POV-Ray : Newsgroups : povray.binaries.images : Tuesday Evening Enigma (mazepigm.jpg 83.3k bu) Server Time
24 Nov 2026 14:28:10 EST (-0500)
  Tuesday Evening Enigma (mazepigm.jpg 83.3k bu) (Message 1 to 20 of 20)
Subject: Tuesday Evening Enigma (mazepigm.jpg 83.3k bu)
Date: 8 Feb 2000 21:51:30
Message: <38A0D839.371F1B4E@aol.com>
Hello everybody. Attached is an image showing off a new pigment I found
today. I've been wanting to create a maze-like pigment for some time
now. Can you guess how it was done?
Here are some hints:
    It was made totally in PovRay; no paint programs were used.
    It was made with MegaPov (Superpatch works too).
    It's not a huge, complex iso function, although it uses small
functions for simple tasks you could already do in pov (so the functions
really don't matter).
Good evening~
Samuel Benge
E-Mail: STB### [at] aolcom
Visit the still unfinished isosurface tutorial:
http://members.aol.com/stbenge
Download 'mazepigm.jpg' (83 KB)
Preview of image 'mazepigm.jpg'
Subject: Re: Tuesday Evening Enigma (mazepigm.jpg 83.3k bu)
Date: 9 Feb 2000 00:08:11
Message: <38a0f63b@news.povray.org>
"SamuelT." <STB### [at] aolcom> wrote in message
news:38A0D839.371F1B4E@aol.com...
> today.
    Oooo...
    Not a chance. I don't see any repeats, are there any?
Date: 9 Feb 2000 01:26:00
Message: <slrn8a21so.v8.ron.parker@parkerr.fwi.com>
It looks kinda like this, but mine doesn't have all the loops, and it
has a definite diagonal tendency.
camera {location 20*y sky y look_at <15,0,15>}
light_source {20*y rgb 1}
plane {y,0
    crackle solid metric 1
    pigment_map {
      [.5 gradient x color_map{[.5 rgb 0][.5 rgb 1]} warp{repeat x}]
      [.5 gradient z color_map{[.5 rgb 1][.5 rgb 0]} warp{repeat z}]
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 9 Feb 2000 01:49:35
Message: <slrn8a238u.v8.ron.parker@parkerr.fwi.com>
Or this version, slightly loopier but with the odd broken piece:
plane {y,0
    bozo
    pigment_map {
      [.5 gradient x
          color_map{[.25 rgb 0][.25 rgb 1][.75 rgb 1][.75 rgb 0]}
          warp{repeat x} scale sqrt(2) rotate 45*y ]
      [.5 gradient x
          warp{repeat x} scale sqrt(2) rotate -45*y]
    scale 100
    warp {repeat x offset 50*y}
    warp {repeat z offset 60*z}
    warp {reset_children}
Date: 9 Feb 2000 02:26:34
Message: <38a116aa@news.povray.org>
All I know is that pigments can be made into new patterns but I don't see how
you got a seemingly infinitely changing maze out of it.  It's great, never seen
one before.
"SamuelT." <STB### [at] aolcom> wrote in message news:38A0D839.371F1B4E@aol.com...
| Good evening~
| Samuel Benge
Date: 9 Feb 2000 10:39:04
Message: <38a18a18@news.povray.org>
Excellent - at first I thought it was a bitmap repeated - but I didn't see
any repeating patterns.
Will you be sharing your pigment code with the rest of us?
Mike
> Good evening~
> Samuel Benge
Date: 9 Feb 2000 11:02:04
Message: <38A18F85.4081BC69@spiritone.com>
I'm almost thinking that you found a way to randomize a checke pattern with
limiting the steps to 90 degree turns when caclulcation the tubulence... but
I'm probably way off.
> Good evening~
> Samuel Benge
Josh English
eng### [at] spiritonecom
Date: 9 Feb 2000 12:14:46
Message: <slrn8a383r.11r.ron.parker@ron.gwmicro.com>
Okay, I'm going to assume this is pretty much it until you say otherwise:
#macro MazePigment(Pig1,Pig2)
  #local Pig3=pigment {
    gradient x
    pigment_map {[.25 Pig1][.25 Pig2][.75 Pig2][.75 Pig1]}
    warp {repeat x} scale sqrt(2) rotate 45*y
  function { noise3d(floor(x)+.5,floor(y)+.5,floor(z)+.5) }
  pigment_map {
    [.5 Pig3 ]
    [.5 Pig3 rotate 90*y ]
camera {location 80*y sky z look_at 0}
light_source {80*y rgb 1}
plane {y 0
    MazePigment(pigment{color rgb <.5,.5,1>}, pigment {color rgb 0})
Date: 9 Feb 2000 22:33:28
Message: <38A233D7.C56EB241@aol.com>
It does repeat.
Ron, your' guesses were excellent! You had the basic idea down, but not
the procedure. I like your first try at it best, although it does have a
diagonal tendancy, and I could not remove it. Best thing about yours is
that it doesn't repeat. I didn't know metric did that to crackle.
Well, here's mine in macro form. It may need to be edited if you paste
it into pov.
// Maze( M_Dim, M_Complex, M_Randseed )
// M_Dim is the dimensions for the tile. '4' would let you place it on a
// 4-unit square cube
// M_Complex is how complex you want it. Values range from 0 to 2.
// good values are from 1 to 2
// M_Randseed is just the seed value for the maze. Enter any value to
// see different patterns
#version unofficial MegaPov .3;    // needed for MegaPov .4 users
camera{ location<0,10,-15> look_at 0 angle 40 rotate y*-30 }
light_source{ <100,200,100>,1 }
background{ <.4 .7 1> }
#macro Maze( M_Dim, M_Complex, M_Randseed )
 #local M_Dim=M_Dim*8;
 #local M_Rand=M_Dim/20
 #local M_Pat=
  function{
   pigment{
    image_map{
     pattern M_Dim, M_Dim{ function noise3d(x,y,z) scale( .25/M_Rand
)/M_Complex translate y*rand( seed( M_Randseed ) ) }
     map_type 0    //include 'once' to test the tiling
    translate<-.5, -.5, -.5> rotate x*90 scale M_Dim/4
 #local M_Pigm=
  function{
   pigment{
    function M_Pat( x, y, z ) scale .5
    pigment_map{
     [.5 function x*2 sine_wave color_map{ [.5 rgb 0][.5 rgb 1] } ]
     [.5 function z*2 sine_wave color_map{ [.5 rgb 0][.5 rgb 1] } ]
 function{ M_Pigm( x, y, z ) }
box{<-4,-1,-4>,<4,1,4>
 pigment{ Maze( 8, 1.25, 13598 ) }
Samuel Benge
Visit the still unfinished isosurface tutorial: http://members.aol.com/stbenge
Date: 10 Feb 2000 04:00:39
Message: <38a27e37@news.povray.org>
That is so neat.  And a-mazing you could ever come up with a similar pattern as
well as that too.
Only thing I can see unmaze-like about both Sams and Rons is they have many
closed paths.  Most mazes I've ever seen don't a completely sealed off sections
like these do.  But who cares, it's a great pattern.
"Ron Parker" <ron### [at] povrayorg> wrote in message
news:slr### [at] rongwmicrocom...
|     gradient x
|   pigment_map
|     [.5 Pig3 ]
| #end
| plane {y 0
|   pigment {
Date: 10 Feb 2000 11:15:03
Message: <38a2e407@news.povray.org>
i o u
thanks,again.
peter
Date: 10 Feb 2000 11:25:56
Message: <slrn8a5pjf.v8.ron.parker@ron.gwmicro.com>
On Wed, 09 Feb 2000 19:43:19 -0800, SamuelT. wrote:
>It does repeat.
One thing that might remove some of it would be to use my later unit-square
patterns (Pig3, Pig3 rotate 90*y) since they don't have the left/bottom bias
of the tiles I used in the first example.  None of my attempts repeat, btw.
I have to be honest: crackle solid metric 1 has some problems.  It doesn't
seem to do very well for a certain range of numbers, but I haven't stopped
to determine what that range is.  That's why the translate 20.
Finally, I leave you all with yet another maze pattern, of sorts. This is
an adaptation of an idea I first saw on the Commodore VIC 20 years and years
ago, and is the basic idea behind my second and third tries at the maze code:
#declare S=seed(12346);#declare Y=0;#while(Y<20)#declare X=0;#while(X<50)
#if (rand(S)<.5)#debug"/"#else#debug"\\"#end#declare X=X+1;#end#debug"\n"
#declare Y=Y+1;#end
Date: 10 Feb 2000 16:48:57
Message: <38A331ED.DD9C28DF@faricy.net>
Oh! See, I was looking fot this "metric" thing and could not find it. What
does it do?
___     ______________________________________________________
 | \     |_                 <dav### [at] faricynet> <ICQ 55354965>
 |_/avid |ontaine               http://www.faricy.net/~davidf/
"Sitting on a cornflake, waiting for the van to come" -Beatles
Date: 10 Feb 2000 18:07:49
Message: <slrn8a6hl3.ov.ron.parker@linux.parkerr.fwi.com>
>does it do?
It changes the distance metric used to determine which centroid is
closest.  metric 2 is the default, which corresponds to what's known
as the 2-norm, |V|_2=sqrt(V.x^2+V.y^2+V.z^2).  This is also usually
called the Pythagorean Theorem.  metric 1 is commonly called the
"taxicab distance" as it's the distance a taxicab would drive if it
had to follow city streets in a standard block pattern.
It's |V|_1=V.x+V.y+V.z.  In general, POV raises each component of
the vector to the specified power, then adds them together, then
raises them to the reciprocal power (i.e. 1/2 if the metric was 2.)
In the limit as the metric approaches infinity, the norm is equal to
whichever of V.x, V.y, or V.z is largest.  In the space between 2 and
infinity, neat things can happen.
Now ask me about form. :)
Date: 10 Feb 2000 18:22:42
Message: <38a34842@news.povray.org>
What about it? Tell me more...
Date: 10 Feb 2000 19:12:25
Message: <38a353e9@news.povray.org>
Hey Teach,
What is form?
Date: 10 Feb 2000 21:18:53
Message: <slrn8a6sre.sq.ron.parker@linux.parkerr.fwi.com>
form is used to set the equation crackle uses to calculate the value
of the pattern at any given point.  The default form is <-1,1,0>, which
returns the difference between the second-closest point and the closest
point.  Form takes the distance to the closest point and multiplies it
by the first term, the distance to the second-closest point by the second
term, and the distance to the third-closest point by the third term, then
adds them all up.  Messing with form can give completely different patterns.
form <1,0,0>, for example, gives you something that looks kinda like a
bunch of bacteria.
Subject: metric (was: Re: Tuesday Evening Enigma (mazepigm.jpg 83.3k bu))
Date: 11 Feb 2000 02:54:52
Message: <qqmn1p85g37.fsf_-_@schlatt.fmi.uni-konstanz.de>
ron### [at] povrayorg (Ron Parker) writes:
> >does it do?
You probably meant |V|_1 = |V.x| + |V.y| + |V.z|. In Germany they call this
the Manhattan metric, because standard block pattern aren't standard
here.
Another nice metric I know is the metric of the French railway:
You always have to travel via Paris. So, the distance between two points
A and B is the distance from a A to Paris plus the distance from Paris
to B. There is an exception though: If A, B and Paris lie on a straight
line, it's the distance between A and B.
Formally:
d(A,B) = |A-B|        if P in (A,B)
         |A-P|+|P-B|  otherwise
where | | denotes the Euclidean norm.
Perhaps we should start to distinguish between "metric" and "norm".
"metric" denotes something that can be interpreted as a distance
between to points. "norm" denotes something that can be interpreted
as the distance of a point to the origin in a vector space.
These notions are interconnected though. If you have a norm | |, you can
easily create a metric d by defining d(A,B) as d(A,B):=|A-B|. However,
this doesn't work the other way round. If you are given a norm, you
can't -- generally -- define a metric such that the equation above holds.
In particular, this isn't possible for the "metric of the French railway".
(For seeing this, we must define "norm" and "metric" more precisely.
If someone really wants to know, please ask.)
http://thomas.willhalm.de/ (includes pgp key)
Date: 11 Feb 2000 03:26:46
Message: <qqmitzw5em1.fsf@schlatt.fmi.uni-konstanz.de>
> bunch of bacteria.
I assume that you know:
Steven Worley
A Cellular Texture Basis Function
Siggraph 1996
He has created some very nice textures by adding crackle patterns of
different scale. By this, the pattern becomes some sort of fractal.
Subject: Re: metric (was: Re: Tuesday Evening Enigma (mazepigm.jpg 83.3k bu))
Date: 11 Feb 2000 08:33:37
Message: <slrn8a83tg.v8.ron.parker@ron.gwmicro.com>
>> >does it do?
>here.
Whoops, you're right.  Thanks for the correction.
Yes, my description was a little sloppy there.  I was thinking of the
closest centroid as the origin in each case, but of course it isn't.
