Hey all,
I'm working on a lamp that I saw in a waiting room the other day. The
problem is the lamp shade. It should be opaque in that you can't see thru
it but transparent in that it lets light out. Is such a thing possible? Is
this a job for media??? I'm clueless.
Eric
"A wise and frugal government, which shall restrain men from injuring one
another, which shall leave them otherwise free to regulate their own
pursuits of industry and improvement, and shall not take from the mouth of
labor the bread it has earned. This is the sum of good government."
- Thomas Jefferson
- First inaugural address, 1801
http://www.ametro.net/~ericfree
Download 'lamp.jpg' (21 KB)
Preview of image 'lamp.jpg'
You are reffering to translucency. This can only be achieved by using
blurred transparency available in... what a second... it isn't available...
oh, Chriiiis...!
On Mon, 24 Jan 2000 12:56:26 -0500, "TonyB"
>oh, Chriiiis...!
Try double_illuminate and radiosity in MegaPOV.
Peter Popov
pet### [at] usa net
ICQ: 15002700
no_shadow
Hurts, don't it?
-Mike
On Mon, 24 Jan 2000 11:06:57 -0600, Eric Freeman wrote:
>Hey all,
As well as the other solutions others have offered, media might do the trick
if used (im)properly. Render this and see if it approximates the effect you're
looking for. In this case, it's not so much that the shade isn't translucent
as it is that the scattered light overwhelms anything you might see through
the shade. Real lampshades are like this, too, I think.
difference {
cone {0,1,y,.75}
cone {-.01*y,.95,1.01*y, .70}
hollow
texture {pigment {color rgbf <1,.9,.7,1>}}
interior {
media {
scattering {2,rgb <20,18,14>}
absorption 1
samples 10,20
torus { 1,.02 pigment {color rgb 0}}
torus { .75,.02 pigment {color rgb 0} translate y}
light_source { .5*y rgb 2*<1,.9,.6> }
plane {y,-1 pigment {color rgb 1}}
plane {-z,-1.01 pigment {color rgb 1}}
cylinder {-y,.2*y,.1 pigment {color red 1}}
camera { location .5*y-10*z look_at 0 }
These are my opinions. I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Yes, scattering media can do the job.
See also my post 'Translucency demonstration (97 K)' from 12.04.99
It's more realistic, but significantly slower than double_illuminate.
Margus
In article <388c922b@news.povray.org>, "TonyB"
> available...
> oh, Chriiiis...!
Ok, ok. I will fix up a version using a more standard syntax than my
current patch and post the changed files...when I get the time. :-)
I will put this on my to-do list. I may not have time until the
weekends, though.
I have released a patch which implements it, but it is an older syntax
which I have thought of improvements for.
Chris Huff
e-mail: chr### [at] yahoo com
If you have something right up behind the shade you can see the outline. I think
that the light coming through is scattered so much that you can't tell where it's
coming from.
___ ______________________________
| \ |_ <dav### [at] faricy net>
|_/avid |ontaine <ICQ 55354965>
It seems a lot like blurred reflection; is it just as slow?
> weekends, though.
> Chris Huff
> Web page: http://chrishuff.dhs.org/
Samuel Benge
E-Mail: STB### [at] aol com
Visit the still unfinished isosurface tutorial:
http://members.aol.com/stbenge
In article <388CFA43.D8586A75@aol.com>, "SamuelT." <STB### [at] aol com>
Yes. I actually just copied over some of the blurred reflection code
into Refract() and made some very slight modifications, I didn't
actually write much.
I have gotten started on a new transparence patch, the syntax might
eventually be like this:
finish {
transparence {
transparence_blur AMOUNT
blur_samples SAMPLES
filter_pigment {PIGMENT}
transmit_pigment {PIGMENT}
I will release the code when I have the blur done, I will then make an
attempt at the filter_pigment and transmit_pigment. Those last two will
simply allow you to specify a color for the filter or transmit by using
a pigment. It might take a while, though, I have to re-learn much of the
lighting code, and account for dispersion, photons, etc.(it is based on
MegaPOV 0.3, and there are a lot of changes from the official version)
Chris Huff
>finish {
> transparence {
This just got me thinking (actually the idea has been floating around in my
head for a while), the way reflection has been growing, wouldn't it be nice
if instead of
finish
reflection_type
reflection_min
reflection_max
reflect_metallic
etc.
we could have
finish
reflection
val / min, max
type
metallic
etc.
wouldn't it be shorter and less bothersome than reflection_x? I think that
the number of reflection parameters have gotten to a point where this would
be a good idea.
Eric Freeman wrote:
> Hey all,
> Eric
I would use those patches in povray that are translucent, like the
bicubic patch.
Here's a example code. Have a look at the texture statement. It's only
rgb ... not rgbt.
camera {location <0,5,0>
look_at 0}
light_source {y*0.5 rgb 4}
bicubic_patch{
type 0
flatness 0.001
u_steps 4
v_steps 4
<0,0,0>,<1,1,0>,<2,1,0>,<3,0,0>,
<0,1,1>,<1,1,1>,<2,1,1>,<3,1,1>,
<0,1,2>,<1,1,2>,<2,1,2>,<3,1,2>,
<0,0,3>,<1,1,3>,<2,1,3>,<3,0,3>
texture{pigment{rgb<1.0,1.0,0.8>}
finish {ambient 0
diffuse 0.4
reflection 0}
translate <-1.5,0,-1.5>
Hope this one helps.
Marc Schimmler
Download 'bezier.jpg' (6 KB)
Preview of image 'bezier.jpg'
In article <388d1251@news.povray.org>, "TonyB"
> my
> nice if instead of
> finish
> reflection_type
> reflection_min
> reflection_max
> reflect_metallic
> etc.
> we could have
> finish
> reflection
> val / min, max
> type
> metallic
> etc.
> that
> would be a good idea.
I have done something similar to this in my reflectivity patch, which
mostly just gave a new syntax to blurred/angle-dependant reflections.
The syntax for this patch is pretty strange,though. Several things are
controlled by patterns instead of float values.
But it wouldn't be difficult at all to simply add an alternate syntax. I
don't really care for the current one...
Chris Huff
You could try adding no_shadow to the shade, then give the shade some amient
value to make it look like it's glowing from the inside, but that won't make a
defined shadow against the wall, so make a slightly smaller version that is grey
with high transmit value (but not 1) to create the shadow effect.
Just a guess at a workaround
Eric Freeman wrote:
> Hey all,
> Eric
> - Thomas Jefferson
> [Image]
Josh English
eng### [at] spiritone com
Maybe keep the shadow but give it a texture with high ambience and use a gradient y
to make it brighter (more ambient) where it's closer to the bulb.
I sure appreciate everybody's input. I'm going to try all of your
suggestions and see which one (or maybe something else) works.
Eric
- Thomas Jefferson
