POV-Ray : Newsgroups : povray.binaries.images : They're just people (141kb) Server Time
3 Oct 2024 11:19:01 EDT (-0400)
  They're just people (141kb) (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: They're just people (141kb)
Date: 11 Feb 2000 23:50:10
Message: <38A4E6BA.C6B8671A@tiac.net>
Awesome as usual. Creepy and beautiful.
If I were the big character I'd be *very* displeased to have a
bunch of little humans scurrying around on my skin like ants.
Phil
Date: 12 Feb 2000 00:05:54
Message: <38A4422D.7ABD2B23@home.com>
This is amazing as usually for your work of course!! Somehow this scene is
quite disturbing!
Gilles Tran wrote:
> No, it's not some strange hair...
> These are people, 9500 of them. Their size is adjusted to the size of
> the underlying triangle.
> 1.5% of them fall to the ground.
> Note : jpg really kills this picture and produces whitish spots where
> yellow really is.
> Credits :
> Pov-Team & Nathan Kopp : Megapov 0.4
> Poser 4 : people (12 differents types, 6 men, 6 women, stored in an
> array)
> Warp/Colefax : mesh compressor and related macros
> Thomas Baier : 3DS2POV convertor
> Rob Antonishen : chain (found through the POV links)
> Kari Kivisalo : stone wall technique for the bottom wall
> Other :
> Walls, ground, door and window : height fields
> The large wall is actually an acrylic painting used as a height field
> (but textured with POV)
> The bottom wall hf was generated with pov (crackle + J. VanSickle's
> "blotches").
> Window and streetlamp glow : media method 3
> No radiosity used (added too much light).
> Gilles Tran
> The Book of Beginnings
> http://www.mediaport.net/Artichaud/Tran/gtran.en.html
Date: 12 Feb 2000 01:36:43
Message: <38A500D0.975E107D@geocities.com>
> yellow really is.
Please post a link to a PNG version.
Please, Please, Please, Please, Please, Please, Please, Please, Please,
Please, Please.
Date: 12 Feb 2000 02:06:22
Message: <38A506A8.735C5CC3@tiac.net>
I'll second that motion.
All in favor say  I...
Phil
Date: 12 Feb 2000 05:36:33
Message: <38a537b1@news.povray.org>
f.u.
Date: 12 Feb 2000 06:20:31
Message: <slrn8aafs1.ald.sjlen@zero-pps.localdomain>
Ugly.
  9:32am  up 2 days, 15:29,  2 users,  load average: 1.08, 1.13, 1.09
Date: 12 Feb 2000 07:13:27
Message: <38A54E7B.F60DDE3B@inapg.inra.fr>
Thanks to all for the comments. You'll forgive me if I group the answers.
Correction : I said that the bottom wall used the "blotches" pattern. This
pattern has been removed from Megapov 0.4 (I created the wall with 0.3 and
switched later to 0.4), probably because it was redundant with the "crackle
solid" pattern, which works in the same way.
I posted the (corrected) stone wall generation file in povray.text.scene-files
for those interested.
About render time and memory usage : at 3200 X 2400 (with antialiasing), it
took around 16 hours on a PII 350 and used 190MB of RAM. Not so much if you
consider the 250 millions of smooth triangles in the scene. With no
antialiasing and no area light it even runs very fast : there's almost nothing
but height-fields and meshes in that scene.
The only trick is that meshes are very efficient objects in povray memorywise
: using one mesh or 1000 copies of it is (almost) the same. In fact this is
this particular property that prompted me to do the scene. All you need is a
utility that gives you access to the mesh vertices and normals, in that case
the association of Warp's Mesh compressor and of Chris Colefax's mesh macros.
Here's a temporary link to a larger version (1600*1200, jpg, 1 MB)
It's a jpg with 1/5 compression ratio. Because of the high level of detail,
pngs remains too big (several MB).
Beware: the image is still 1 megabyte big !!!!
http://www.inapg.inra.fr/dsa/temp/huma21sm.jpg
You'll see that some of the people are imbedded in the wall, which makes the
scene even creepier.
G.
Date: 12 Feb 2000 12:14:30
Message: <38a594f6@news.povray.org>
wow, very very nice work - you really are quite good at this arnt you?
this will do for desktop wallpaper for a good while !
"Gilles Tran" <tra### [at] inapginrafr> wrote in message
news:38A46C48.BD37C1AD@inapg.inra.fr...
> yellow really is.
> Credits :
> array)
> Other :
> "blotches").
> Gilles Tran
Date: 12 Feb 2000 12:18:22
Message: <38A595EE.50FE0BFD@gci.net>
Your images have always been works of art and
this one is no exception. This is magnificent.
> yellow really is.
> Credits :
> array)
> Other :
> "blotches").
> Gilles Tran
Mr. Art
"Often the appearance of reality is more important
than the reality of the appearance."
Bill DeWitt 2000
Date: 12 Feb 2000 20:46:53
Message: <38a60d0d@news.povray.org>
> Please, Please.
and a little larger resolution
