POV-Ray : Newsgroups : povray.binaries.images : Iso_Pollen Server Time
24 Nov 2026 15:28:11 EST (-0500)
  Iso_Pollen (Message 1 to 17 of 17)
Subject: Iso_Pollen
Date: 4 Jan 2000 17:48:56
Message: <387278B4.41BD9AC5@pacbell.net>
Playing around with Warps recently posted function. It immediately reminded
me of either a seed PoD or a microscopic image of a pollen spore.
Question for the Guru's   -  Why is it that when bounding is removed this
object is a unit sized box object but when bounding is enabled the object
fills the bounding volume ?
Function for those interested in such things -
camera { location <5,10,-20>*4 look_at 0 angle 39 }
light_source { <100,200,-150> 1 }
isosurface
{ function
  { (sin(sqrt(-x*x+y*y)-pi/2)-z)^2+
    (sin(sqrt(-x*x+z*z)-pi/2)-y)^2+
    (sin(sqrt(-y*y+z*z)-pi/2)-x)^2-20^2
  accuracy .01
  max_trace 1
  threshold 0
  bounded_by { box { -30,30 } }
  pigment { rgb y } finish { phong -.5 specular .5 }
Download 'isotest.jpg' (28 KB)
Preview of image 'isotest.jpg'
Subject: Re: Iso_Pollen
Date: 4 Jan 2000 17:58:44
Message: <38727b24@news.povray.org>
aaa-aa-achoo!
Sorry, I just had to say that.
It does look remarkably like some sort of seed pod to me.
Not a clue on the bounding phenomenon.  Except maybe... isn't the isosurface
constrained to a unit size initially? Or am I way off there.
"Ken" <tyl### [at] pacbellnet> wrote in message
news:387278B4.41BD9AC5@pacbell.net...
reminded
Date: 4 Jan 2000 18:13:49
Message: <38727C5E.56F89EEC@faricy.net>
Does look like a type of pollen. I'm mostly used to seeing the kind that looks
like dehydrated red blood cells. (Hmm, I should try rendering hat with
blobs...)
From the MultiPatch page at nathan.kopp.com:
"The default is a box of <-1,-1,-1>, <1,1,1>"
Date: 4 Jan 2000 18:17:12
Message: <38727F66.741BE70D@pacbell.net>
I realize that many functions/objects in pov default to a unit square but
what I do not understand is why manual bounding affects this and why it
is not documented as doing so. I also need to know how one determines the
size of the bounding volume to use for a given iso surface object or if
it can be any arbitrary amount.
Date: 4 Jan 2000 18:27:04
Message: <chrishuff_99-3AD2F1.18270904012000@news.povray.org>
In article <387278B4.41BD9AC5@pacbell.net>, lin### [at] povrayorg
Isosurface objects require a bounding shape for their calculations, the
default is a unit sized box. Since this is entirely inside the function,
the whole box is filled with the object.
A better bounding shape for this isosurface might be a sphere.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 4 Jan 2000 18:38:37
Message: <chrishuff_99-B271B2.18384204012000@news.povray.org>
In article <38727F66.741BE70D@pacbell.net>, lin### [at] povrayorg
"bounded_by" does not work the same in isosurfaces as it does for other
shapes, it just uses a unit box as default. The bounding shape is just
the "container" for the isosurface. I really think this part of the
syntax should be changed when the isosurface is added to the official
version, and be replaced with something like "contained_by".
The size of the bounding shape doesn't really matter, if it is smaller
than the resulting shape it will be the same as intersecting the
isosurface with the bounding shape.
The only ways to determine the correct size are trial and error or
figuring out the furthest reach of the object from the equation and the
threshold value. I usually guess at it from the equation and then use
trial and error to get a shape that fits correctly. I also sometimes
switch to clipped_by(which does the same thing but leaves the surfaces
open) to make sure there are no intersecting points.
Chris Huff
Date: 4 Jan 2000 18:57:25
Message: <387288C8.61ABD6C@pacbell.net>
Thanks for the input Chris.
Date: 5 Jan 2000 15:20:29
Message: <yaZzOPdXi9P7je7hpq1=4lenA1Bi@4ax.com>
I can't help thinking about the poetry of the Azagoths  of  Kria, the
second worst poetry in the entire Universe, and in particular about
the masterpiece by Poet  Master Grunthos the Flatulent  called "Ode To
A Small Lump of Green Putty I Found In My Armpit One Midsummer
Morning".
And some Vogon poetry to go with that:
"Oh frettled gruntbuggly, thy micturations are to me
As plurdled gabbleblotchits  ona lurgid bee.
Groop I  implore  thee, my foonting turlingdromes.
And hooptiously drangle me with crinkly bindlewurdles,
Or I will rend thee in the  gobberwarts with my blurglecruncheon,
   see if I don't!"
Sorry, had to ;)
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 5 Jan 2000 15:25:40
Message: <3873A768.26ACC92D@pacbell.net>
Peter Popov wrote:
> Sorry, had to ;)
Well I'm glad you like it.
Date: 5 Jan 2000 15:33:26
Message: <chrishuff_99-1E7A21.15333305012000@news.povray.org>
In article <yaZzOPdXi9P7je7hpq1=4lenA1Bi@4ax.com>, Peter Popov
> Morning".
>    see if I don't!"
> Sorry, had to ;)
Been reading Douglas Adams lately? :-)
Chris Huff
Date: 5 Jan 2000 16:35:51
Message: <3873b937@news.povray.org>
Sounds a bit like Lewis Carroll:
"'t Was brillig, and the slithy toves
did gyre and gimble in the wabe..."
Was that earlier or later, Vogon (or whoever)?
Sander
Peter Popov <pet### [at] usanet> schreef in berichtnieuws
yaZzOPdXi9P7je7hpq1=4lenA1Bi@4ax.com...
> Morning".
>    see if I don't!"
> Sorry, had to ;)
> Peter Popov
> pet### [at] usanet
> ICQ: 15002700
Date: 5 Jan 2000 17:45:35
Message: <uMhzOF00hOZLNglcZShSMWCMJ1kq@4ax.com>
...All mimsy were the borogoves
And the mome raths outgrabe!
Hey, I know "Jabberwock" by heart both in English and Bulgarian :))
Vogons are an alien race in "The Hitchiker's Guide to the Galaxy" by
Douglas Adams. The novel was written in the early 80s I think.
This should really be in p.o-t. sorry...
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 5 Jan 2000 17:46:09
Message: <U8lzOLOnHVgZlpTAFAv22aqLdulU@4ax.com>
On Wed, 05 Jan 2000 15:33:33 -0500, Chris Huff
Not lately (been a couple of years), but Vogon poetry is something one
remembers for a lifetime.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 5 Jan 2000 21:02:52
Message: <slrn877i5q.4k1.sjlen@zero-pps.localdomain>
Reminds me of a Ferero Roche (chocolate coverd sweet
that looks expensive but is very cheap).
  4:55pm  up 2 days, 15:29,  1 user,  load average: 1.08, 1.02, 1.01
Date: 5 Jan 2000 21:47:00
Message: <3873FFD4.D59887CB@faricy.net>
The European speciality your guests will adore?
Date: 7 Jan 2000 18:42:30
Message: <slrn87a9ss.61a.sjlen@zero-pps.localdomain>
The image inspired even better poetry. No offence Ken;-)
>Morning".
>   see if I don't!"
>Sorry, had to ;)
>Peter Popov
>pet### [at] usanet
>ICQ: 15002700
 11:20pm  up 3 days, 21:54,  5 users,  load average: 2.00, 1.39, 1.16
Date: 7 Jan 2000 18:42:31
Message: <slrn87aa3d.61a.sjlen@zero-pps.localdomain>
Though life can be quite short when listening to Vogon poetry. Some don't
even make it to the end of the first verse.
