POV-Ray : Newsgroups : povray.binaries.images : Lamp shade, Part II Server Time
25 Oct 2026 14:57:19 EDT (-0400)
  Lamp shade, Part II (Message 1 to 16 of 16)
Subject: Lamp shade, Part II
Date: 27 Jan 2000 21:11:45
Message: <3890fae1@news.povray.org>
Thanks for all your suggestions on Part I.  For you who have been following
the story, here's what I did this time:
rgbft <0.8, 0.85, 0.8, 0.75, 0.15>
I just fiddled with f and t until it looked okay.  The bathroom light
(fluorescent) used a higher t value (something like 0.25).  no_shadow looked
too unreal, and I didn't want to jack with media since the final product
will be an animation (walk-thru).  What do you think?  BTW, I'm kinda proud
of the carpet texture.
Download 'room_bi4.jpg' (28 KB)
Preview of image 'room_bi4.jpg'
Subject: Re: Lamp shade, Part II
Date: 27 Jan 2000 21:32:57
Message: <3890FFF9.5188BE58@gci.net>
Looks clean and clear to me.
Mr. Art
"Often the appearance of reality is more important
than the reality of the appearance."
Bill DeWitt 2000
Date: 27 Jan 2000 22:06:10
Message: <389104E5.64C76FB8@faricy.net>
Glad to see you got it fixed :-)
Date: 28 Jan 2000 00:18:18
Message: <3891269a@news.povray.org>
The room is literally going to shimmer when animated if your camera moves.  A
side effect of having small patterns like those in the doors, walls, carpet.
Might help if 'jitter' is set to 0.0 but I wouldn't count on it too much.
Good going on the lights and room in general.  The doorknobs seem awfully tiny
to me.
"cadman" <NOS### [at] graffitinet> wrote in message
news:3890fae1@news.povray.org...
Date: 28 Jan 2000 05:12:03
Message: <38916b73@news.povray.org>
"Bob Hughes" <omn### [at] hotmailcom?subject=PoV-News:> wrote in message
news:3891269a@news.povray.org...
A
carpet.
tiny
> to me.
a healthy dose of aa might fix that, you will have to render a few frames
and see....
and yes the doorknobs seem tiny to me to.. (glad to see that weird shadow
has gone, looks much better), is there any rad used?
Date: 28 Jan 2000 13:11:33
Message: <389116CC.3D4FD545@usit.net>
Looks good. I'd like to see it with radiosity, and I agree with Rick a little
AA would probably help.
Reminds me of a bathroom scene I once worked on. :)
Jay Raney
Date: 28 Jan 2000 16:58:12
Message: <3890C1AB.9D9E6072@earthlink.net>
Door knobs...? I did not realize there were ant till i read the thread...
The carpet needs some kind of deep normal to simulate carpet nap [and shadows]
The lights look wonderful... The light in the bathroom sheds a strange pattern
on the ceiling... the wall behind the sink and mirror causes the light to make
a straight line parallel w the left wall... it should cause a triangle of
shadow in the small corner similar to the one in the right hand corner... (but
smaller.)
I have no idea how to do this maybe move the light farther out from the
wall...?
hope to see a fully antialised pict shoeing all the detail... looks great...
Date: 28 Jan 2000 18:24:07
Message: <38922517@news.povray.org>
Thanks.  Will the aa make the animation funny?  I will do radiosity
(MegaPOV) if rendering times don't grow too much.  Touché on the door
knob--I'll fix that.
cadman <NOS### [at] graffitinet> wrote in message
following
looked
proud
Date: 28 Jan 2000 18:50:15
Message: <38922b37@news.povray.org>
Well for one thing if 'jitter' is used anywhere (arealights, antialiasing) then
any animation is likely to suffer the dance of the pixels effect.
I seldom use a real fine AA for animations simply because they tend to have
enough motion that the smoothness isn't as noticeable anyway.  Making it a
faster total render time.  However lack of any AA whatsoever isn't going to stop
pixel jumping unless there are no patterns or at least none with small scale
variations.  And using some AA should help prevent the "jaggies' from jumping
somewhat too.
Pretty much the way you would think it would be.
news:38922517@news.povray.org...
| following
| looked
| proud
Date: 28 Jan 2000 18:52:57
Message: <38922bd9@news.povray.org>
How much aa would you recommend ? 0.3?
Bob Hughes <omn### [at] hotmailcom?subject=PoV-News:> wrote in message
news:38922b37@news.povray.org...
then
have
to stop
scale
jumping
> somewhat too.
> Bob
> | following
> | looked
product
> | proud
Date: 28 Jan 2000 19:01:43
Message: <38922de7@news.povray.org>
That's a good number, especially since it's the default.  I've used 0.4
sometimes there's almost all motion in the scene (usually goes to Mpeg anyhow
which tends to blend things... your mileage may vary for type of final format).
Might be that you would want more AA (+a0.2) and less depth (+r2) or the other
way around (+a0.3 +r4).  It's really scene dependent.
news:38922bd9@news.povray.org...
Date: 28 Jan 2000 19:16:02
Message: <3890E1FB.680463E9@earthlink.net>
Unless the door on the right goes to a small closet it looks too small...
Date: 28 Jan 2000 19:36:46
Message: <3892361e@news.povray.org>
In article <3890fae1@news.povray.org>, "cadman" <NOS### [at] graffitinet> wrote:
I'm currious, what are the finish (and normal) settings on the shade (which is
actually a cover isn't it, sometimes referred to as a lens, like in
fluorescent lamps)?
PHIL
Date: 28 Jan 2000 21:18:54
Message: <38924e0e@news.povray.org>
True, true.  the whole texture is (no normal):
#declare K_LIGHT_SHADE = texture {
        pigment { color rgbft <0.9176471, 0.8588235,
0.7411765,0.75,0.15>*<0.85,0.85,0.85,1,1> }
        finish {
                diffuse 0.99
                specular 0.8
                roughness 0.9
                reflection 0.05
Philip Bartol <phi### [at] cleanwebnet> wrote in message
news:3892361e@news.povray.org...
following
(which is
> fluorescent lamps)?
> PHIL
Date: 28 Jan 2000 21:19:27
Message: <38924e2f@news.povray.org>
Thanks,  I'll give it a shot and let you know what happens.
news:38922de7@news.povray.org...
anyhow
format).
other
> Bob
Date: 1 Feb 2000 17:16:37
Message: <slrn89d9qh.14r.sjlen@zero-pps.localdomain>
This looks so much better.  Where's that light patch
coming from, the circular patch to the top left of
the door, and like bob said the door knobs need
a rethink.
Keep us posted.
  9:22am  up  7:50,  3 users,  load average: 2.10, 2.06, 2.02
