POV-Ray : Newsgroups : povray.binaries.images : craters Server Time
25 Oct 2026 18:16:23 EDT (-0400)
  craters (Message 1 to 20 of 20)
Subject: craters
Date: 1 Jan 2000 20:05:56
Message: <386EA3D5.9C998A08@xs4all.nl>
The attached image is not raytraced, it's a snapshot of the preview
window of a utility that is supposed to create planet(oid)s and add
craters and stuff. I tried doing this in POVRay but it took days to
parse at a reasonable resolution. In this case a preview only takes a
couple of minutes with the displaying part being the most time
consuming.
Finally I ran into problems with the amount of data. Apparently the
program can't handle datastreams larger then 8(?)/10(?)/16(?)Mb (I don't
know exactly what the limit is) and the resulting files are enormous.
The example here has some 130000 triangles, which is more or less the
maximum, but it still doesn't look quite right.
The program is supposed to write all data to an inc-file with either a
couple of data-arrays or a mesh, but I'm afraid the filesize will be a
problem.
Remco
Download 'neogeotest.jpg' (24 KB)
Preview of image 'neogeotest.jpg'
Subject: Re: craters
Date: 1 Jan 2000 22:18:49
Message: <386EC21D.D3EF464F@teleport.com>
Looks like a modified ripples pattern mixed with a spherical isosurface.  By
the way, I've found that very realistic planetoids can be created by combining
a granite pigment with a spherical isosurface.  Renders fast, too!
Date: 1 Jan 2000 22:52:17
Message: <386ECBB1.73C897FE@istar.ca>
Can you post the source in one of the groups? I still can't figure out how to
incorporate pigments into isosurfaces :(
Date: 1 Jan 2000 23:41:10
Message: <386ED665.896CB9FD@xs4all.nl>
> isosurface.  By
> combining
Oops, seems all my efforts were in vain then.
I was rather satisfied I finally managed to get a tracable output (see
image) although the results don't look very realistic. This image took
±3 minutes to parse and 1 to render with ±40Mb of memory. I was going to
ask how I could improve the way the craters look but never mind... 8)
Remco
Download 'c_test2.jpg' (18 KB)
Preview of image 'c_test2.jpg'
Date: 2 Jan 2000 03:53:37
Message: <46+5hKAdGxb4EwVi@econym.demon.co.uk>
>consuming.
>problem.
I'd try to approach it with an isosurface made up of a sphere, a few
leopard pigments, and a bit of noise. Something like this:-
#declare Crater=pigment {
  leopard
  color_map { [0 rgb 1]
              [0.2 rgb 1]
              [0.3 rgb 0]
              [0.4 rgb 1]
              [1 rgb 1] }
#declare Sphere=function{"Sphere",<1>}
#declare C1=function{pigment{Crater scale 0.04}}
#declare C2=function{pigment{Crater scale 0.07}}
#declare C3=function{pigment{Crater scale 0.10}}
#declare C4=function{pigment{Crater scale 0.20}}
  isosurface {
  function { Sphere(x,y,z)
             +C1(x,y,z)*0.005
             +C2(x,y,z)*0.01
             +C3(x,y,z)*0.005
             +C4(x,y,z)*0.01
             +noise3d(x*100,y*100,z*100)*0.003
  eval
  accuracy 0.001
  bounded_by{sphere{0,1}}
  pigment {rgb 0.5}
Mike Williams + #
Gentleman of Leisure
Date: 2 Jan 2000 05:53:19
Message: <386f2e1f@news.povray.org>
Remco
I love your various utilities and downloads. (Sadly I have had to forego
using psych but I believe that to be an Evil Microsoft* problem).
SoftText is awesome and I use Bumper all the time on my old box.
Personally I do not know how useful this type of program would be.
Especially with the long parse times and huge file size.
Mostly I just wanted to say Hello and wish you a Happy New Year.
Peter Warren
war### [at] hotmailcom
*as a resident of Gates Country (Seattle) this is just a affectionate
 term of endearment that the locals use. It is in no way intended to be
 a criticism of any OS.
Download 'castle.jpg' (9 KB)
Preview of image 'castle.jpg'
Date: 2 Jan 2000 07:24:08
Message: <386F42ED.968E8D6F@xs4all.nl>
Peter Warren wrote:
>  Remco
> forego
> Peter Warren
Thank you, you're very kind.
I've been doodling with creating spheres for some time now, doing all
sorts of stuff with it, not with any plan in mind. This was just another
thing I thought I might try. Luckily I managed to get it working (which
was more then I expected) but I soon realized it wouldn't be of much
use. Even with the (to me amazing) speed of the creating, parsing and
tracing it still needs an absurd amount of memory with a result that is
on the edge of being acceptable (you decide on which side).
Anyway, Hello to you and a Happy New Year as well and to all others here
and everywhere 8)
Remco
Date: 2 Jan 2000 09:17:45
Message: <386f5e09@news.povray.org>
Can the inside to outside crater edge be modified in such a way that the
inside falls off to be sharper and outside falls off to be more extended,
such as in real life cratering?
"Remco de Korte" <rem### [at] xs4allnl> wrote in message
news:386ED665.896CB9FD@xs4all.nl...
> > isosurface.  By
> > combining
> Remco
Date: 2 Jan 2000 10:30:20
Message: <chrishuff_99-24353C.10302202012000@news.povray.org>
> how to incorporate pigments into isosurfaces :(
This should work:
#declare MyPigmentFunction =
function {
   pigment {blahblah}
then you just use this function as you would noise3d:
MyPigmentFunction(x, y, z)
Chris Huff
e-mail: chr### [at] yahoocom
Date: 2 Jan 2000 12:15:57
Message: <386F8750.EFE2784@xs4all.nl>
> the
> extended,
> Bob
Easily. I should have made more changes to the craters anyway. I hadn't
looked at any examples yet. For instance, the overlapping craters seem
wrong to me.
Remco
Date: 2 Jan 2000 16:12:43
Message: <386FBDB7.7202E216@teleport.com>
Chris, I've got a problem.  The code I used to make this works in the
Mini-Patch but not in the Mega-Patch.  Any clue?
#declare Texture =
pigment { granite
color_map {
[0 rgb .5]
[1 rgb .75]
scale 5
finish {ambient 0 diffuse 1}
pigment { bozo
pigment_map {
[.1 rgbt 1]
[.9 granite
color_map {
[0 rgb .75]
[1 rgb 1]
scale 10
scale .5
turbulence .5
omega .125
#declare Base=function {"Sphere",<1>}
#declare Moonlikebumps=
function {
pigment {granite
color_map {[0 rgb 0][1 rgb 1]}
scale 2.5
isosurface {
function {
Base(x,y,z)+Moonlikebumps(x,y,z)*.2
//+(Oid(-y,-z,-x))*.2
//+(Oid2(x,y,z))*.25/10
//+(Oid3(x,y,z))*.25/20
eval
accuracy .005
texture {Texture}
direction 1
location <-1,1,-1>*2
look_at <0,0,0>
light_source {<25,20,-50>*100 rgb <1.15,1.15,1>*1}
light_source {<0,-20,50>*100 rgb <.5,.5,1>/2}
H.E. Day
Science is merely a method of gathering data and information.
Science *cannot* prove facts.
It can only provide theories that fit given data.
Technology is merely Science applied to common situations.
Technology is used for both good and evil.
Society is a framework mostly dependent on the willing participation of it
subjects.
Kingdoms and dominions come and go, none are eternal.
In the end, Society, Technology, and Science do not matter.  Only the
actions
and choices of the individual will matter. <><
Date: 2 Jan 2000 17:34:52
Message: <chrishuff_99-45D846.17345402012000@news.povray.org>
It works fine(and with very nice results) here using MacMegaPOV 0.2. Are
you sure you are using the latest version?
Chris Huff
Date: 3 Jan 2000 02:02:01
Message: <38704969@news.povray.org>
"H.E. Day" <mil### [at] teleportcom> wrote :
> isosurface {
> function {
    This is lots of fun! I suspect that we will see some much better planets
in the next few weeks. Here's my first try.
    I am working on some texture_maps to improve this.
Download 'HEDAYPlanet.jpg' (74 KB)
Preview of image 'HEDAYPlanet.jpg'
Date: 3 Jan 2000 03:20:48
Message: <386F0C6A.D1D3CE19@earthlink.net>
Looks Like Someone Has Let There Science Project Go Too Far....
Penicillin Anyone...
Just Kidding...
Wish The Official Vers. Could Handle This Stuff...
> > isosurface {
> > function {
Date: 3 Jan 2000 09:55:28
Message: <3870b860@news.povray.org>
the hills are to extreme, dont forget that the earth from space appears
almost perfectly flat, maybe if they were about 1/3rd as pronounced it would
look perfect
"Bill DeWitt" <the### [at] earthlinknet> wrote in message
news:38704969@news.povray.org...
> > isosurface {
> > function {
planets
Date: 3 Jan 2000 10:10:51
Message: <3870bbfb@news.povray.org>
Right, but then it was indistinguishable from just a bozo pigment. I had to
lift the mountains enough for them to throw noticeable shadows before it
looked anything but flat.
Remember, often the appearance of reality is more important than the reality
of the appearance.
"Rick" <pov### [at] dialpipexcom> wrote in message
news:3870b860@news.povray.org...
would
> look perfect
> Rick
> > > isosurface {
> > > function {
> planets
Date: 3 Jan 2000 13:37:40
Message: <3870EA98.7817968B@gci.net>
Bill DeWitt wrote:
This looks a lot like a half-eaten bubblegum ball I found when cleaning the
kid's bedroom last week. :{)
David
Keeper of the family pets.
"You want fish? I got fish. I got fish, and eels, and turtles, and snails, and
frogs, and dragons and cats..."
Date: 3 Jan 2000 16:41:24
Message: <38711537.838060C7@faricy.net>
> look perfect
Nah, it's just the smallest M-class planet in the galaxy!
Date: 4 Jan 2000 03:15:49
Message: <3871ABFE.1DB9329B@pobox.com>
Real crater rims are not additive, like ripples: the new obliterate the
old.  That is why these moons look wrong.
"How'd ya like to climb this high without no mountain?" --Porky Pine
Anton Sherwood  *\\* +1 415 267 0685 *\\* http://www.jps.net/antons/
Date: 4 Jan 2000 09:38:51
Message: <3872057C.968952A1@xs4all.nl>
> the
That's what I thought. It'd be easy to fix, but I've moved the whole
thing to the Big Giant Archives.
Remco
