Here it is again... The reflectiveness of it was too hard to manage,
So I gave it the standard white hull.
Bryan Valencia
Software Services - Making Windows Scream
http://www.209software.com
mailto:bry### [at] 209software com
Download 'space3.jpg' (34 KB)
Preview of image 'space3.jpg'
Radiositied? What is the big white disk?
Well it is certainly much more visible now :-)
___ ______________________________
| \ |_ <dav### [at] faricy net>
|_/avid |ontaine <ICQ 55354965>
Still rather dark on this end. Good modeling, but I feel something is
missing at the rear end. Thrusters or a tower with future tech 125 on
it.
Oh, and have you checked out Nathan's lens flare?
sig.
> Bryan Valencia
> [Image]
Sigmund Kyrre Aas
Trondheim, Norway
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
<body text="#000000" bgcolor="#FFFFFF" link="#FF0000" vlink="#800080" alink="#0000FF">
Lens Flare: Point me to it.
<br>
<br>
<p>"Sigmund Kyrre Ås" wrote:
<blockquote TYPE=CITE>Still rather dark on this end. Good modeling, but
I feel something is
<br>missing at the rear end. Thrusters or a tower with future tech 125
on
<br>it.
<p>Oh, and have you checked out Nathan's lens flare?
<p>sig.</blockquote>
</body>
</html>
http://nathan.kopp.com/nkflare.htm
Ken Tyler - 1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Ok, this is before I got the lens flare post, but it shows the current
evolution of the project.
This was rendered poster size at 3456x1728 using megapov.
It took 28 hours to complete
Of course I rescaled it for the post :)
[Image]
I will REPLY with some detail pics.
Bryan Valencia
Download 'us-ascii' (2 KB)
Download 'c:\temp\nsmail10.jpeg.jpg' (41 KB)
Preview of image 'c:\temp\nsmail10.jpeg.jpg'
[Image]
Download 'us-ascii' (1 KB)
Download 'c:\temp\nsmaildo.jpeg.jpg' (21 KB)
Preview of image 'c:\temp\nsmaildo.jpeg.jpg'
[Image]
Download 'c:\temp\nsmailsq.jpeg.jpg' (112 KB)
Preview of image 'c:\temp\nsmailsq.jpeg.jpg'
ok, I added the lens flare thing, But I may have screwed it up... I am not
getting any flare effect.
Since this is my first time, can someone tell me what I did wrong?
> // Persistence of Vision Ray Tracer Scene Description File
> // File: Space.pov
> // Vers: 3.1
> // Desc: A Typical Space Scene
> // Date: 1/13/2000
> // Auth: Bryan Valencia
> #include "colors.inc" // Standard Color definitions
> #include "textures.inc" // Standard Texture definitions
> #include "ship2000.inc"
> global_settings{
> radiosity{
> brightness 3.3 //float value that is the degree to which ambient values
are brightened (3.3)
> count 100 //number of rays that are sent out (100)
> distance_maximum 1 // (required) sets the distance in model units from a
sample at which the error is guaranteed to hit 100% (0)
> error_bound .4 //the fraction of error tolerated(.4)
> gray_threshold .5 //grays it down a little, to make your scene more
believable (.5)
> low_error_factor .8 //sets the amount that the error bound is dropped during
the preliminary image passes(.8)
> minimum_reuse .015 //the fraction of the screen width which sets the
minimum radius of reuse for each sample point (.015)
> nearest_count 6 //the maximum number of old ambient values blended
together to create a new interpolated value (6) (<4 for debugging)
> recursion_limit 1 //how many recursion levels are used to calculate the
diffuse inter-reflection. Valid values are one and two. (1)
> #declare Pic= function{
> pigment{ marble turbulence 3.35
> color_map{
> [0 color Black]
> [1 color White]
> scale <.5,.1,.5>
> #declare R0=1;
> #declare FUNC1=function {"sphere",<R0>}
> #declare Planet=isosurface {
> function{FUNC1(x,y,z)-(Pic(x,y,z)/10)}
> bounded_by {sphere {0,2.2}}
> method 2
> max_gradient 10
> #declare ThePlanet=union{
> object{Planet
> texture{
> /* pigment{checker color Red color Green scale 1/1000}*/
> pigment{bozo turbulence 3.409875
> color_map{
> [0, .95 color Black color Gray]
> [.95, 1.001 color Green color Yellow]
> scale .01
> finish {phong 0.4}
> sphere{<0,0,0>,1.035 texture{pigment {color Green} finish{ambient .7} }rotate y*1
scale .99 }
> object{ThePlanet scale 1000}
> #declare ShipLoc = <-20,1085,-35>
> #declare ShipRot = <0,0,0>
> #declare CamLoc = <7, 2, 1>
> camera{
> //postercam settings
> up y*1
> right x*2
> location CamLoc
> look_at <0,0,0>
> rotate ShipRot
> translate ShipLoc
You have to remove the ship, because I didn't send the file.
> object{Ship2000
> texture{
> pigment{color White}
> finish{Shiny}
> rotate ShipRot
> translate ShipLoc
> sky_sphere{
> pigment{bozo
> color_map {
> [0,0.95 color Black color Black]
> [0.95,1 color Blue color White]
> scale 1/500
> #declare SunLoc=<-5000,1000,-200>*100;
> //cylinder{<0,0,0>,SunLoc, 100 pigment{color Red} finish{ambient 1}}
> light_source{SunLoc color White*5
> looks_like{
> sphere{<0,0,0>,50000 no_shadow
> finish{ambient 1}
> //settings for the Lens Flare Thingy
> #declare cam_loc = CamLoc;
> #declare light_loc = SunLoc;
> #declare lookat = ShipLoc;
> #declare sky_vect = y;
> #declare flare_type = "35mm"
> #declare flare_size = 1;
> #declare flare_brightness = 1;
> #include "nkflare.inc"
Bryan
There is a lot going on here. It's interesting to see
the various working images you posted.
I've never used lense flare so I'm no help on that.
Good luck with your Ship project.
Peter Warren
war### [at] hotmail com
Render this in place of the original (might want to save other first) and
you'll see the flare. Maybe this will help you figure it out from here.
// postercam settings
up y*1
right x*2
location CamLoc
look_at <0,0,0> // this was not the same as lens lookat.
rotate ShipRot
translate ShipLoc // trouble spot. see below.
// settings for the Lens Flare Thingy
#declare lookat = <0,0,0>; // now the same as camera look_at
#declare sky_vect = <0,1,0>;
#declare flare_size = 3; // increased for better seeing.
union { #include "nkflare.inc" // be sure Library_Path= points to all flare
files.
rotate ShipRot // here was the trouble...
translate ShipLoc // needed to align with camera setup.
"Bryan Valencia" <bry### [at] 209software com> wrote in message
news:3890F5BC.B0BC3B7C@209software.com...
| > // File: Space.pov
| > // Vers: 3.1
| > // Date: 1/13/2000
| > global_settings{
| > radiosity{
| > brightness 3.3 file://float value that is the degree to which
ambient values are brightened (3.3)
| > count 100 file://number of rays that are sent out (100)
from a sample at which the error is guaranteed to hit 100% (0)
| > error_bound .4 file://the fraction of error tolerated(.4)
| > gray_threshold .5 file://grays it down a little, to make your
scene more believable (.5)
| > low_error_factor .8 file://sets the amount that the error bound is
dropped during the preliminary image passes(.8)
| > minimum_reuse .015 file://the fraction of the screen width which
sets the minimum radius of reuse for each sample point (.015)
| > nearest_count 6 file://the maximum number of old ambient values
blended together to create a new interpolated value (6) (<4 for debugging)
| > recursion_limit 1 file://how many recursion levels are used to
calculate the diffuse inter-reflection. Valid values are one and two. (1)
| > color_map{
| > [0 color Black]
| > [1 color White]
| > scale <.5,.1,.5>
| > #declare R0=1;
| > method 2
| > max_gradient 10
| > object{Planet
| > texture{
| > color_map{
| > scale .01
| > finish {phong 0.4}
.7} }rotate y*1 scale .99 }
| > camera{
| > file://postercam settings
| > up y*1
| > right x*2
| > location CamLoc
| > look_at <0,0,0>
| > rotate ShipRot
| > translate ShipLoc
| > object{Ship2000
| > texture{
| > finish{Shiny}
| > rotate ShipRot
| > translate ShipLoc
| > sky_sphere{
| > pigment{bozo
| > color_map {
| > scale 1/500
| > file://cylinder{<0,0,0>,SunLoc, 100 pigment{color Red} finish{ambient 1}}
| > looks_like{
| > finish{ambient 1}
| > file://settings for the Lens Flare Thingy
whats the focus of the scene your creating the ship or the weird
swirling thingy?
news:38909A83.E34DEFAB@209software.com...
Download 'iso-8859-1' (2 KB)
The ship is just a place holder. Really I am playing with my first
isosurface sphere.
> swirling thingy? Rick
Bryan Valencia
>Content-Disposition: inline; filename="C:\TEMP\nsmailSQ.jpeg"
The file name really sucks. ^^^^^^^^^^^^^^^^^^^^^^^^
Steve email mailto:sjl### [at] ndirect co uk
%HAV-A-NICEDAY Error not enough coffee 0 pps.
or http://start.at/zero-pps
1:22pm up 11:52, 3 users, load average: 2.07, 2.04, 2.06
Bryan Valencia wrote in message <38909B94.4627726C@209software.com>...
>[Image]
Please do not post in HTML. It is difficult for me to open a picture that
is part of a HTML post using anything but my newsreader, and my newsreader
won't let me see more than a quarter of the picture at a time.
Mark
