POV-Ray : Newsgroups : povray.binaries.images : POV gallery 1 Server Time
5 Nov 2024 16:38:16 EST (-0500)
  POV gallery 1 (Message 21 to 27 of 27)
Subject: Re: POV gallery 1
Date: 6 Jan 2000 15:33:12
Message: <3873C0FE.325AECE7@melbpc.org.au>
Sigmund Kyrre Aas wrote:
> Those boards should have been cut at
> different places in the log, or perhaps a little tilted along x or z.
There was only one board that was duplicated, but in one direction only, I
should have offset them to make it appear more realistic.
  ,-._|\  Alex McMurray
 /  Oz  \ ale### [at] melbpcorgau               Melbourne PC User Group.
 \_,--.x/Melton. Vic.                                    Australia
       v
Date: 6 Jan 2000 15:33:15
Message: <3873C27E.DFCB2294@melbpc.org.au>
David Fontaine wrote:
> Some of the image_map ratios are wrong I think, a standard render is
> 3:4. (I'm looking at my now squashed pirate ship...) Or else it's a
> camera problem, but you should fix it.
> Be sure to give all the artists credit if/when you put this up.
When I looked closer to the images, I noticed that the artist name plates
that were supposed to be below the image maps were missing, the new image
will have the artists credits attached.  Thank you.
       v
Date: 6 Jan 2000 16:28:27
Message: <3875086B.7A3D133A@tapestry.tucson.az.us>
Alex McMurray wrote:
> Kevin Wampler wrote:
> > Great idea!  When you finish this project, maybe you could set up a web
> > site and create a Myst-like virtual gallery, so you can travel around
> > inside of it.
> That would be nice, but I have absolutely no idea how to program in VRML,
> I'd have to steal some space on my son's web page to house it though.
No need for VRML, I was thinking of using imagemaps, so you "jump" from one
camera position to another when you click on the appropriate place on the
screen.  The biggest problem is that you would have to render a whole bunch
of images for it.
Date: 6 Jan 2000 16:32:07
Message: <3875094A.BA7FFDFC@tapestry.tucson.az.us>
I don't know if this is how you are doing it already, but I would suggest
using a repeat warp to do the boards.  It makes it so you only have to have
one object for the floor, and doing things like adding an offset is trivial.
>        v
Date: 6 Jan 2000 23:06:41
Message: <3874BDA0.59AB645E@ij.net>
> > inside of it.
    Given the converters out there I would be surprised if anyone actually
programs in VRML.
Date: 7 Jan 2000 01:59:01
Message: <H451OP4JkGgj4kAm1++XIboAALxt@4ax.com>
>programs in VRML.
I tried it two years ago because I was fooled by the fact that it is
script based and has primitives (hint, hint). When I found out that in
order to transform a red sphere, one should have
transform
{ <transform specs>
  pigment
  { <pigment specs>
    sphere { <sphere specs> }
which is the complete inverse of what I was and am used to. I gave it
up.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 10 Jan 2000 14:14:31
Message: <387904E1.1B6488B1@melbpc.org.au>
> of images for it.
Not such a bad idea, you're right though, having to render all those images, I
am currently revamping the whole thing after reading all the comments.
Hopefully it will be imporved.
 \_,--.x/ Melton. Vic.                                   Australia
       v
