POV-Ray : Newsgroups : povray.binaries.images : 16x9 Server Time
20 Oct 2026 16:51:14 EDT (-0400)
  16x9 (Message 1 to 15 of 15)
Subject: 16x9
Date: 15 Feb 2000 05:55:52
Message: <38A930B6.B192D6A2@ij.net>
If I may comment, that is becoming a much more
common aspect ratio in the last few months.
Whatever happened to the Kerbs and the Sosovars?
Subject: Re: 16x9
Date: 15 Feb 2000 11:36:02
Message: <38A983C0.298A54CF@osu.edu>
where? here? interesting...
Subject: Re: 16x9
Date: 15 Feb 2000 12:35:24
Message: <38A98B99.FEF27574@pacbell.net>
I have never seen a monitor with that aspect ratio. It will never fly.
Subject: Re: 16x9
Date: 15 Feb 2000 12:49:04
Message: <38a99190@news.povray.org>
And now I link THEE, O Great Linkmaster. Tho the unit does lack wings, so I
agree that it will never attain flight.  : )
http://www.apple.com/displays/acd22/
Dirk
"Ken" <tyl### [at] pacbellnet> wrote in message
news:38A98B99.FEF27574@pacbell.net...
> Ken Tyler -  1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Subject: Re: 16x9
Date: 15 Feb 2000 14:11:18
Message: <38A9A4E0.42F63AB8@gci.net>
I heard of that ratio here in the postings and
have tried it out. The reasons that I like
it are
1) it is the letterbox ratio used in movies.
2) it cuts about 20% of the render time out.
3) it wasn't common, and I do things like that.
Mr. Art
"Often the appearance of reality is more important
than the reality of the appearance."
Bill DeWitt 2000
Subject: Re: 16x9
Date: 15 Feb 2000 17:43:13
Message: <38a9d681@news.povray.org>
How can it reduce render time ?? I really don't understand what you mean !
Pascal
Subject: Re: 16x9
Date: 15 Feb 2000 17:57:42
Message: <38A9D97D.B479C595@faricy.net>
If you just chop off the top and bottom of a 3:4 pic. If you increased the
width to keep the pixel count the same, it would do nothing for render time.
This chopping is kind of a cheap way of rendering in a smaller res.
___     ______________________________________________________
 | \     |_                 <dav### [at] faricynet> <ICQ 55354965>
 |_/avid |ontaine               http://www.faricy.net/~davidf/
"Sitting on a cornflake, waiting for the van to come" -Beatles
Subject: Re: 16x9
Date: 15 Feb 2000 17:58:04
Message: <38A9DA07.4BA68EAB@gci.net>
If I render a picture at 800x600, that is 480,000 pixels.
If I render a picture at 800x450, that is 360,000 pixels.
The second picture is 25% smaller. Depending on the scene,
the scene will render anywhere from 0% to 25% faster. If
what you do has a lot of background stuff, like clouds, or
trees that you don't need to see the tops of, this can help
cut into the render time. If you have a single object that
you need to see all of, this doesn't help much.
> Pascal
Mr. Art
Bill DeWitt 2000
Subject: Re: 16x9
Date: 16 Feb 2000 01:45:23
Message: <160220000745238550%a.raves@direct.a2000.nl>
A normal computer sized image could be 640 x 480 (format 4:3), a 16 x 9
image would then be 640 x 360, this you'd have to render less :-)
Anton
In article <38a9d681@news.povray.org>, Pascal Baillehache
> Pascal
Subject: Re: 16x9
Date: 16 Feb 2000 06:05:45
Message: <38aa8489@news.povray.org>
You know what is so annoying about you Matt?
It is that you never come out and say what you want to say.
I mean, really.
Blah, blah, blah.
Yak, dot, Yak, dot, com.
whatever.
Peter Warren
war### [at] hotmailcom
Subject: Re: 16x9
Date: 16 Feb 2000 07:04:01
Message: <xYyqOMp9qioEOLkymMXe7qTvzl5x@4ax.com>
Just for trivia's sake, I thought I would mention a few things I
learned while researching film formats for the IMP:
Most new movies are actually filmed in "Academy Format" which has an
aspect ratio of about 1.37:1 Movies made on 16mm film also share this
aspect ratio. There are also some movies being filmed in Panavision,
which has an aspect ratio of about 2.35:1 I won't even get into the
various IMAX formats, as most people consider those special cases.
The 16x9 letterbox format was chosen as a compromise format for wide
screen TV's. Movies aren't really shot in this format, they just get
cropped to it.
Personally, I render many of my images with a 3:2 aspect ratio, which
is the same aspect ratio used in 35mm film, for still photography. I
also use other ratios, including various vertical formats, square
images, and different horizontal formats. The POV-Ray default ratio of
4:3 happens to be one of my least favorite ratios to work with.
for what it's worth...
Glen Berry
Subject: Re: 16x9
Date: 16 Feb 2000 08:32:51
Message: <38AAA70F.25E487A9@gci.net>
What I haven't seen anyone say yet is that with WinMegaPOV,
you can use a camera like
camera	{
	location -z
	right image_width/image_height*x //<---------<<< important
	look_at 0
 and no mater what you set the width or height of the image to,
it is like looking through a window, just shaped differently. The
image doesn't distort. Without the right image_width/image_height*x
part, the image just gets squashed one way or another. I keep several
ini files that are each contain one aspect ratio at various sizes.
All I need do is select the ini file I want and then the image size.
The camera statement keeps it looking proper. My personal feelings is
that this should be the default action with the use of right in the
camera statement as a means of overriding the default. i.e.. you only
use right if you want to distort the image.
Oh, thanks for the different aspect ratios. New ini's are on the way.
> cropped to it.
> Glen Berry
Mr. Art
Bill DeWitt 2000
Subject: Re: 16x9
Date: 16 Feb 2000 19:45:07
Message: <p0OrOFQzpn5Pntl7AD9fuEKWbzbe@4ax.com>
On Wed, 16 Feb 2000 03:04:28 -0800, "Peter Warren"
>I mean, really.
That's what I really enjoy about his posts. They make me think and dig
around. And I have learned a few spicey slang words in the process :)
Peter Popov
pet### [at] tagpovrayorg
ICQ: 15002700
Subject: Re: 16x9
Date: 17 Feb 2000 04:04:06
Message: <38ABB985.BEC4C260@ij.net>
    It is called HDTV. Patience.
Subject: Re: 16x9
Date: 17 Feb 2000 04:10:13
Message: <38ABBAF3.BA2EFCB0@ij.net>
    But if using windows 98 and with background programs (and maybe X-Windows)
your actual usuable screen ratio is closer t0 16:9 than 4:3. I'm looking at an
atguard line on the top, there 98 lines on the bottom and to look at an image
from POV a separate window with a line at its top.
