b005dc@news.povray.org>
"Sigmund Kyrre Aas" <as### [at] studntnuno> wrote in message
news:38AFF53B.4A483B33@stud.ntnu.no...
> with blobs, and as you can see there is a sharp edge
> sphere.
> the reverse side? I've tried gradient texture maps, but
> was told that texture maps couldn't be used in layered
While I can't answer your first question, here's a link to a tutorial
dealing with your second:
http://members.xoom.com/yang4yang/pov/imap1.html
Good luck.
Eric
"The whole problem with the world is that fools and fanatics are always so
certain of themselves, but wiser people so full of doubts."
--Bertrand Russel
Date: 20 Feb 2000 10:27:13
Message: <38b007d1@news.povray.org>
Are you enclosing the ball sphere and the bump spheres in a single blob{}
statement? If you have them in separate blob{} statements, they won't blob
together when they intersect.
Paul Vanukoff
van### [at] primenetcom
Sigmund Kyrre Aas wrote in message <38AFF53B.4A483B33@stud.ntnu.no>...
you
ball
>sphere.
Date: 20 Feb 2000 11:50:48
Message: <38B01B76.9AB0BDE7@stud.ntnu.no>
Yes. Here it is:
blob {
    threshold .8
    sphere {<0, 0, 0>, R*3.05, 1.004 }
    $a=0;
    $AntKuler=500;
    $d=1/AntKuler;
    #while (a<1)
        $Her=eval_3d_spline("Seam",a);
        $Der=eval_3d_spline("Seam",a+d);
        $Retn=vnormalize( Der-Her);
        $Tvers=vnormalize(vcross(Retn,Her) );
        $Norm=vnormalize(Her);
        sphere { 0, .25 ,1.2 scale <.33,1,1>  // bulk utover
            matrix <Norm.x,Norm.y,Norm.z,
                    Retn.x,Retn.y,Retn.z,
                    Tvers.x,Tvers.y,Tvers.z,
                    0   ,0   ,0    >
            translate Her*.99
        sphere { 0, .2 ,-1                 // skøyt
                    Tvers.x*.2,Tvers.y*.2,Tvers.z*.2,
                    0   ,0   ,0    >
            translate Her*1.02
        sphere { 0, .14 ,-1               // meir avrunding av skøyten
                    0   ,0   ,0    >
            translate Her*1.04
        $a=a+d;
    texture{pigment {Green}}
    texture{pigment {Svart}}
    texture {pigment {Batter}}
    texture {pigment {Logo}}
    texture {pigment {Major}}
    finish {specular .1 roughness .05}
    normal { granite 0.5  scale .01 }
Date: 20 Feb 2000 13:02:25
Message: <38B02C3E.D0BC1000@stud.ntnu.no>
Nice tutorial, but it didn't solve my problem.
Now I've tried material maps too, but I get the same message when I try to use
them in layers: "Cannot layer a patterned texture over another"
sig.
Date: 20 Feb 2000 18:46:10
Message: <38b07cc2@news.povray.org>
'threshold .8' might be a little tight, perhaps lower that.  'blob' hardly ever
loses it's creases between components completely though.
news:38B01B76.9AB0BDE7@stud.ntnu.no...
| Yes. Here it is:
| blob {
|     threshold .8
|     $a=0;
|     $AntKuler=500;
|     $d=1/AntKuler;
|     #while (a<1)
|                     0   ,0   ,0    >
|             translate Her*.99
|                     0   ,0   ,0    >
|             translate Her*1.02
|                     0   ,0   ,0    >
|             translate Her*1.04
|         $a=a+d;
|     #end
Date: 20 Feb 2000 18:58:53
Message: <38B0801E.6B62C4C3@istar.ca>
I can't answer either of your questions, but I am mightly impressed with the ball.
Could you post the texture you used for the leather? Very nice!
Simon
Date: 20 Feb 2000 23:24:57
Message: <38B0BD23.2107814A@fci.net>
> sphere.
First, decrease your threshold to .1.  As for the intersections, you should make
multiple copies of the objects you wish to blob. Make the components increase in
diameter, and decrease the component power.  This "feathers" the edges, resulting
in a much smoother edge.
This actually works just fine. The texture on my sports car is entirely dependent
on this working just fine. my suggestion is to experiment.
H.E. Day
Date: 21 Feb 2000 03:46:28
Message: <38b0fb64@news.povray.org>
news:38B02C3E.D0BC1000@stud.ntnu.no...
> same message when I try to use them in layers:
> sig.
Here's a code snippet from a drinking glass I made using a different
technique.  Basically you create a second object (slightly larger than the
original and hollow), apply the logo image map to it, and chop off the back
half by differencing it with a box.
// make a drinking glass from the difference
// of two cylinders
#declare GlassMain = difference {
  cylinder {
    <0,0,0>,
    <0,Hite,0>
    Rad
  cylinder {
    <0,0.1,0>,
    <0,Hite+1,0>
    Rad*0.9
  material {GlassMat}
// make another hollow cylinder with a slightly larger
// radius than the drinking glass and chop off the back
// of it by differencing it with a box
#declare Logo = difference {
  cylinder { // main cylinder
    <0, -0.7, 0>,
    <0,  0.7, 0>
    Rad+0.00002
  cylinder { // cut-out
    <0,-0.71,0>,
    <0,0.71,0>
    Rad+0.00001
  box { // chop off the back half of the cylinder
    <-Rad-0.1,-0.71,0>,
    <Rad+0.1,0.71,Rad+0.1>
      image_map {
        gif "logo_image.gif"
        transmit 209, 1.0 // make the background of the image transparent
        once
        map_type 0
        interpolate 2
    // scale the logo to fit
    translate <-0.5,-0.5,0>
    scale <224/167,1,1>
    scale 1.4
  // position the logo cylinder on the drinking glass
  translate <0,3.75,0>
  rotate y*11
#declare DrinkingGlass = union {
  object {GlassMain}
  object {Logo}
Eric
--Bertrand Russel
Date: 21 Feb 2000 05:16:24
Message: <38B10675.86A069B@stud.ntnu.no>
Thanks! It's quite simple actually. I got it pretty much at first attempt:
$Green=
pigment { bozo
    colour_map {
        [0 rgb <255,249,227>/255]
        [0.5 rgb <233,255,227>/255 ]
        [0.8 rgb <219,205,150>/255 ]
        [1 rgb <255,249,227>/255]
$Svart=
pigment { ripples
    colour_map {
        [0 rgb 1]
        [0.8 rgbf <131,105,55,90>/255 ]
        [1 rgbf 1]
(see previous posting for the rest)
sig.
Date: 21 Feb 2000 05:16:26
Message: <38B10FF9.857F7BE2@stud.ntnu.no>
That worked like a dream, thank you very much.
It must feel great to have control of these evasive shapes..
Guess you're right! Just bad nesting on my part.
<bow> <scrape>
sig.
Date: 21 Feb 2000 05:45:51
Message: <38B111B0.4E8C3BEC@stud.ntnu.no>
I can see this working, but won't the differencing make the scene a lot slower?
sig.
> > sig.
> // of two cylinders
>   cylinder {
>     <0,0,0>,
>     <0,Hite,0>
>     Rad
>   cylinder {
>     <0,0.1,0>,
>     <0,Hite+1,0>
>     Rad*0.9
>   material {GlassMat}
>     <0, -0.7, 0>,
>     <0,  0.7, 0>
>     Rad+0.00002
>     <0,-0.71,0>,
>     <0,0.71,0>
>     Rad+0.00001
>     <-Rad-0.1,-0.71,0>,
>   texture {
>     pigment {
>       image_map {
>         once
>         map_type 0
>         interpolate 2
>     scale <224/167,1,1>
>     scale 1.4
>   rotate y*11
>   object {GlassMain}
>   object {Logo}
> Eric
> http://www.datasync.com/~ericfree
> --Bertrand Russel
Date: 21 Feb 2000 11:07:37
Message: <38B1631E.651B9D8D@spiritone.com>
<snip>
http://www.spiritone.com/~english/cyclopdia/bottle.html
Hopefully this will help. I'm not the linkmaster Ken is, I only know of this on
because I wrote it.
Josh English
eng### [at] spiritonecom
Date: 21 Feb 2000 17:46:25
Message: <b7+xOPHz+iuedMj1OdzCW298RzmT@4ax.com>
On Mon, 21 Feb 2000 11:21:36 +0100, Sigmund Kyrre Aas
>sig.
Probably, try clipping it with a plane instead.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 21 Feb 2000 17:48:21
Message: <slrn8b3amu.hd7.sjlen@zero-pps.localdomain>
Real nice photograph,  but if you want to render it
be prepared to be dissapointed, it'll take you hours
and hours, and you'll still be nowhere close to the
photo version.
  8:55pm  up 7 days,  7:58,  5 users,  load average: 2.10, 2.04, 1.79
Subject: Baseball, strike two 28kbu
Date: 21 Feb 2000 18:10:27
Message: <38B1C5D8.DFBABF96@stud.ntnu.no>
cyclop_e_dia
Hm, yes, using radial is a bit more elegant than gradient. Ah, well who cares
as long as it works..
I also found a thread in this group concerning my other problem:
On 23 Nov 1999 11:29:02 -0500, Nieminen Juha wrote:
>  When I was making my irtc animation entry, povray told me this:
>error: Cannot layer over a patterned texture.
but I got around this since I didn't actually need a texture_map, just a
pigment_map.
Btw I'm planning to make a bunch of baseball artifacts for the Knickers web
site. Can't wait to start on that glove :-[ Nice excuse to learn spatch..
sig.
Download 'baseball2.jpg' (28 KB)
Preview of image 'baseball2.jpg'
Subject: Re: Baseball, strike two 28kbu
Date: 21 Feb 2000 18:26:42
Message: <38b1c9b2@news.povray.org>
news:38B1C5D8.DFBABF96@stud.ntnu.no...
> for the Knickers web site. Can't wait to start on that
Very nice image.  You might consider Rhino for making that glove.  You can
download a fully functional demo that limits you to a total of 25 saves.  It
exports to POV and is VERY powerful.  If you're a student they offer a great
discount (my wife just started back to school to finish her MBA... time to
buy it!!!).
http://www.rhino3d.com/
Eric
--Bertrand Russel
Date: 21 Feb 2000 18:31:41
Message: <icmxOENZS=HNRkK3xJBEpCLUsq+o@4ax.com>
On Mon, 21 Feb 2000 17:25:37 -0600, "Eric Freeman"
>buy it!!!).
That was 15 uses last that I checked (the day before). If you can keep
an uptime of two or three days you'll learn most of the stuff you'll
need. The tutorials are good and the help, though a bit on the
reference side, is, well, quite helpful. I was able to create a pretty
complex (for me, anyway) model in less than 6 hours and I don't think
I am any exception to the learning curve statistics.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 21 Feb 2000 22:27:20
Message: <38b20218@news.povray.org>
"Peter Popov" <pet### [at] usanet> wrote in message
news:icmxOENZS=HNRkK3xJBEpCLUsq+o@4ax.com...
> > that glove.  You can download a fully functional demo
> > that limits you to a total of 25 saves.  It exports to POV
> > great discount (my wife just started back to school to
> > finish her MBA... time to buy it!!!).
They must have changed it... I just checked mine and it said I have 25 saves
left (I haven't made anything good enuf to save yet).
Eric
--Bertrand Russel
Date: 22 Feb 2000 06:43:00
Message: <k8eg0ulbgze.fsf@jeeves.stud.ntnu.no>
"Eric Freeman" <eri### [at] datasynccom> writes:
I'll check it out. I've seen some very nice models done with Rhino, but I
didn't know there was a trial version. How good is the pov-export? Do you
have good control of object groups/unions?
Sigmund Kyrre Aas
Date: 22 Feb 2000 08:17:49
Message: <38b28c7d@news.povray.org>
Kill Rhino and, while your at it, destroy your gifs.
Just My Not So Humble Opinion.
Peter Warren
war### [at] hotmailcom
Date: 22 Feb 2000 08:32:20
Message: <38b28fe4@news.povray.org>
Very nice.
Is that a bat?
Personal to me:  Jr is now #30. But who will break 714(?).
Mac or the Cry Baby?
Peter Warren
Date: 22 Feb 2000 10:05:52
Message: <vqSyOCPWxO94M0toMU+R120R4MuZ@4ax.com>
On 22 Feb 2000 12:43:01 +0100, as### [at] jeevesstudntnuno (Sigmund Kyrre
The POV export is pretty good. It can export a big POV file or a small
POV file and a separate INC for every object. It would have been good
if all elements on a layer could be made into a single mesh, but even
now preparing a 50 MB exported mesh for rendering takes about 5
minutes.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 22 Feb 2000 10:07:20
Message: <k8e4sb1uvh2.fsf@jeeves.stud.ntnu.no>
"Peter Warren" <int### [at] halcyoncom> writes:
> Very nice.
> Is that a bat?
Thanks, and yes. A bat with 100 inch radius.
I don't get it.
But then again I didn't get your statement about gifs either. Surrealism?
personal to me:
Are you sure that personal to you?
Jr is now #30
Is it because of your plans that you say jr is now 30?
Does it bother you that who will break 714?
Is it because of the people you hang around with that you are going through
all this?
Sigmund Kyrre Aas
Date: 22 Feb 2000 10:07:28
Message: <HqWyOM4Yx6HXaCziDQceHNvVKS0I@4ax.com>
On Mon, 21 Feb 2000 21:26:23 -0600, "Eric Freeman"
I am seriously considering registering it. I'll have to see the terms
and conditions for a student's license and of course I'll have to
figure a way to pay (I hope they accept cash).
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 23 Feb 2000 00:23:40
Message: <38b36edc@news.povray.org>
news:HqWyOM4Yx6HXaCziDQceHNvVKS0I@4ax.com...
> see the terms and conditions for a student's license
If I recall from reading their web page (emphasis on "if") it's just a
discount on price... same terms and conditions.
Eric
--Bertrand Russel
Date: 26 Feb 2000 04:53:12
Message: <38B7A299.EBBE1DC4@stud.ntnu.no>
> I haven't used image maps, but isn't there a cylindrical map type?
Yes. But then I have to make the maps 4 times bigger, cause they wrap all the
way around. And I like to keep memory usage down. I'm using a radial pigment
map now, just as Josh English suggested earlier in this thread.
sig.
Date: 26 Feb 2000 06:30:33
Message: <38B7B8FC.255D4E72@stud.ntnu.no>
Just realized how lame this post was. To defend myself, it was Dr. Emacs who
spoke, not me.
sig.
"Sigmund Kyrre Ås" wrote:
> personal to me:
> Jr is now #30
> all this?
> Sigmund Kyrre Aas
Date: 26 Feb 2000 18:07:54
Message: <slrn8bgml9.19o.sjlen@zero-pps.localdomain>
On Sat, 26 Feb 2000 10:53:29 +0100, Sigmund Kyrre Aas <as### [at] studntnuno> wrote:
4.7.8.9.1 The once Option
Normally there are an infinite number of repeating image maps,
bump maps or material maps created over every unit square of the
x-y-plane like tiles. By adding the once keyword after a file
name you can eliminate all other copies of the map except the one
at (0,0) to (1,1). In image maps, areas outside this unit square
are treated as fully transparent. In bump maps, areas outside
this unit square are left flat with no normal modification.  In
material maps, areas outside this unit square are textured with
the first texture of the texture list.
For example:
  image_map {
    gif "mypic.gif"
    once
 10:52pm  up 18:44,  6 users,  load average: 2.00, 2.09, 2.10
Date: 27 Feb 2000 04:31:12
Message: <38B8EEF1.2448CB75@stud.ntnu.no>
A cylindrical image map will wrap all the way around the ball, regardless of
wether once is used. My png-s are covering an 40 deg. angle. To avoid they
getting stretched beyond recognition, I would have to make them looong.
sig.
> For example:
>   image_map {
>     gif "mypic.gif"
>     once
> Cheers
> Steve              email mailto:sjl### [at] ndirectcouk
> %HAV-A-NICEDAY Error not enough coffee  0 pps.
> web http://www.ndirect.co.uk/~sjlen/
> or  http://start.at/zero-pps
Date: 29 Feb 2000 04:16:11
Message: <38bb8e5b@news.povray.org>
Never tried this myself, but try using "once" and "frequency" on a radial
map.
Another possibility : radial texture_map with something like:
[0.00 texture{myImageMap}]
[0.25 texture{myImageMap}]
[0.25 texture{Invisible}]}]
[1.00 texture{Invisible}]
I hope this helps,
Povingly
Philippe
Date: 1 Mar 2000 07:41:56
Message: <38BD1028.1180E8E9@stud.ntnu.no>
Thanks for your time, but as you can see from previous posts, I have solved
this. You would also see that texture maps cannot be layered..
sig.
> map.
> I hope this helps,
> Povingly
> Philippe
Date: 2 Mar 2000 03:24:41
Message: <38be2549@news.povray.org>
news:38BD1028.1180E8E9@stud.ntnu.no...
You're welcome
oops
*blushes*
 ^_^'
Well,... er
never mind
Philippe
