POV-Ray : Newsgroups : povray.binaries.images : They're just people (141kb) Server Time
24 Nov 2026 14:28:14 EST (-0500)
  They're just people (141kb) (Message 1 to 24 of 24)
Subject: They're just people (141kb)
Date: 11 Feb 2000 15:08:42
Message: <38A46C48.BD37C1AD@inapg.inra.fr>
No, it's not some strange hair...
These are people, 9500 of them. Their size is adjusted to the size of
the underlying triangle.
1.5% of them fall to the ground.
Note : jpg really kills this picture and produces whitish spots where
yellow really is.
Credits :
Pov-Team & Nathan Kopp : Megapov 0.4
Poser 4 : people (12 differents types, 6 men, 6 women, stored in an
array)
Warp/Colefax : mesh compressor and related macros
Thomas Baier : 3DS2POV convertor
Rob Antonishen : chain (found through the POV links)
Kari Kivisalo : stone wall technique for the bottom wall
Other :
Walls, ground, door and window : height fields
The large wall is actually an acrylic painting used as a height field
(but textured with POV)
The bottom wall hf was generated with pov (crackle + J. VanSickle's
"blotches").
Window and streetlamp glow : media method 3
No radiosity used (added too much light).
Gilles Tran
The Book of Beginnings
http://www.mediaport.net/Artichaud/Tran/gtran.en.html
Download 'huma21.jpg' (141 KB)
Preview of image 'huma21.jpg'
Subject: Re: They're just people (141kb)
Date: 11 Feb 2000 15:17:22
Message: <38A46E0D.93991406@pacbell.net>
> the underlying triangle. 1.5% of them fall to the ground.
When art becomes stranger than fiction...
Date: 11 Feb 2000 15:45:07
Message: <8ED7D3CB0seed7@204.213.191.228>
C'est merveilleux!
Ingo
Date: 11 Feb 2000 15:48:53
Message: <38a475b5@news.povray.org>
As ever great idea, beautifully executed.
Mick
       http://www.minda.swinternet.co.uk/index.htm
"Gilles Tran" <tra### [at] inapginrafr> wrote in message
news:38A46C48.BD37C1AD@inapg.inra.fr...
> yellow really is.
> Credits :
> array)
> Other :
> "blotches").
> Gilles Tran
Date: 11 Feb 2000 16:37:24
Message: <MPG.130e99d0253bb03a989683@news.povray.org>
Gilles Tran wrote...
>yellow really is.
Whow! Amazing, a true Tran.
Rudy Velthuis
Date: 11 Feb 2000 16:38:46
Message: <38a48166@news.povray.org>
Whoa... what an imagination... ^_^*
Date: 11 Feb 2000 16:44:44
Message: <38a482cc@news.povray.org>
wow, quite impressive !
I wonder how you manage to mix all these soft together, but I'm a beginner
using only Pov !
congratulations :-)
Baillehache Pascal
Gilles Tran <tra### [at] inapginrafr> a écrit dans le message :
> yellow really is.
> Credits :
> array)
> Other :
> "blotches").
> Gilles Tran
Date: 11 Feb 2000 16:50:47
Message: <38a48437@news.povray.org>
First let me say...  Wow. I'm humbled by your
majesty!
Question, how did you manage to render this!?
Do you have a gig of RAM? What is the trick.
How long did it take?
Harold
Date: 11 Feb 2000 17:04:02
Message: <38A486F2.823DEDC@faricy.net>
Strange concept.
The render time must be incredible.
___     ______________________________________________________
 | \     |_                 <dav### [at] faricynet> <ICQ 55354965>
 |_/avid |ontaine               http://www.faricy.net/~davidf/
"Sitting on a cornflake, waiting for the van to come" -Beatles
Date: 11 Feb 2000 17:24:24
Message: <38A48B36.1DE1C13F@my-dejanews.com>
Yikes, you're not even on the same planet!
Those words popped out of my fingers, as a huge compliment, both in style and
artistic excellence...
Date: 11 Feb 2000 23:50:10
Message: <38A4E6BA.C6B8671A@tiac.net>
Awesome as usual. Creepy and beautiful.
If I were the big character I'd be *very* displeased to have a
bunch of little humans scurrying around on my skin like ants.
Phil
Date: 12 Feb 2000 00:05:54
Message: <38A4422D.7ABD2B23@home.com>
This is amazing as usually for your work of course!! Somehow this scene is
quite disturbing!
> yellow really is.
> Credits :
> array)
> Other :
> "blotches").
> Gilles Tran
Date: 12 Feb 2000 01:36:43
Message: <38A500D0.975E107D@geocities.com>
> yellow really is.
Please post a link to a PNG version.
Please, Please, Please, Please, Please, Please, Please, Please, Please,
Please, Please.
Date: 12 Feb 2000 02:06:22
Message: <38A506A8.735C5CC3@tiac.net>
I'll second that motion.
All in favor say  I...
Phil
Date: 12 Feb 2000 05:36:33
Message: <38a537b1@news.povray.org>
f.u.
Date: 12 Feb 2000 06:20:31
Message: <slrn8aafs1.ald.sjlen@zero-pps.localdomain>
Ugly.
  9:32am  up 2 days, 15:29,  2 users,  load average: 1.08, 1.13, 1.09
Date: 12 Feb 2000 07:13:27
Message: <38A54E7B.F60DDE3B@inapg.inra.fr>
Thanks to all for the comments. You'll forgive me if I group the answers.
Correction : I said that the bottom wall used the "blotches" pattern. This
pattern has been removed from Megapov 0.4 (I created the wall with 0.3 and
switched later to 0.4), probably because it was redundant with the "crackle
solid" pattern, which works in the same way.
I posted the (corrected) stone wall generation file in povray.text.scene-files
for those interested.
About render time and memory usage : at 3200 X 2400 (with antialiasing), it
took around 16 hours on a PII 350 and used 190MB of RAM. Not so much if you
consider the 250 millions of smooth triangles in the scene. With no
antialiasing and no area light it even runs very fast : there's almost nothing
but height-fields and meshes in that scene.
The only trick is that meshes are very efficient objects in povray memorywise
: using one mesh or 1000 copies of it is (almost) the same. In fact this is
this particular property that prompted me to do the scene. All you need is a
utility that gives you access to the mesh vertices and normals, in that case
the association of Warp's Mesh compressor and of Chris Colefax's mesh macros.
Here's a temporary link to a larger version (1600*1200, jpg, 1 MB)
It's a jpg with 1/5 compression ratio. Because of the high level of detail,
pngs remains too big (several MB).
Beware: the image is still 1 megabyte big !!!!
http://www.inapg.inra.fr/dsa/temp/huma21sm.jpg
You'll see that some of the people are imbedded in the wall, which makes the
scene even creepier.
G.
Date: 12 Feb 2000 12:14:30
Message: <38a594f6@news.povray.org>
wow, very very nice work - you really are quite good at this arnt you?
this will do for desktop wallpaper for a good while !
> yellow really is.
> Credits :
> array)
> Other :
> "blotches").
> Gilles Tran
Date: 12 Feb 2000 12:18:22
Message: <38A595EE.50FE0BFD@gci.net>
Your images have always been works of art and
this one is no exception. This is magnificent.
> yellow really is.
> Credits :
> array)
> Other :
> "blotches").
> Gilles Tran
Mr. Art
"Often the appearance of reality is more important
than the reality of the appearance."
Bill DeWitt 2000
Date: 12 Feb 2000 20:46:53
Message: <38a60d0d@news.povray.org>
> Please, Please.
and a little larger resolution
Date: 14 Feb 2000 12:30:41
Message: <38a83bc1@news.povray.org>
Wonderful!
Reminds me of a clive barker short story called (I think) "In the Hills, the
Cities"
Date: 15 Feb 2000 05:20:55
Message: <38A92B8B.BE7945B5@cyberhighway.net>
> > Please, Please.
I third the motion and maybe a 8000x6000 res....  (huge i know but it should
save the details lost in the jpg)
Date: 15 Feb 2000 05:25:04
Message: <38A92C84.F2DE54D1@cyberhighway.net>
Don't think i have read that one....  but Mr. Barker's Paintings are VERY
strange... (Reminds me of WeaveWorld in a way.....   {all the occupants of
Weaveworld attacking the self-proclaimed Archangel Michael[?]})
Tom Melly wrote:
> Wonderful!
> Cities"
Date: 15 Feb 2000 15:07:12
Message: <38A9B20F.18AAF83@inapg.inra.fr>
G.
